[技术问答] I2C bus 添加 设备问题求教
3330|35
s2333 发表于 2019-9-23 18:48 | 显示全部楼层
Lbb121358 发表于 2019-9-23 13:43
主要在怎么修改?
刚刚大致翻了翻
linux-3.10.x\sound\soc\codecs\sgtl5000.c
你这个文件里:
static struct regulator_consumer_supply ldo_consumer[] = {
        REGULATOR_SUPPLY(LDO_CONSUMER_NAME, NULL),
改为:
        REGULATOR_SUPPLY(LDO_CONSUMER_NAME, “0-000a”),
这里0-000a和你前面改的.codec_name     = "sgtl5000.0-000a",对应起来试试看;
然后看看系统内核启动时,显示出来的一些信息,注意观察这部分内核的一些提示信息
还是不行的话,百度google找找类似的驱动移植吧
 楼主| Lbb121358 发表于 2019-9-23 20:09 | 显示全部楼层
刚刚大致翻了翻
你这个文件里:
NUC972 limian de wenjian
* sgtl5000.c  --  SGTL5000 ALSA SoC Audio driver
* Copyright 2010-2011 Freescale Semiconductor, Inc. All Rights Reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
#include <linux/module.h>
#include <linux/moduleparam.h>
#include <linux/init.h>
#include <linux/delay.h>
#include <linux/slab.h>
#include <linux/pm.h>
#include <linux/i2c.h>
#include <linux/clk.h>
#include <linux/regulator/driver.h>
#include <linux/regulator/machine.h>
#include <linux/regulator/consumer.h>
#include <linux/of_device.h>
#include <sound/core.h>
#include <sound/tlv.h>
#include <sound/pcm.h>
#include <sound/pcm_params.h>
#include <sound/soc.h>
#include <sound/soc-dapm.h>
#include <sound/initval.h>
#include "sgtl5000.h"
#define SGTL5000_DAP_REG_OFFSET        0x0100
#define SGTL5000_MAX_REG_OFFSET        0x013A
/* default value of sgtl5000 registers */
static const u16 sgtl5000_regs[SGTL5000_MAX_REG_OFFSET] =  {
        [SGTL5000_CHIP_CLK_CTRL] = 0x0008,
        [SGTL5000_CHIP_I2S_CTRL] = 0x0010,
        [SGTL5000_CHIP_SSS_CTRL] = 0x0010,
        [SGTL5000_CHIP_DAC_VOL] = 0x3c3c,
        [SGTL5000_CHIP_PAD_STRENGTH] = 0x015f,
        [SGTL5000_CHIP_ANA_HP_CTRL] = 0x1818,
        [SGTL5000_CHIP_ANA_CTRL] = 0x0111,
        [SGTL5000_CHIP_LINE_OUT_VOL] = 0x0404,
        [SGTL5000_CHIP_ANA_POWER] = 0x7060,
        [SGTL5000_CHIP_PLL_CTRL] = 0x5000,
        [SGTL5000_DAP_BASS_ENHANCE] = 0x0040,
        [SGTL5000_DAP_BASS_ENHANCE_CTRL] = 0x051f,
        [SGTL5000_DAP_SURROUND] = 0x0040,
        [SGTL5000_DAP_EQ_BASS_BAND0] = 0x002f,
        [SGTL5000_DAP_EQ_BASS_BAND1] = 0x002f,
        [SGTL5000_DAP_EQ_BASS_BAND2] = 0x002f,
        [SGTL5000_DAP_EQ_BASS_BAND3] = 0x002f,
        [SGTL5000_DAP_EQ_BASS_BAND4] = 0x002f,
        [SGTL5000_DAP_MAIN_CHAN] = 0x8000,
        [SGTL5000_DAP_AVC_CTRL] = 0x0510,
        [SGTL5000_DAP_AVC_THRESHOLD] = 0x1473,
        [SGTL5000_DAP_AVC_ATTACK] = 0x0028,
        [SGTL5000_DAP_AVC_DECAY] = 0x0050,
/* regulator supplies for sgtl5000, VDDD is an optional external supply */
enum sgtl5000_regulator_supplies {
        VDDA,
        VDDIO,
        VDDD,
        SGTL5000_SUPPLY_NUM
/* vddd is optional supply */
static const char *supply_names[SGTL5000_SUPPLY_NUM] = {
        "VDDA",
        "VDDIO",
        "VDDD"
#define LDO_CONSUMER_NAME        "VDDD_LDO"
#define LDO_VOLTAGE                1200000
static struct regulator_init_data ldo_init_data = {
        .constraints = {
                .min_uV                 = 1200000,
                .max_uV                 = 1200000,
                .valid_modes_mask       = REGULATOR_MODE_NORMAL,
                .valid_ops_mask         = REGULATOR_CHANGE_STATUS,
        .num_consumer_supplies = 1,
        .consumer_supplies = &ldo_consumer[0],
* sgtl5000 internal ldo regulator,
* enabled when VDDD not provided
struct ldo_regulator {
        struct regulator_desc desc;
        struct regulator_dev *dev;
        int voltage;
        void *codec_data;
        bool enabled;
/* sgtl5000 private structure in codec */
struct sgtl5000_priv {
        int sysclk;        /* sysclk rate */
        int master;        /* i2s master or not */
        int fmt;        /* i2s data format */
        struct regulator_bulk_data supplies[SGTL5000_SUPPLY_NUM];
        struct ldo_regulator *ldo;
* mic_bias power on/off share the same register bits with
* output impedance of mic bias, when power on mic bias, we
* need reclaim it to impedance value.
* 0x0 = Powered off
* 0x1 = 2Kohm
* 0x2 = 4Kohm
* 0x3 = 8Kohm
static int mic_bias_event(struct snd_soc_dapm_widget *w,
        struct snd_kcontrol *kcontrol, int event)
        switch (event) {
        case SND_SOC_DAPM_POST_PMU:
                /* change mic bias resistor to 4Kohm */
                snd_soc_update_bits(w->codec, SGTL5000_CHIP_MIC_CTRL,
                                SGTL5000_BIAS_R_MASK,
                                SGTL5000_BIAS_R_4k << SGTL5000_BIAS_R_SHIFT);
                break;
        case SND_SOC_DAPM_PRE_PMD:
                                SGTL5000_BIAS_R_MASK, 0);
                break;
        return 0;
* As manual described, ADC/DAC only works when VAG powerup,
* So enabled VAG before ADC/DAC up.
* In power down case, we need wait 400ms when vag fully ramped down.
static int power_vag_event(struct snd_soc_dapm_widget *w,
        switch (event) {
        case SND_SOC_DAPM_PRE_PMU:
                snd_soc_update_bits(w->codec, SGTL5000_CHIP_ANA_POWER,
                        SGTL5000_VAG_POWERUP, SGTL5000_VAG_POWERUP);
                break;
        case SND_SOC_DAPM_POST_PMD:
                        SGTL5000_VAG_POWERUP, 0);
                msleep(400);
                break;
        default:
                break;
        return 0;
/* input sources for ADC */
static const char *adc_mux_text[] = {
        "MIC_IN", "LINE_IN"
static const struct soc_enum adc_enum =
SOC_ENUM_SINGLE(SGTL5000_CHIP_ANA_CTRL, 2, 2, adc_mux_text);
static const struct snd_kcontrol_new adc_mux =
SOC_DAPM_ENUM("Capture Mux", adc_enum);
/* input sources for DAC */
static const char *dac_mux_text[] = {
        "DAC", "LINE_IN"
static const struct soc_enum dac_enum =
SOC_ENUM_SINGLE(SGTL5000_CHIP_ANA_CTRL, 6, 2, dac_mux_text);
static const struct snd_kcontrol_new dac_mux =
SOC_DAPM_ENUM("Headphone Mux", dac_enum);
static const struct snd_soc_dapm_widget sgtl5000_dapm_widgets[] = {
        SND_SOC_DAPM_INPUT("LINE_IN"),
        SND_SOC_DAPM_INPUT("MIC_IN"),
        SND_SOC_DAPM_OUTPUT("HP_OUT"),
        SND_SOC_DAPM_OUTPUT("LINE_OUT"),
        SND_SOC_DAPM_SUPPLY("Mic Bias", SGTL5000_CHIP_MIC_CTRL, 8, 0,
                            mic_bias_event,
                            SND_SOC_DAPM_POST_PMU | SND_SOC_DAPM_PRE_PMD),
        SND_SOC_DAPM_PGA("HP", SGTL5000_CHIP_ANA_POWER, 4, 0, NULL, 0),
        SND_SOC_DAPM_PGA("LO", SGTL5000_CHIP_ANA_POWER, 0, 0, NULL, 0),
        SND_SOC_DAPM_MUX("Capture Mux", SND_SOC_NOPM, 0, 0, &adc_mux),
        SND_SOC_DAPM_MUX("Headphone Mux", SND_SOC_NOPM, 0, 0, &dac_mux),
        /* aif for i2s input */
        SND_SOC_DAPM_AIF_IN("AIFIN", "Playback",
                                0, SGTL5000_CHIP_DIG_POWER,
                                0, 0),
        /* aif for i2s output */
        SND_SOC_DAPM_AIF_OUT("AIFOUT", "Capture",
                                1, 0),
        SND_SOC_DAPM_SUPPLY("VAG_POWER", SGTL5000_CHIP_ANA_POWER, 7, 0,
                            power_vag_event,
                            SND_SOC_DAPM_PRE_PMU | SND_SOC_DAPM_POST_PMD),
        SND_SOC_DAPM_ADC("ADC", "Capture", SGTL5000_CHIP_ANA_POWER, 1, 0),
        SND_SOC_DAPM_DAC("DAC", "Playback", SGTL5000_CHIP_ANA_POWER, 3, 0),
/* routes for sgtl5000 */
static const struct snd_soc_dapm_route sgtl5000_dapm_routes[] = {
        {"Capture Mux", "LINE_IN", "LINE_IN"},        /* line_in --> adc_mux */
        {"Capture Mux", "MIC_IN", "MIC_IN"},        /* mic_in --> adc_mux */
        {"ADC", NULL, "VAG_POWER"},
        {"ADC", NULL, "Capture Mux"},                /* adc_mux --> adc */
        {"AIFOUT", NULL, "ADC"},                /* adc --> i2s_out */
        {"DAC", NULL, "VAG_POWER"},
        {"DAC", NULL, "AIFIN"},                        /* i2s-->dac,skip audio mux */
        {"Headphone Mux", "DAC", "DAC"},        /* dac --> hp_mux */
        {"LO", NULL, "DAC"},                        /* dac --> line_out */
        {"LINE_IN", NULL, "VAG_POWER"},
        {"Headphone Mux", "LINE_IN", "LINE_IN"},/* line_in --> hp_mux */
        {"HP", NULL, "Headphone Mux"},                /* hp_mux --> hp */
        {"LINE_OUT", NULL, "LO"},
        {"HP_OUT", NULL, "HP"},
/* custom function to fetch info of PCM playback volume */
static int dac_info_volsw(struct snd_kcontrol *kcontrol,
                          struct snd_ctl_elem_info *uinfo)
        uinfo->type = SNDRV_CTL_ELEM_TYPE_INTEGER;
        uinfo->count = 2;
        uinfo->value.integer.min = 0;
        uinfo->value.integer.max = 0xfc - 0x3c;
        return 0;
* custom function to get of PCM playback volume
* dac volume register
* 15-------------8-7--------------0
* | R channel vol | L channel vol |
* PCM volume with 0.5017 dB steps from 0 to -90 dB
* register values map to dB
* 0x3B and less = Reserved
* 0x3C = 0 dB
* 0x3D = -0.5 dB
* 0xF0 = -90 dB
* 0xFC and greater = Muted
* register value map to userspace value
* register value        0x3c(0dB)          0xf0(-90dB)0xfc
* userspace value        0xc0                             0
static int dac_get_volsw(struct snd_kcontrol *kcontrol,
                         struct snd_ctl_elem_value *ucontrol)
        struct snd_soc_codec *codec = snd_kcontrol_chip(kcontrol);
        int reg;
        int l;
        int r;
        reg = snd_soc_read(codec, SGTL5000_CHIP_DAC_VOL);
        /* get left channel volume */
        l = (reg & SGTL5000_DAC_VOL_LEFT_MASK) >> SGTL5000_DAC_VOL_LEFT_SHIFT;
        /* get right channel volume */
        r = (reg & SGTL5000_DAC_VOL_RIGHT_MASK) >> SGTL5000_DAC_VOL_RIGHT_SHIFT;
        /* make sure value fall in (0x3c,0xfc) */
        l = clamp(l, 0x3c, 0xfc);
        r = clamp(r, 0x3c, 0xfc);
        /* invert it and map to userspace value */
        l = 0xfc - l;
        r = 0xfc - r;
        ucontrol->value.integer.value[0] = l;
        ucontrol->value.integer.value[1] = r;
        return 0;
* custom function to put of PCM playback volume
* 0x3C = 0 dB
* 0x3D = -0.5 dB
* 0xF0 = -90 dB
* userspace value map to register value
static int dac_put_volsw(struct snd_kcontrol *kcontrol,
        int reg;
        int l;
        int r;
        l = ucontrol->value.integer.value[0];
        r = ucontrol->value.integer.value[1];
        /* make sure userspace volume fall in (0, 0xfc-0x3c) */
        l = clamp(l, 0, 0xfc - 0x3c);
        r = clamp(r, 0, 0xfc - 0x3c);
        /* invert it, get the value can be set to register */
        l = 0xfc - l;
        r = 0xfc - r;
        /* shift to get the register value */
        reg = l << SGTL5000_DAC_VOL_LEFT_SHIFT |
                r << SGTL5000_DAC_VOL_RIGHT_SHIFT;
        snd_soc_write(codec, SGTL5000_CHIP_DAC_VOL, reg);
        return 0;
static const DECLARE_TLV_DB_SCALE(capture_6db_attenuate, -600, 600, 0);
/* tlv for mic gain, 0db 20db 30db 40db */
static const unsigned int mic_gain_tlv[] = {
        TLV_DB_RANGE_HEAD(2),
        0, 0, TLV_DB_SCALE_ITEM(0, 0, 0),
        1, 3, TLV_DB_SCALE_ITEM(2000, 1000, 0),
/* tlv for hp volume, -51.5db to 12.0db, step .5db */
static const DECLARE_TLV_DB_SCALE(headphone_volume, -5150, 50, 0);
static const struct snd_kcontrol_new sgtl5000_snd_controls[] = {
        /* SOC_DOUBLE_S8_TLV with invert */
                .iface = SNDRV_CTL_ELEM_IFACE_MIXER,
                .name = "PCM Playback Volume",
                .access = SNDRV_CTL_ELEM_ACCESS_TLV_READ |
                        SNDRV_CTL_ELEM_ACCESS_READWRITE,
                .info = dac_info_volsw,
                .get = dac_get_volsw,
                .put = dac_put_volsw,
        SOC_DOUBLE("Capture Volume", SGTL5000_CHIP_ANA_ADC_CTRL, 0, 4, 0xf, 0),
        SOC_SINGLE_TLV("Capture Attenuate Switch (-6dB)",
                        8, 2, 0, capture_6db_attenuate),
        SOC_SINGLE("Capture ZC Switch", SGTL5000_CHIP_ANA_CTRL, 1, 1, 0),
        SOC_DOUBLE_TLV("Headphone Playback Volume",
                        SGTL5000_CHIP_ANA_HP_CTRL,
                        0, 8,
                        0x7f, 1,
                        headphone_volume),
        SOC_SINGLE("Headphone Playback ZC Switch", SGTL5000_CHIP_ANA_CTRL,
                        5, 1, 0),
        SOC_SINGLE_TLV("Mic Volume", SGTL5000_CHIP_MIC_CTRL,
                        0, 3, 0, mic_gain_tlv),
/* mute the codec used by alsa core */
static int sgtl5000_digital_mute(struct snd_soc_dai *codec_dai, int mute)
        struct snd_soc_codec *codec = codec_dai->codec;
        u16 adcdac_ctrl = SGTL5000_DAC_MUTE_LEFT | SGTL5000_DAC_MUTE_RIGHT;
        snd_soc_update_bits(codec, SGTL5000_CHIP_ADCDAC_CTRL,
                        adcdac_ctrl, mute ? adcdac_ctrl : 0);
        return 0;
/* set codec format */
static int sgtl5000_set_dai_fmt(struct snd_soc_dai *codec_dai, unsigned int fmt)
        struct sgtl5000_priv *sgtl5000 = snd_soc_codec_get_drvdata(codec);
        u16 i2sctl = 0;
        sgtl5000->master = 0;
         * i2s clock and frame master setting.
         * ONLY support:
         *  - clock and frame slave,
         *  - clock and frame master
        switch (fmt & SND_SOC_DAIFMT_MASTER_MASK) {
        case SND_SOC_DAIFMT_CBS_CFS:
                break;
        case SND_SOC_DAIFMT_CBM_CFM:
                i2sctl |= SGTL5000_I2S_MASTER;
                sgtl5000->master = 1;
                break;
        default:
                return -EINVAL;
        /* setting i2s data format */
        switch (fmt & SND_SOC_DAIFMT_FORMAT_MASK) {
        case SND_SOC_DAIFMT_DSP_A:
                i2sctl |= SGTL5000_I2S_MODE_PCM;
                break;
        case SND_SOC_DAIFMT_DSP_B:
                i2sctl |= SGTL5000_I2S_LRALIGN;
                break;
        case SND_SOC_DAIFMT_I2S:
                i2sctl |= SGTL5000_I2S_MODE_I2S_LJ;
                break;
        case SND_SOC_DAIFMT_RIGHT_J:
                i2sctl |= SGTL5000_I2S_MODE_RJ;
                i2sctl |= SGTL5000_I2S_LRPOL;
                break;
        case SND_SOC_DAIFMT_LEFT_J:
                break;
        default:
                return -EINVAL;
        sgtl5000->fmt = fmt & SND_SOC_DAIFMT_FORMAT_MASK;
        /* Clock inversion */
        switch (fmt & SND_SOC_DAIFMT_INV_MASK) {
        case SND_SOC_DAIFMT_NB_NF:
                break;
        case SND_SOC_DAIFMT_IB_NF:
                i2sctl |= SGTL5000_I2S_SCLK_INV;
                break;
        default:
                return -EINVAL;
        snd_soc_write(codec, SGTL5000_CHIP_I2S_CTRL, i2sctl);
        return 0;
/* set codec sysclk */
static int sgtl5000_set_dai_sysclk(struct snd_soc_dai *codec_dai,
                                   int clk_id, unsigned int freq, int dir)
        switch (clk_id) {
        case SGTL5000_SYSCLK:
                sgtl5000->sysclk = freq;
                break;
        default:
                return -EINVAL;
        return 0;
* set clock according to i2s frame clock,
* sgtl5000 provide 2 clock sources.
* 1. sys_mclk. sample freq can only configure to
*        1/256, 1/384, 1/512 of sys_mclk.
* 2. pll. can derive any audio clocks.
* clock setting rules:
* 1. in slave mode, only sys_mclk can use.
* 2. as constraint by sys_mclk, sample freq should
*        set to 32k, 44.1k and above.
* 3. using sys_mclk prefer to pll to save power.
static int sgtl5000_set_clock(struct snd_soc_codec *codec, int frame_rate)
        int clk_ctl = 0;
        int sys_fs;        /* sample freq */
         * sample freq should be divided by frame clock,
         * if frame clock lower than 44.1khz, sample feq should set to
         * 32khz or 44.1khz.
        switch (frame_rate) {
        case 8000:
        case 16000:
                sys_fs = 32000;
                break;
        case 11025:
        case 22050:
                sys_fs = 44100;
                break;
        default:
                sys_fs = frame_rate;
                break;
        /* set divided factor of frame clock */
        switch (sys_fs / frame_rate) {
        case 4:
                clk_ctl |= SGTL5000_RATE_MODE_DIV_4 << SGTL5000_RATE_MODE_SHIFT;
                break;
        case 2:
                clk_ctl |= SGTL5000_RATE_MODE_DIV_2 << SGTL5000_RATE_MODE_SHIFT;
                break;
        case 1:
                clk_ctl |= SGTL5000_RATE_MODE_DIV_1 << SGTL5000_RATE_MODE_SHIFT;
                break;
        default:
                return -EINVAL;
        /* set the sys_fs according to frame rate */
        switch (sys_fs) {
        case 32000:
                clk_ctl |= SGTL5000_SYS_FS_32k << SGTL5000_SYS_FS_SHIFT;
                break;
        case 44100:
                clk_ctl |= SGTL5000_SYS_FS_44_1k << SGTL5000_SYS_FS_SHIFT;
                break;
        case 48000:
                clk_ctl |= SGTL5000_SYS_FS_48k << SGTL5000_SYS_FS_SHIFT;
                break;
        case 96000:
                clk_ctl |= SGTL5000_SYS_FS_96k << SGTL5000_SYS_FS_SHIFT;
                break;
        default:
                dev_err(codec->dev, "frame rate %d not supported\n",
                        frame_rate);
                return -EINVAL;
         * calculate the divider of mclk/sample_freq,
         * factor of freq =96k can only be 256, since mclk in range (12m,27m)
        switch (sgtl5000->sysclk / sys_fs) {
        case 256:
                clk_ctl |= SGTL5000_MCLK_FREQ_256FS <<
                        SGTL5000_MCLK_FREQ_SHIFT;
                break;
        case 384:
                clk_ctl |= SGTL5000_MCLK_FREQ_384FS <<
                break;
        case 512:
                clk_ctl |= SGTL5000_MCLK_FREQ_512FS <<
                break;
        default:
                /* if mclk not satisify the divider, use pll */
                if (sgtl5000->master) {
                        clk_ctl |= SGTL5000_MCLK_FREQ_PLL <<
                } else {
                        dev_err(codec->dev,
                                "PLL not supported in slave mode\n");
                        return -EINVAL;
        /* if using pll, please check manual 6.4.2 for detail */
        if ((clk_ctl & SGTL5000_MCLK_FREQ_MASK) == SGTL5000_MCLK_FREQ_PLL) {
                u64 out, t;
                int div2;
                int pll_ctl;
                unsigned int in, int_div, frac_div;
                if (sgtl5000->sysclk > 17000000) {
                        div2 = 1;
                        in = sgtl5000->sysclk / 2;
                } else {
                        div2 = 0;
                        in = sgtl5000->sysclk;
                if (sys_fs == 44100)
                        out = 180633600;
                else
                        out = 196608000;
                t = do_div(out, in);
                int_div = out;
                t *= 2048;
                do_div(t, in);
                frac_div = t;
                pll_ctl = int_div << SGTL5000_PLL_INT_DIV_SHIFT |
                    frac_div << SGTL5000_PLL_FRAC_DIV_SHIFT;
                snd_soc_write(codec, SGTL5000_CHIP_PLL_CTRL, pll_ctl);
                if (div2)
                                SGTL5000_CHIP_CLK_TOP_CTRL,
                                SGTL5000_INPUT_FREQ_DIV2,
                                SGTL5000_INPUT_FREQ_DIV2);
                else
                                0);
                /* power up pll */
                snd_soc_update_bits(codec, SGTL5000_CHIP_ANA_POWER,
                        SGTL5000_PLL_POWERUP | SGTL5000_VCOAMP_POWERUP,
                        SGTL5000_PLL_POWERUP | SGTL5000_VCOAMP_POWERUP);
        } else {
                /* power down pll */
                        0);
        /* if using pll, clk_ctrl must be set after pll power up */
        snd_soc_write(codec, SGTL5000_CHIP_CLK_CTRL, clk_ctl);
        return 0;
* Set PCM DAI bit size and sample rate.
* input: params_rate, params_fmt
static int sgtl5000_pcm_hw_params(struct snd_pcm_substream *substream,
                                  struct snd_pcm_hw_params *params,
                                  struct snd_soc_dai *dai)
        struct snd_soc_codec *codec = dai->codec;
        int channels = params_channels(params);
        int i2s_ctl = 0;
        int stereo;
        int ret;
        /* sysclk should already set */
        if (!sgtl5000->sysclk) {
                dev_err(codec->dev, "%s: set sysclk first!\n", __func__);
                return -EFAULT;
        if (substream->stream == SNDRV_PCM_STREAM_PLAYBACK)
                stereo = SGTL5000_DAC_STEREO;
        else
                stereo = SGTL5000_ADC_STEREO;
        /* set mono to save power */
        snd_soc_update_bits(codec, SGTL5000_CHIP_ANA_POWER, stereo,
                        channels == 1 ? 0 : stereo);
        /* set codec clock base on lrclk */
        ret = sgtl5000_set_clock(codec, params_rate(params));
        if (ret)
                return ret;
        /* set i2s data format */
        switch (params_format(params)) {
        case SNDRV_PCM_FORMAT_S16_LE:
                if (sgtl5000->fmt == SND_SOC_DAIFMT_RIGHT_J)
                        return -EINVAL;
                i2s_ctl |= SGTL5000_I2S_DLEN_16 << SGTL5000_I2S_DLEN_SHIFT;
                i2s_ctl |= SGTL5000_I2S_SCLKFREQ_32FS <<
                    SGTL5000_I2S_SCLKFREQ_SHIFT;
                break;
        case SNDRV_PCM_FORMAT_S20_3LE:
                i2s_ctl |= SGTL5000_I2S_DLEN_20 << SGTL5000_I2S_DLEN_SHIFT;
                i2s_ctl |= SGTL5000_I2S_SCLKFREQ_64FS <<
                break;
        case SNDRV_PCM_FORMAT_S24_LE:
                i2s_ctl |= SGTL5000_I2S_DLEN_24 << SGTL5000_I2S_DLEN_SHIFT;
                break;
        case SNDRV_PCM_FORMAT_S32_LE:
                        return -EINVAL;
                i2s_ctl |= SGTL5000_I2S_DLEN_32 << SGTL5000_I2S_DLEN_SHIFT;
                break;
        default:
                return -EINVAL;
        snd_soc_update_bits(codec, SGTL5000_CHIP_I2S_CTRL,
                            SGTL5000_I2S_DLEN_MASK | SGTL5000_I2S_SCLKFREQ_MASK,
                            i2s_ctl);
        return 0;
#ifdef CONFIG_REGULATOR
static int ldo_regulator_is_enabled(struct regulator_dev *dev)
        struct ldo_regulator *ldo = rdev_get_drvdata(dev);
        return ldo->enabled;
static int ldo_regulator_enable(struct regulator_dev *dev)
        struct snd_soc_codec *codec = (struct snd_soc_codec *)ldo->codec_data;
        int reg;
        if (ldo_regulator_is_enabled(dev))
                return 0;
        /* set regulator value firstly */
        reg = (1600 - ldo->voltage / 1000) / 50;
        reg = clamp(reg, 0x0, 0xf);
        /* amend the voltage value, unit: uV */
        ldo->voltage = (1600 - reg * 50) * 1000;
        /* set voltage to register */
        snd_soc_update_bits(codec, SGTL5000_CHIP_LINREG_CTRL,
                                SGTL5000_LINREG_VDDD_MASK, reg);
                                SGTL5000_LINEREG_D_POWERUP,
                                SGTL5000_LINEREG_D_POWERUP);
        /* when internal ldo enabled, simple digital power can be disabled */
                                SGTL5000_LINREG_SIMPLE_POWERUP,
                                0);
        ldo->enabled = 1;
        return 0;
static int ldo_regulator_disable(struct regulator_dev *dev)
                                0);
        /* clear voltage info */
                                SGTL5000_LINREG_VDDD_MASK, 0);
        ldo->enabled = 0;
        return 0;
static int ldo_regulator_get_voltage(struct regulator_dev *dev)
        return ldo->voltage;
static struct regulator_ops ldo_regulator_ops = {
        .is_enabled = ldo_regulator_is_enabled,
        .enable = ldo_regulator_enable,
        .disable = ldo_regulator_disable,
        .get_voltage = ldo_regulator_get_voltage,
static int ldo_regulator_register(struct snd_soc_codec *codec,
                                struct regulator_init_data *init_data,
                                int voltage)
        struct regulator_config config = { };
        ldo = kzalloc(sizeof(struct ldo_regulator), GFP_KERNEL);
        if (!ldo) {
                dev_err(codec->dev, "failed to allocate ldo_regulator\n");
                return -ENOMEM;
        ldo->desc.name = kstrdup(dev_name(codec->dev), GFP_KERNEL);
        if (!ldo->desc.name) {
                kfree(ldo);
                dev_err(codec->dev, "failed to allocate decs name memory\n");
                return -ENOMEM;
        ldo->desc.type  = REGULATOR_VOLTAGE;
        ldo->desc.owner = THIS_MODULE;
        ldo->desc.ops   = &ldo_regulator_ops;
        ldo->desc.n_voltages = 1;
        ldo->codec_data = codec;
        ldo->voltage = voltage;
        config.dev = codec->dev;
        config.driver_data = ldo;
        config.init_data = init_data;
        ldo->dev = regulator_register(&ldo->desc, &config);
        if (IS_ERR(ldo->dev)) {
                int ret = PTR_ERR(ldo->dev);
                dev_err(codec->dev, "failed to register regulator\n");
                kfree(ldo->desc.name);
                kfree(ldo);
                return ret;
        sgtl5000->ldo = ldo;
        return 0;
static int ldo_regulator_remove(struct snd_soc_codec *codec)
        struct ldo_regulator *ldo = sgtl5000->ldo;
        if (!ldo)
                return 0;
        regulator_unregister(ldo->dev);
        kfree(ldo);
        return 0;
#else
                                int voltage)
        dev_err(codec->dev, "this setup needs regulator support in the kernel\n");
        return -EINVAL;
        return 0;
#endif
* set dac bias
* common state changes:
* startup:
* off --> standby --> prepare --> on
* standby --> prepare --> on
* stop:
* on --> prepare --> standby
static int sgtl5000_set_bias_level(struct snd_soc_codec *codec,
                                   enum snd_soc_bias_level level)
        int ret;
        switch (level) {
        case SND_SOC_BIAS_ON:
        case SND_SOC_BIAS_PREPARE:
                break;
        case SND_SOC_BIAS_STANDBY:
                if (codec->dapm.bias_level == SND_SOC_BIAS_OFF) {
                        ret = regulator_bulk_enable(
                                                ARRAY_SIZE(sgtl5000->supplies),
                                                sgtl5000->supplies);
                        if (ret)
                                return ret;
                        udelay(10);
                break;
        case SND_SOC_BIAS_OFF:
                regulator_bulk_disable(ARRAY_SIZE(sgtl5000->supplies),
                break;
        codec->dapm.bias_level = level;
        return 0;
#define SGTL5000_FORMATS (SNDRV_PCM_FMTBIT_S16_LE |\
                        SNDRV_PCM_FMTBIT_S20_3LE |\
                        SNDRV_PCM_FMTBIT_S24_LE |\
                        SNDRV_PCM_FMTBIT_S32_LE)
static const struct snd_soc_dai_ops sgtl5000_ops = {
        .hw_params = sgtl5000_pcm_hw_params,
        .digital_mute = sgtl5000_digital_mute,
        .set_fmt = sgtl5000_set_dai_fmt,
        .set_sysclk = sgtl5000_set_dai_sysclk,
static struct snd_soc_dai_driver sgtl5000_dai = {
        .name = "sgtl5000",
        .playback = {
                .stream_name = "Playback",
                .channels_min = 1,
                .channels_max = 2,
                 * only support 8~48K + 96K,
                 * TODO modify hw_param to support more
                .rates = SNDRV_PCM_RATE_8000_48000 | SNDRV_PCM_RATE_96000,
                .formats = SGTL5000_FORMATS,
        .capture = {
                .stream_name = "Capture",
                .channels_min = 1,
                .channels_max = 2,
        .ops = &sgtl5000_ops,
        .symmetric_rates = 1,
static int sgtl5000_volatile_register(struct snd_soc_codec *codec,
                                        unsigned int reg)
        switch (reg) {
        case SGTL5000_CHIP_ID:
        case SGTL5000_CHIP_ADCDAC_CTRL:
        case SGTL5000_CHIP_ANA_STATUS:
                return 1;
        return 0;
 楼主| Lbb121358 发表于 2019-9-23 20:10 | 显示全部楼层
刚刚大致翻了翻
你这个文件里:
#ifdef CONFIG_SUSPEND
static int sgtl5000_suspend(struct snd_soc_codec *codec)
        sgtl5000_set_bias_level(codec, SND_SOC_BIAS_OFF);
        return 0;
* restore all sgtl5000 registers,
* since a big hole between dap and regular registers,
* we will restore them respectively.
static int sgtl5000_restore_regs(struct snd_soc_codec *codec)
        u16 *cache = codec->reg_cache;
        u16 reg;
        /* restore regular registers */
        for (reg = 0; reg <= SGTL5000_CHIP_SHORT_CTRL; reg += 2) {
                /* These regs should restore in particular order */
                if (reg == SGTL5000_CHIP_ANA_POWER ||
                        reg == SGTL5000_CHIP_CLK_CTRL ||
                        reg == SGTL5000_CHIP_LINREG_CTRL ||
                        reg == SGTL5000_CHIP_LINE_OUT_CTRL ||
                        reg == SGTL5000_CHIP_REF_CTRL)
                        continue;
                snd_soc_write(codec, reg, cache[reg]);
        /* restore dap registers */
        for (reg = SGTL5000_DAP_REG_OFFSET; reg < SGTL5000_MAX_REG_OFFSET; reg += 2)
         * restore these regs according to the power setting sequence in
         * sgtl5000_set_power_regs() and clock setting sequence in
         * sgtl5000_set_clock().
         * The order of restore is:
         * 1. SGTL5000_CHIP_CLK_CTRL MCLK_FREQ bits (1:0) should be restore after
         *    SGTL5000_CHIP_ANA_POWER PLL bits set
         * 2. SGTL5000_CHIP_LINREG_CTRL should be set before
         *    SGTL5000_CHIP_ANA_POWER LINREG_D restored
         * 3. SGTL5000_CHIP_REF_CTRL controls Analog Ground Voltage,
         *    prefer to resotre it after SGTL5000_CHIP_ANA_POWER restored
        snd_soc_write(codec, SGTL5000_CHIP_LINREG_CTRL,
                        cache[SGTL5000_CHIP_LINREG_CTRL]);
        snd_soc_write(codec, SGTL5000_CHIP_ANA_POWER,
                        cache[SGTL5000_CHIP_ANA_POWER]);
                        cache[SGTL5000_CHIP_CLK_CTRL]);
        snd_soc_write(codec, SGTL5000_CHIP_REF_CTRL,
                        cache[SGTL5000_CHIP_REF_CTRL]);
        snd_soc_write(codec, SGTL5000_CHIP_LINE_OUT_CTRL,
                        cache[SGTL5000_CHIP_LINE_OUT_CTRL]);
        return 0;
static int sgtl5000_resume(struct snd_soc_codec *codec)
        /* Bring the codec back up to standby to enable regulators */
        sgtl5000_set_bias_level(codec, SND_SOC_BIAS_STANDBY);
        /* Restore registers by cached in memory */
        sgtl5000_restore_regs(codec);
        return 0;
#else
#define sgtl5000_suspend NULL
#define sgtl5000_resume  NULL
#endif        /* CONFIG_SUSPEND */
* sgtl5000 has 3 internal power supplies:
* 1. VAG, normally set to vdda/2
* 2. chargepump, set to different value
*        according to voltage of vdda and vddio
* 3. line out VAG, normally set to vddio/2
* and should be set according to:
* 1. vddd provided by external or not
* 2. vdda and vddio voltage value. > 3.1v or not
* 3. chip revision >=0x11 or not. If >=0x11, not use external vddd.
static int sgtl5000_set_power_regs(struct snd_soc_codec *codec)
        int vddd;
        int vdda;
        int vddio;
        u16 ana_pwr;
        u16 lreg_ctrl;
        int vag;
        vdda  = regulator_get_voltage(sgtl5000->supplies[VDDA].consumer);
        vddio = regulator_get_voltage(sgtl5000->supplies[VDDIO].consumer);
        vddd  = regulator_get_voltage(sgtl5000->supplies[VDDD].consumer);
        vdda  = vdda / 1000;
        vddio = vddio / 1000;
        vddd  = vddd / 1000;
        if (vdda <= 0 || vddio <= 0 || vddd < 0) {
                dev_err(codec->dev, "regulator voltage not set correctly\n");
                return -EINVAL;
        /* according to datasheet, maximum voltage of supplies */
        if (vdda > 3600 || vddio > 3600 || vddd > 1980) {
                dev_err(codec->dev,
                        "exceed max voltage vdda %dmV vddio %dmV vddd %dmV\n",
                        vdda, vddio, vddd);
                return -EINVAL;
        /* reset value */
        ana_pwr = snd_soc_read(codec, SGTL5000_CHIP_ANA_POWER);
        ana_pwr |= SGTL5000_DAC_STEREO |
                        SGTL5000_ADC_STEREO |
                        SGTL5000_REFTOP_POWERUP;
        lreg_ctrl = snd_soc_read(codec, SGTL5000_CHIP_LINREG_CTRL);
        if (vddio < 3100 && vdda < 3100) {
                /* enable internal oscillator used for charge pump */
                snd_soc_update_bits(codec, SGTL5000_CHIP_CLK_TOP_CTRL,
                                        SGTL5000_INT_OSC_EN,
                                        SGTL5000_INT_OSC_EN);
                /* Enable VDDC charge pump */
                ana_pwr |= SGTL5000_VDDC_CHRGPMP_POWERUP;
        } else if (vddio >= 3100 && vdda >= 3100) {
                ana_pwr &= ~SGTL5000_VDDC_CHRGPMP_POWERUP;
                /* VDDC use VDDIO rail */
                lreg_ctrl |= SGTL5000_VDDC_ASSN_OVRD;
                lreg_ctrl |= SGTL5000_VDDC_MAN_ASSN_VDDIO <<
                            SGTL5000_VDDC_MAN_ASSN_SHIFT;
        snd_soc_write(codec, SGTL5000_CHIP_LINREG_CTRL, lreg_ctrl);
        snd_soc_write(codec, SGTL5000_CHIP_ANA_POWER, ana_pwr);
                                SGTL5000_LINREG_VDDD_MASK, 0x8);
         * if vddd linear reg has been enabled,
         * simple digital supply should be clear to get
         * proper VDDD voltage.
        if (ana_pwr & SGTL5000_LINEREG_D_POWERUP)
                                0);
        else
                                SGTL5000_LINREG_SIMPLE_POWERUP |
                                SGTL5000_STARTUP_POWERUP,
                                0);
         * set ADC/DAC VAG to vdda / 2,
         * should stay in range (0.8v, 1.575v)
        vag = vdda / 2;
        if (vag <= SGTL5000_ANA_GND_BASE)
                vag = 0;
        else if (vag >= SGTL5000_ANA_GND_BASE + SGTL5000_ANA_GND_STP *
                 (SGTL5000_ANA_GND_MASK >> SGTL5000_ANA_GND_SHIFT))
                vag = SGTL5000_ANA_GND_MASK >> SGTL5000_ANA_GND_SHIFT;
        else
                vag = (vag - SGTL5000_ANA_GND_BASE) / SGTL5000_ANA_GND_STP;
        snd_soc_update_bits(codec, SGTL5000_CHIP_REF_CTRL,
                        SGTL5000_ANA_GND_MASK, vag << SGTL5000_ANA_GND_SHIFT);
        /* set line out VAG to vddio / 2, in range (0.8v, 1.675v) */
        vag = vddio / 2;
        if (vag <= SGTL5000_LINE_OUT_GND_BASE)
                vag = 0;
        else if (vag >= SGTL5000_LINE_OUT_GND_BASE +
                SGTL5000_LINE_OUT_GND_STP * SGTL5000_LINE_OUT_GND_MAX)
                vag = SGTL5000_LINE_OUT_GND_MAX;
        else
                vag = (vag - SGTL5000_LINE_OUT_GND_BASE) /
                    SGTL5000_LINE_OUT_GND_STP;
        snd_soc_update_bits(codec, SGTL5000_CHIP_LINE_OUT_CTRL,
                        SGTL5000_LINE_OUT_CURRENT_MASK |
                        SGTL5000_LINE_OUT_GND_MASK,
                        vag << SGTL5000_LINE_OUT_GND_SHIFT |
                        SGTL5000_LINE_OUT_CURRENT_360u <<
                                SGTL5000_LINE_OUT_CURRENT_SHIFT);
        return 0;
static int sgtl5000_replace_vddd_with_ldo(struct snd_soc_codec *codec)
        int ret;
        /* set internal ldo to 1.2v */
        ret = ldo_regulator_register(codec, &ldo_init_data, LDO_VOLTAGE);
        if (ret) {
                dev_err(codec->dev,
                        "Failed to register vddd internal supplies: %d\n", ret);
                return ret;
        sgtl5000->supplies[VDDD].supply = LDO_CONSUMER_NAME;
        ret = regulator_bulk_get(codec->dev, ARRAY_SIZE(sgtl5000->supplies),
        if (ret) {
                ldo_regulator_remove(codec);
                dev_err(codec->dev, "Failed to request supplies: %d\n", ret);
                return ret;
        dev_info(codec->dev, "Using internal LDO instead of VDDD\n");
        return 0;
static int sgtl5000_enable_regulators(struct snd_soc_codec *codec)
        u16 reg;
        int ret;
        int rev;
        int i;
        int external_vddd = 0;
        for (i = 0; i < ARRAY_SIZE(sgtl5000->supplies); i++)
                sgtl5000->supplies.supply = supply_names;
        if (!ret)
                external_vddd = 1;
        else {
                ret = sgtl5000_replace_vddd_with_ldo(codec);
                if (ret)
                        return ret;
        ret = regulator_bulk_enable(ARRAY_SIZE(sgtl5000->supplies),
        if (ret)
                goto err_regulator_free;
        /* wait for all power rails bring up */
        udelay(10);
        /* Need 8 clocks before I2C accesses */
        udelay(1);
        /* read chip information */
        reg = snd_soc_read(codec, SGTL5000_CHIP_ID);
        if (((reg & SGTL5000_PARTID_MASK) >> SGTL5000_PARTID_SHIFT) !=
            SGTL5000_PARTID_PART_ID) {
                dev_err(codec->dev,
                        "Device with ID register %x is not a sgtl5000\n", reg);
                ret = -ENODEV;
                goto err_regulator_disable;
        rev = (reg & SGTL5000_REVID_MASK) >> SGTL5000_REVID_SHIFT;
        dev_info(codec->dev, "sgtl5000 revision 0x%x\n", rev);
         * workaround for revision 0x11 and later,
         * roll back to use internal LDO
        if (external_vddd && rev >= 0x11) {
                /* disable all regulator first */
                /* free VDDD regulator */
                regulator_bulk_free(ARRAY_SIZE(sgtl5000->supplies),
                if (ret)
                        return ret;
                if (ret)
                udelay(10);
        return 0;
err_regulator_disable:
err_regulator_free:
        if (external_vddd)
        return ret;
static int sgtl5000_probe(struct snd_soc_codec *codec)
        int ret;
        /* setup i2c data ops */
        ret = snd_soc_codec_set_cache_io(codec, 16, 16, SND_SOC_I2C);
        if (ret < 0) {
                dev_err(codec->dev, "Failed to set cache I/O: %d\n", ret);
                return ret;
        ret = sgtl5000_enable_regulators(codec);
        if (ret)
                return ret;
        /* power up sgtl5000 */
        ret = sgtl5000_set_power_regs(codec);
        if (ret)
                goto err;
        /* enable small pop, introduce 400ms delay in turning off */
                                SGTL5000_SMALL_POP, 1);
        /* disable short cut detector */
        snd_soc_write(codec, SGTL5000_CHIP_SHORT_CTRL, 0);
         * set i2s as default input of sound switch
         * TODO: add sound switch to control and dapm widge.
        snd_soc_write(codec, SGTL5000_CHIP_SSS_CTRL,
                        SGTL5000_DAC_SEL_I2S_IN << SGTL5000_DAC_SEL_SHIFT);
        snd_soc_write(codec, SGTL5000_CHIP_DIG_POWER,
                        SGTL5000_ADC_EN | SGTL5000_DAC_EN);
        /* enable dac volume ramp by default */
        snd_soc_write(codec, SGTL5000_CHIP_ADCDAC_CTRL,
                        SGTL5000_DAC_VOL_RAMP_EN |
                        SGTL5000_DAC_MUTE_RIGHT |
                        SGTL5000_DAC_MUTE_LEFT);
        snd_soc_write(codec, SGTL5000_CHIP_PAD_STRENGTH, 0x015f);
        snd_soc_write(codec, SGTL5000_CHIP_ANA_CTRL,
                        SGTL5000_HP_ZCD_EN |
                        SGTL5000_ADC_ZCD_EN);
        snd_soc_write(codec, SGTL5000_CHIP_MIC_CTRL, 2);
         * disable DAP
         * TODO:
         * Enable DAP in kcontrol and dapm.
        snd_soc_write(codec, SGTL5000_DAP_CTRL, 0);
        /* leading to standby state */
        ret = sgtl5000_set_bias_level(codec, SND_SOC_BIAS_STANDBY);
        if (ret)
                goto err;
        return 0;
err:
        return ret;
static int sgtl5000_remove(struct snd_soc_codec *codec)
        return 0;
static struct snd_soc_codec_driver sgtl5000_driver = {
        .probe = sgtl5000_probe,
        .remove = sgtl5000_remove,
        .suspend = sgtl5000_suspend,
        .resume = sgtl5000_resume,
        .set_bias_level = sgtl5000_set_bias_level,
        .reg_cache_size = ARRAY_SIZE(sgtl5000_regs),
        .reg_word_size = sizeof(u16),
        .reg_cache_step = 2,
        .reg_cache_default = sgtl5000_regs,
        .volatile_register = sgtl5000_volatile_register,
        .controls = sgtl5000_snd_controls,
        .num_controls = ARRAY_SIZE(sgtl5000_snd_controls),
        .dapm_widgets = sgtl5000_dapm_widgets,
        .num_dapm_widgets = ARRAY_SIZE(sgtl5000_dapm_widgets),
        .dapm_routes = sgtl5000_dapm_routes,
        .num_dapm_routes = ARRAY_SIZE(sgtl5000_dapm_routes),
static int sgtl5000_i2c_probe(struct i2c_client *client,
                              const struct i2c_device_id *id)
        struct sgtl5000_priv *sgtl5000;
        int ret;
        sgtl5000 = devm_kzalloc(&client->dev, sizeof(struct sgtl5000_priv),
        GFP_KERNEL);
        if (!sgtl5000)
                return -ENOMEM;
        i2c_set_clientdata(client, sgtl5000);
        printk("start codec register in %s\n", __FUNCTION__);
        ret = snd_soc_register_codec(&client->dev,
                        &sgtl5000_driver, &sgtl5000_dai, 1);
        return ret;
static int sgtl5000_i2c_remove(struct i2c_client *client)
        snd_soc_unregister_codec(&client->dev);
        return 0;
static const struct i2c_device_id sgtl5000_id[] = {
        {"sgtl5000", 0},
MODULE_DEVICE_TABLE(i2c, sgtl5000_id);
static const struct of_device_id sgtl5000_dt_ids[] = {
        { .compatible = "sgtl5000", },
        { /* sentinel */ }
MODULE_DEVICE_TABLE(of, sgtl5000_dt_ids);
static struct i2c_driver sgtl5000_i2c_driver = {
        .driver = {
                   .name = "sgtl5000",
                   .owner = THIS_MODULE,
                   .of_match_table = sgtl5000_dt_ids,
        .probe = sgtl5000_i2c_probe,
        .remove = sgtl5000_i2c_remove,
        .id_table = sgtl5000_id,
module_i2c_driver(sgtl5000_i2c_driver);
MODULE_DESCRIPTION("Freescale SGTL5000 ALSA SoC Codec Driver");
MODULE_AUTHOR("Zeng Zhaoming <zengzm.kernel@gmail.com>");
MODULE_LICENSE("GPL");
 楼主| Lbb121358 发表于 2019-9-23 23:07 | 显示全部楼层
刚刚大致翻了翻
你这个文件里:
大神,还得请教您一下,我在NUC972和A335x上飞线,可以检测到A335x上的SGTL5000,只有一个条件就是必须A335x系统起来,之前的消息是 两个内核中sgtl5000.c的不同
 楼主| Lbb121358 发表于 2019-9-23 23:12 | 显示全部楼层
刚刚大致翻了翻
你这个文件里:
大神,还得请教您一个问题,我将NUC972与A335X(能够正常通信,sgtl5000正常运行),NUC972能够检测到sgtl5000(A335x上的),前提是A335x系统必须起来,单纯供电不可以,最后我发现 两个内核中的 sgtl5000.c 文件不同,之前标红的就是主要的不同。您看这是主要原因吗?
 楼主| Lbb121358 发表于 2019-9-23 23:13 | 显示全部楼层
s2333 发表于 2019-9-17 22:32
这里的nuc970-i2c0 nuc970-i2c0: cannot get bus (error -110)提示,对i2c总线上的设备进行访问时,超时了 ...
s2333 发表于 2019-9-24 19:38 | 显示全部楼层
大神,还得请教您一个问题,我将NUC972与A335X(能够正常通信,sgtl5000正常运行),NUC972能够检测到sgtl5 ...
按你说的,在NUC972与A335X飞线,A335X系统不起来,你就单纯运行NUC972的时候,量一下stgl5000的VDDD脚电压,这里好像要1.1V-2.0V才能启动stgl5000
然后你正常运行的时候也测试一下看看电压,对比一下
代码不同是不同的人有不同的封装风格,这个不太好说
只能建议你多看回溯的提示,错误提示有时候会给你很重要的提示
 楼主| Lbb121358 发表于 2019-9-24 21:42 | 显示全部楼层
按你说的,在NUC972与A335X飞线,A335X系统不起来,你就单纯运行NUC972的时候,量一下stgl5000的VDDD脚电 ...
这是一块NUC970的打印信息
我是菜鸟
[    1.820000] codec register snd-soc-dummy
[    1.840000] xuᅠ쀠k
                     u@u￀[    1.870000] hub 1-2:1.0: USB hub found
[    1.900000] hub 1-2:1.0: 4 ports detected
start codec register in sgtl5000_i2c_probe
[    1.940000] codec register 0-000a
[    1.940000] `ꂠ.À᭲Ì£hꂀ@u@隂
[    2.040000] sgtl5000 0-000a: Device with ID register ffff is not a sgtl5000
[    2.050000] sgtl5000 0-000a: ASoC: failed to probe CODEC -19
[    2.050000] nuc970-audio nuc970-audio: ASoC: failed to instantiate card -19
[    2.070000] nuc970-audio nuc970-audio: snd_soc_register_card() failed: -19
 楼主| Lbb121358 发表于 2019-9-24 21:44 | 显示全部楼层
就是想和您学习下,刚入门,怎莫分析
zhuotuzi 发表于 2019-9-24 21:50 | 显示全部楼层
期待大佬继续讨论,我围观学习。
s2333 发表于 2019-9-25 16:41 | 显示全部楼层
这个是对应nuc970-audio.c文件中的static int nuc970_audio_probe(struct platform_device *pdev)函数,
snd_soc_register_card() failed: -19这个提示就是来自这个函数的:dev_err(&pdev->dev, "snd_soc_register_card() failed: %d\n",ret);
然后看这个函数中的第一句struct snd_soc_card *card = &nuc970evb_audio_machine;
nuc970evb_audio_machine结构中的.dai_link对应的结构体,默认是nuc970evb_i2s_dai,应该是被你改掉了,看你前面好像是改成stgl5000什么的了,你自己改一下对应起来
 楼主| Lbb121358 发表于 2019-9-27 18:11 | 显示全部楼层
[    2.070000] nuc970 ...
这里写的是这样
static struct snd_soc_dai_link nuc970evb_i2s_dai = {
                .name       = "IIS",
                .stream_name    = "IIS HiFi",
                .cpu_dai_name   = "nuc970-audio-i2s",
                .codec_dai_name = "sgtl5000",
                .ops        = &nuc970_audio_ops,
                .platform_name = "nuc970-audio-pcm.0",
static struct snd_soc_card nuc970evb_audio_machine = {
                .name       = "nuc970_IIS",
                .dai_link   = &nuc970evb_i2s_dai,
                .num_links  = 1,
 楼主| Lbb121358 发表于 2019-9-27 20:06 | 显示全部楼层
期待大佬继续讨论,我围观学习。
大神
比特牛1118 发表于 2020-6-5 16:37 | 显示全部楼层
主要在怎么修改?
您好,是怎么解决的?
