[DemoCode下载]
ML51串口2的普通用法
505|4
598330983|  楼主 | 2019-9-29 23:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved.                                         */
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  File Function: ML51 simple GPIO toggle out demo code
#include "ML51.h"
* [url=home.php?mod=space&uid=247401]@brief[/url]       UART2 TXD output demo
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     conned UART2 and UART0 to loop check.
void main (void)
#if 0  /* UART2*/
    unsigned char temp=0x30;
     MFP_P21_UART2_TXD;
    P21_QUASI_MODE;
    UART_Open(24000000,UART2,115200);                /* Open UART2 use timer1 as baudrate generate and baud rate = 115200*/
     MFP_P30_UART0_RXD;
    P30_QUASI_MODE;
    UART_Open(24000000,UART0_Timer1,115200);        /* Open UART0 use timer1 as baudrate generate and baud rate = 115200 */
    while(1)
      UART_Send_Data(UART2,temp);
      temp = UAR67T_Receive_Data(UART0);              /* connect P5.4 and P3.0 to check receive data from UART0. */
      temp++;                                       /* loop out ascii code. */
      Timer3_Delay(24000000,128,500,1000);
#endif
#if 1
    /* UART2 lower power run mode*/
        unsigned char temp=0x50;
     MFP_P21_UART2_TXD;
    P21_QUASI_MODE;
          set_SC0CR0_SCEN;         /* Enable SC module */
          set_SC0CR1_UARTEN;       /* set as UART mode */
          set_SC0CR1_CLKKEEP;
          clr_SC0CR0_CONSEL;       /* clr CONSEL and AUTOCEN*/
          clr_SC0CR0_AUTOCEN;
          SC0ETURD0 = 0x07;        /* define baud rate low byte */
          SC0ETURD1 = 0x00;        /* define baud rate high byte */
          set_SC0CR1_PBOFF;     //parity bit disable
          SC0CR1&=0XCF;        //datalegth 8bit
          set_SC0CR0_NSB;      //stop bit = 1bit
//    SFRS =1;
//    TA=0xAA;
//    TA=0x55;
//    LVRDIS = 0x5A;
//    TA=0xAA;
//    TA=0x55;
//    LVRDIS = 0xA5;
//    TA=0xAA;
//    TA=0x55;
//    PORDIS = 0x5A;
//    TA=0xAA;
//    TA=0x55;
//    PORDIS = 0xA5;
    FsysSelect(FSYS_LIRC);
    set_PCON_LPR;
    while(1)
//      Timer0_Delay(38400,1,1000);
#endif
598330983|  楼主 | 2019-9-29 23:35 | 只看该作者
这个例子是串口0接收,串口2发送的例子,仔细读读,会发现新唐的例子非常容易上手,然后用于自己的项目。
zhuotuzi| | 2019-10-8 00:05 | 只看该作者
发送和接收用了两个不同的串口。
xinpian101| | 2019-10-8 20:40 | 只看该作者
MFP_P21_UART2_TXD;
类似这种我去哪儿看
xinpian101| | 2019-10-8 21:07 | 只看该作者
使用库函数的延时比较准确,串口的配置使用例子的方法就行。
