[DemoCode下载]
ML51的外部中断
362|5
598330983|  楼主 | 2019-9-29 23:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved.                                         */
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
#include "ML51.h"
* [url=home.php?mod=space&uid=247401]@brief[/url]              External pin interrupt INT1 demo
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     None
void INT1_ISR(void) interrupt 2          // Vector [url=home.php?mod=space&uid=72445]@[/url]  0x13
/* Clear INT1 interrupt flag */
    clr_TCON_IE1;
/* check tiny board LEDG1 to confirm into interrupt */
                P31 = ~P31;
void main (void)
                MFP_P31_GPIO;
                P31_PUSHPULL_MODE;
/* Define P24 multi-function pin as External pin interrupt INT1 source*/
                MFP_P24_INT1;
                P24_INPUT_MODE;
/* Enable P2.4 internal pull high to wait falling edge*/
                GPIO_Pull_Enable(Port2,SET_BIT4,PullUp);
/* Include exint.c in library */
                ExternPinInterrupt_Enable(INT1,Edge,Enable);
/* Include sys.c */
                ENABLE_GLOBAL_INTERRUPT;
                while(1);
#include "ML51.h"
* @brief              External pin interrupt INT0 demo
* @param       None
* @return      None
* @details     None
void INT0_ISR(void) interrupt 0          // Vector @  0x03
/* Clear INT0 interrupt flag */
                clr_TCON_IE0;
                printf ("\n INT0 interrupt");
void main (void)
                MFP_P31_UART0_TXD;
                P31_QUASI_MODE;
                UART_Open(24000000,UART0_Timer1,115200);
                ENABLE_UART0_PRINTF;
/* Define P25 multi-function pin as External pin interrupt INT0 source*/
                MFP_P25_INT0;
                P25_INPUT_MODE;
/* Enable internal pull up function to wait falling edge*/
                GPIO_Pull_Enable(Port2,SET_BIT5,PullUp);
                ExternPinInterrupt_Enable(INT0,Edge,Enable);
                while(1);
这个例子还展示了如何用printf函数。
yiy| | 2019-9-30 16:10 | 只看该作者
非常给力,这价格比传统51便宜多了,主要提供库函数,51内核里单片机好像只有新唐做到了
heisexingqisi| | 2019-9-30 20:20 | 只看该作者
其实这个作为农场监控也不错啊,低功耗。
wanduzi| | 2019-10-9 21:24 | 只看该作者
interrupt 2
这个从哪儿看
