[DemoCode下载]
关闭看门狗复位功能
619|2
jiekou001|  楼主 | 2019-9-29 23:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如果想使用看门狗作为一个定时器,而不让看门狗定时器复位咋办
/* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2016
//  File Function: N76E003 Watch Dog reste functiondemo code
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#define     CFG_READ            0xC0
#define     CFG_ERASE           0xE2
#define     CFG_BYTE_PROGRAM    0xE1
        WDT CONFIG enable
        warning : this macro is only when ICP not enable CONFIG WDT function
        copy this marco code to you code to enable WDT reset.
void Enable_WDT_Reset_Config(void)
          set_IAPEN;
    IAPAL = 0x04;
    IAPAH = 0x00;
    IAPFD = 0x0F;
    IAPCN = CFG_BYTE_PROGRAM;
    set_CFUEN;
    set_IAPGO;                                  //trigger IAP
                while((CHPCON&SET_BIT6)==SET_BIT6);          //check IAPFF (CHPCON.6)
    clr_CFUEN;
    clr_IAPEN;
        WDT CONFIG disable
        warning : this macro is for CONFIG already enable WDT Reset to disable.
        Since erase CONFIG is full page
        step 1. storage CONFIG value in RAM
        step 2. modify RAM CONFIG4 WDT value to disable
        step 3. erase CONFIG page
        step 4. re writer CONFIG.
void Disable_WDT_Reset_Config(void)
        UINT8 cf0,cf1,cf2,cf3,cf4;
          set_IAPEN;
    IAPAL = 0x00;
    IAPAH = 0x00;
    IAPCN = CFG_READ;
    set_IAPGO;                                  //Storage CONFIG0 data
                cf0 = IAPFD;
                IAPAL = 0x01;
                set_IAPGO;                                  //Storage CONFIG1 data
                cf1 = IAPFD;
                IAPAL = 0x02;
          set_IAPGO;                                  //Storage CONFIG2 data
                cf2 = IAPFD;
                IAPAL = 0x03;
          set_IAPGO;                                  //Storage CONFIG3 data
                cf3 = IAPFD;
                IAPAL = 0x04;
          set_IAPGO;                                  //Storage CONFIG4 data
                cf4 = IAPFD;
                cf4 |= 0xF0;        //Moidfy Storage CONFIG4 data disable WDT reset
                set_CFUEN;
                IAPCN = CFG_ERASE;        //Erase CONFIG all
                IAPAH = 0x00;
                IAPAL = 0x00;
                IAPFD = 0xFF;
                set_IAPGO;
                IAPCN = CFG_BYTE_PROGRAM;        //Write CONFIG
                IAPFD = cf0;
                set_IAPGO;
                IAPAL = 0x01;
                IAPFD = cf1;
                set_IAPGO;
                IAPAL = 0x02;
                IAPFD = cf2;
                set_IAPGO;
                IAPAL = 0x03;
                IAPFD = cf3;
                set_IAPGO;
                IAPAL = 0x04;
                IAPFD = cf4;
                set_IAPGO;
    clr_CFUEN;
    clr_IAPEN;
*    Main function
void main (void)
  Set_All_GPIO_Quasi_Mode;
        clr_GPIO1;
        Timer0_Delay1ms(50);                                        //toggle I/O to show MCU Reset
        set_GPIO1;
        clr_GPIO1;
        set_GPIO1;
// WDT Init !!! ENABLE CONFIG WDT FIRST !!!
// Warning:
// Always check CONFIG WDT enable first, CONFIG not enable, SFR can't enable WDT reset
// Please call Enable_WDT_Reset_Config() function to enable CONFIG WDT reset
//        Enable_WDT_Reset_Config();                                                        //Software enable WDT reset CONFIG setting
          TA=0xAA;TA=0x55;WDCON|=0x07;                                                //Setting WDT prescale
                set_WDCLR;        //Clear WDT timer
                while((WDCON|~SET_BIT6)==0xFF);                                        //confirm WDT clear is ok before into power down mode
//                EA = 1;
                set_WDTR;        //WDT run
                Disable_WDT_Reset_Config();                                                //Software disable WDT reset CONFIG setting
    while (1)
                        clr_GPIO1;
                        Timer0_Delay1ms(100);
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_PD;
设计人员已经考虑这个情况了,所以例子也提供了,非常方便。
