[DemoCode下载]
串口唤醒M051
395|14
xixi2017|  楼主 | 2019-10-16 22:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
有人问,串口中断需要清理标志位吗?
这里找个例子给大家看看
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 3 $
* $Date: 15/08/07 1:31p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Show how to wake up system form Power-down mode by UART interrupt.
* @note
* Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLL_CLOCK   50000000
/* Define functions prototype        */
int32_t main(void);
void UART_CTSWakeUpTest(void);
/* ISR to handle UART Channel 1 interrupt event                                                            */
void UART1_IRQHandler(void)
    if(UART_GET_INT_FLAG(UART1, UART_ISR_MODEM_INT_Msk))    /* UART Modem Status interrupt flag */
        printf("UART Modem Status interrupt happen.");
        UART_ClearIntFlag(UART1, UART_ISR_MODEM_INT_Msk);   /* Clear UART Modem Status interrupt flag */
/*  Function for System Entry to Power Down Mode                                                           */
void PowerDownFunction(void)
    /* Check if all the debug messages are finished */
    UART_WAIT_TX_EMPTY(UART0);
    /* Enter to Power-down mode */
    CLK_PowerDown();
/*  UART nCTS Wake-up Function        */
    printf("+----------------------------------------------------------+\n");
    printf("|   Power-Down and Wake-up by UART interrupt Sample Code   |\n");
    printf("+----------------------------------------------------------+\n\n");
    /* Clear Modem Status interrupt before entering Power-down mode */
    /* Enable UART Wake-up function and Modem Status interrupt */
    UART_EnableInt(UART1, UART_IER_WAKE_EN_Msk|UART_IER_MODEM_IEN_Msk);
    printf("System enter to Power-down mode.\n");
    printf("Toggle nCTS of UART1 to wake-up system.\n\n");
    /* Unlock protected registers before entering Power-down mode */
    SYS_UnlockReg();
    PowerDownFunction();
    /* Lock protected registers after entering Power-down mode */
    SYS_LockReg();
    /* Disable UART Wake-up function and Modem Status interrupt */
    UART_DisableInt(UART1, UART_IER_WAKE_EN_Msk|UART_IER_MODEM_IEN_Msk);
    printf("\nSystem waken-up done.\n");
    printf("\nUART Sample Program End.\n");
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(UART1_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    CLK_SetModuleClock(UART1_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
    /* Set P1 multi-function pins for UART1 RXD and TXD */
    SYS->P1_MFP &= ~(SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
    SYS->P1_MFP |= (SYS_MFP_P12_RXD1 | SYS_MFP_P13_TXD1);
    /* Set P0 multi-function pins for UART1 CTS */
    SYS->P0_MFP = SYS->P0_MFP & (~SYS_MFP_P00_Msk) | SYS_MFP_P00_CTS1;
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
void UART1_Init()
    /* Init UART        */
    /* Reset UART1 */
    SYS_ResetModule(UART1_RST);
    /* Configure UART1 and set UART1 Baudrate */
    UART_Open(UART1, 115200);
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init UART0 for testing */
    UART1_Init();
    /* SAMPLE CODE        */
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("\n\nUART Sample Program.\n");
    /* UART wake-up sample function */
    UART_CTSWakeUpTest();
    while(1);
xixi2017|  楼主 | 2019-10-16 22:03 | 只看该作者
显然有这个函数,说明可能需要,但是这个是进入中断前做的清场操作。
然后找到这个中断函数,发现需要自己清理,没毛病,记住了。
zhuomuniao110| | 2019-10-16 22:32 | 只看该作者
总结的很好,原来提供了函数操作了,方便。
不用再死记那些寄存器了。
zhuomuniao110| | 2019-10-16 23:17 | 只看该作者
看是不是函数里面帮忙实现了,一般是需要自己做的。
幸福小强| | 2019-10-16 23:26 | 只看该作者
结合例子学习特别快。
jiekou001| | 2019-10-20 23:57 | 只看该作者
呵呵,如果能收到数据唤醒就好了。
zhuotuzi| | 2019-10-21 23:59 | 只看该作者
这个功能很重要,低功耗很需要这个
wowu| | 2019-11-19 12:38 | 只看该作者
非常感谢楼主分享
wakayi| | 2019-11-19 12:43 | 只看该作者
非常感谢楼主分享
renzheshengui| | 2019-11-19 12:46 | 只看该作者
非常感谢楼主分享
paotangsan| | 2019-11-19 12:50 | 只看该作者
非常感谢楼主分享
