请教关于STM32F4的浮点单元问题
10738|13
 楼主| sonicll 发表于 2011-11-24 13:30 | 显示全部楼层 |阅读模式
使用环境为 STM32F4DISCOVERY + MDK4.22
因为看到MDK的options for target选项里,可以选择使用或不使用FPU,想看看使用FPU和不使用FPU在浮点计算上有多大差距,就写了个简单的程序,加减乘除计算,看看每秒钟能计算多少次,把次数和计算结果从串口输出来,代码如下
#include "stm32f4xx.h"
#include <stdio.h>
#include <string.h>
void InitTIM(void);
void InitUart(void);
void UartSendStr(char buf[],int length);
char TIM2_Flag = 0;
int main(void)
        unsigned long count = 0;
        float i = 0;
float j = 0.134245223423424556;
float k = 0.253252534536366666;
        char buffer[128];
        SystemInit();
        InitTIM();
        InitUart();
        while(1)
                i = (j+5123)*821/(k-456);
                count++;
                if (TIM2_Flag) //TIM2的中断处理函数里把TIM2_Flag置1,周期1秒
                        TIM2_Flag = 0;
                        sprintf(buffer, "%d,%f\n",count,i);
                        UartSendStr(buffer,strlen(buffer));
                        count = 0;
        int i;
        for(i=0;i<length;i++)
                USART_SendData(USART3, buf);
                while (USART_GetFlagStatus(USART3, USART_FLAG_TC) == RESET);
void InitUart(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        USART_InitTypeDef USART_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_8 | GPIO_Pin_9;
        GPIO_Init(GPIOD, &GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_USART3);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_USART3);
        USART_InitStructure.USART_BaudRate = 115200;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        USART_Init(USART3, &USART_InitStructure);
        USART_Cmd(USART3, ENABLE);
void InitTIM(void)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
        NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        TIM_TimeBaseStructure.TIM_Period = 41999;
        TIM_TimeBaseStructure.TIM_Prescaler = 1999;
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Down;
        TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
        TIM_Cmd(TIM2, ENABLE);
        TIM_PrescalerConfig(TIM2, TIM_TimeBaseStructure.TIM_Prescaler, TIM_PSCReloadMode_Immediate);
        TIM_ClearFlag(TIM2, TIM_FLAG_Update);
        TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
MDK的选项里,target选项卡里只选择是否使用FPU,其他选项不选;C/C++选项卡里,优化等级选为0,其他选项都不选
观察结果为:
使用FPU,count为4657245
不使用FPU,count为916266
区别还是比较明显;
接下来是问题,当我把i、j、k三个变量的类型设成double后,结果变成了这样:
使用FPU,count为284680
不使用FPU,count为530620
我知道F4的FPU是单精度的,但是也不应该出现double类型使用FPU,速度反而下降的现象啊,请大家帮忙看看,是程序问题还是MDK有什么设置不对,工程在附件里
STM32F4_project_demo_20111124.rar
308.01 KB, 下载次数: 258
liujl 发表于 2011-11-24 16:40 | 显示全部楼层
友情顶一下,F4的帖子真少
grissiom 发表于 2011-11-24 17:13 | 显示全部楼层
看汇编代码,调优化选项
香水城 发表于 2011-11-24 21:39 | 显示全部楼层
LZ看错了吧?
 楼主| sonicll 发表于 2011-11-25 08:59 | 显示全部楼层
回香主,我确认没看错,那3个变量设成float没有问题,设成double就是开启FPU速度慢,开发板用的STM32F4DISCOVERY
香水城 发表于 2011-11-25 09:43 | 显示全部楼层
也许要看看编译出来的代码,才能知道是怎么回事。
如果有人能问问KEIL,可以得到更准确地答复。
lianshumou 发表于 2011-11-25 10:41 | 显示全部楼层
使用FPU后居然只有5倍的性能提升,这是不可能的。我就算全用定点,如果用我用汇编写的浮点算法都比标准库快5倍以上。
 楼主| sonicll 发表于 2011-11-25 11:04 | 显示全部楼层
回7楼,这个程序只是个粗略的比较,串口发送也要占用不少时间的,而且没有任何编译优化
IJK 发表于 2011-11-25 11:40 | 显示全部楼层
串口发送应该占不了多少时间,因为1秒才发送1次。
编译优化的影响应该比较大
grissiom 发表于 2011-11-25 11:41 | 显示全部楼层
问题就在于,人家用的不是定点,而是浮点……
grissiom 发表于 2011-11-25 11:43 | 显示全部楼层
我觉得 LZ 可以看看生成的汇编代码,看看 double 类型的有没有用到 FPU ……
pluto55 发表于 2013-1-11 15:41 | 显示全部楼层
stm32F4是单精度的,有double类型的数据的话就会调用math.h中的库函数来执行了,根本没有用FPU指令,所以变慢了,看一下汇编代码就知道了
smartmcu 发表于 2013-1-25 21:43 | 显示全部楼层
这里的关键是 “不使用FPU” 的设置上。虽然在选项里设置了,但在相应的.h文件里有可能有
#define __FPU_PRESENT             1
这样的语句。
这样,表面上是关了fpu,但其实float还是用了fpu的。也只有这个原因,才是合乎逻辑的解释,否则就太神秘了!:lol
wwwq 发表于 2013-2-5 18:10 | 显示全部楼层
这个问题其实就是double引起的,单精度的float采用FPU,而double则使用了库函数,速度自然慢多了
