是不是没有响应中断啊?
313|8
chuxh|  楼主 | 2019-12-1 15:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用定时器Terminalcountout中断控制  一个发光二极管每一秒钟闪烁一次,但是程序下进后二极管一直亮着,是不是没有响应中断啊?
houcs| | 2019-12-1 15:58 | 只看该作者
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
chuxh|  楼主 | 2019-12-1 16:02 | 只看该作者
#include <m8c.h>        // part specific constants and macros
#include "PSoCAPI.h"    // PSoC API definitions for all User Modules
#pragma interrupt_handler Timer8_ISR_C
extern void Timer8_EnableInt(void);
extern void Timer8_DisableInt(void);
extern void Timer8_Start(void);
extern void Timer8_Stop(void);
extern BYTE Timer8_bReadTimer(void);
extern BYTE Timer8_bReadTimerSaveCV(void);
extern void Timer8_WritePeriod(BYTE bPeriod);
extern BYTE Timer8_bReadCompareValue(void);
extern void Timer8_WriteCompareValue(BYTE bCompareValue);
void main()
    // Insert your main routine code here.
        //Timer8_WritePeriod(183);
        M8C_EnableGInt;
        Timer8_EnableInt();
        Timer8_Start();
        while(1);
void Timer8_ISR_C()
    PRT0DR^ =0x02;
芯片配置
Global Resources
CPU_Clock =12 MHz
VC1 =16             Divide 24 MHz SysClock by 16.
VC2 =16             Divide VC1 by 16.
VC3 Source =VC2     Set the source for VC3 as VC2.
VC3 Divider =256    Divide VC2 by 256 (to produce a 366 Hz clock)
User Module Parameters
   Timer8_1   Clock =VC3              Input 366 Hz clock from VC3.
   Capture =Low Not used.
   TerminalCountOut =Row_0_Output_0    For routing to Pin2[3].
   CompareOut =None                    Not used.
   Period =182                         Set to 182 and count down.
   Compare Value =0                    Not used.
   Compare Type  =Less Than            Not used.
   Interrupt Type =Terminal Count      To generate interrupt after the down counter reaches 0.
   Clock Sync =Sync                    To SysClk Synchronize to system clock.
   TC_PulseWidth =Full width           Generate a full pulse width at every terminal count. InvertCapture =Normal Not used
yinxiangh| | 2019-12-1 16:05 | 只看该作者
那个中断服务程序的框架在硬件配置好后Designer会自动生成吗?
chuxh|  楼主 | 2019-12-1 16:09 | 只看该作者
我没有看到框架生成,是不是构建Project的时候出了问题才这样的
morrisk| | 2019-12-1 16:14 | 只看该作者
你好歹亮和暗间加个延时啊,不然它闪太快,在你看来就是一直亮了。。。。
stly| | 2019-12-1 16:17 | 只看该作者
PRT0DR^ =0x02;在这句,
xxmmi| | 2019-12-13 18:58 | 只看该作者
或者while里面加个延时咯
chuxh|  楼主 | 2019-12-13 19:11 | 只看该作者
嗯,预料中的结果,先结贴吧,多谢大家啦
