[技术问答]
M051 使用PWM功能一定要开中断写中断服务函数吗?
1943|16
手册里有这么个配置流程
但玩转M0 M4里面就没有配中断
我看到很多其它例程都写了PWM中断函数,到底使用PWM功能要不要开中断呢?
jiekou001| | 2019-12-14 17:25 | 只看该作者
是的
jiekou001| | 2019-12-14 17:28 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 4 $
* $Date: 15/05/22 2:05p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Generate different frequency(Tenor C Do ~ Si) waveform by PWM.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
/* Macro, type and constant definitions        */
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
// Scale frequency and unit is Hz
#define TENOR_C 523
#define TENOR_D 587
#define TENOR_E 659
#define TENOR_F 698
#define TENOR_G 784
#define TENOR_A 880
#define TENOR_B 988
void PWM_PwmIRQHandler(void);
/* Global variables        */
volatile uint8_t g_u8PWMCount = 1;
volatile uint16_t g_u16Frequency;
volatile uint32_t g_u32Pulse = 0;
/* Assume PWM output frequency is 523Hz and duty ratio is 60%, user can calculate PWM settings by follows.
   PWM clock source frequency = __HXT = 12000000 in the sample code.
   (CNR+1) = PWM clock source frequency/prescaler/clock source divider/PWM output frequency
           = 12000000/2/1/523 = 11472 < 65536  (Note: If calculated value is larger than 65536, user should increase prescale value.)
   CNR = 11471 =>g_au16ScaleCnr[0] = 11471
   duty ratio = 60% = (CMR+1)/(CNR+1) ==> CMR = (CNR+1)*60/100-1 = 11472*60/100-1
   CMR = 6882 =>g_au16ScaleCmr[0] = 6882
static const uint16_t g_au16ScaleFreq[7] = {TENOR_C, TENOR_D, TENOR_E, TENOR_F, TENOR_G, TENOR_A, TENOR_B};
// static const uint16_t g_au16ScaleCnr[7] =  {11471,10220,9103,8594,7652,6817,6071};
// static const uint16_t g_au16ScaleCmr[7] =  {6882 ,6131 ,5461,5156,4590,4089,3642};
* @brief       PWMA IRQ Handler
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     ISR to handle PWMA interrupt event
void PWMA_IRQHandler(void)
    uint32_t u32PwmIntFlag;
    /* Handle PWMA Timer function */
    u32PwmIntFlag = PWMA->PIIR;
    /* PWMB channel 0 PWM timer interrupt */
    if(u32PwmIntFlag & PWM_PIIR_PWMIF0_Msk)
        PWMA->PIIR = PWM_PIIR_PWMIF0_Msk;
        PWM_PwmIRQHandler();
/* PWM Timer function        */
    if(g_u32Pulse == 1 * g_u16Frequency / 10)
        /* Stop PWMA channel 0 Timer (Recommended procedure method 2)                           */
        /* Set PWM Timer counter as 0, When interrupt request happen, disable PWM Timer         */
        PWMA->CNR0 = 0;
    if(g_u32Pulse == 1 * g_u16Frequency / 10 + 1)
        g_u8PWMCount = 0;
    g_u32Pulse++;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for IRC22M clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external 12MHz XTAL, internal 22.1184MHz */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC22M_EN_Msk);
    /* Enable PLL and Set PLL frequency */
    CLK_SetCoreClock(PLLCON_SETTING);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_PLL, CLK_CLKDIV_HCLK(2));
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable PWM module clock */
    CLK_EnableModuleClock(PWM01_MODULE);
    CLK_EnableModuleClock(PWM23_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Select PWM module clock source */
    CLK_SetModuleClock(PWM01_MODULE, CLK_CLKSEL1_PWM01_S_HXT, 0);
    CLK_SetModuleClock(PWM23_MODULE, CLK_CLKSEL1_PWM23_S_HXT, 0);
    /* Reset PWMA channel0~channel3 */
    SYS_ResetModule(PWM03_RST);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD  */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Set P4 multi-function pins for PWMA Channel0 */
    SYS->P4_MFP = SYS_MFP_P40_PWM0;
void UART0_Init(void)
    /* Init UART        */
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  Main Function        */
int32_t main(void)
    uint8_t u8Item, u8ItemOK;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("+------------------------------------------------------------------------+\n");
    printf("|                          PWM Driver Sample Code                        |\n");
    printf("|        |\n");
    printf("  This sample code will use PWMA channel 0 to drive Buzzer\n");
    printf("  I/O configuration:\n");
    printf("    PWM0(P4.0 PWMA channel 0) <--> Buzzer\n");
    printf("\nPWM Timer Waveform Test. Waveform output(P4.0 PWMA channel 0) to Buzzer\n");
    /* P4.0 PWMA channel 0 generates PWM frequency Do - Si */
    printf("Select Test Item\n");
    printf(" 1: Do (523Hz)Tenor C\n");
    printf(" 2: Re (587Hz)\n");
    printf(" 3: Mi (659Hz)\n");
    printf(" 4: Fa (698Hz)\n");
    printf(" 5: Sol(784Hz)\n");
    printf(" 6: La (880Hz)\n");
    printf(" 7: Si (988Hz)\n");
    while(1)
        u8ItemOK = 1;
        u8Item = getchar();
        printf("\t");
        switch(u8Item)
        case '1':
        case '2':
        case '3':
        case '4':
        case '5':
        case '6':
        case '7':
            g_u16Frequency = g_au16ScaleFreq[(u8Item - '1')];
            break;
        default:
            u8ItemOK = 0;
            break;
        if(u8ItemOK)
            g_u32Pulse = 0;
            g_u8PWMCount = 1;
               duty ratio = (CMR+1)/(CNR+1)
               cycle time = CNR+1
               High level = CMR+1
               (Note: CNR is 16 bits, so if calculated value is larger than 65536, user should increase prescale value.)
               CNR = 11471
               duty ratio = 60% ==> (CMR+1)/(CNR+1) = 60% ==> CMR = (CNR+1)*0.6-1 = 11472*60/100-1
               CMR = 6882
               Prescale value is 1 : prescaler = 2
               Clock divider is PWM_CSR_DIV1 : clock divider = 1
            /* Enable PWM Output pin */
            PWM_EnableOutput(PWMA, 0x1);
            PWM_ConfigOutputChannel(PWMA, PWM_CH0, g_u16Frequency, 60);
            /* Enable Timer period Interrupt */
            PWM_EnablePeriodInt(PWMA, PWM_CH0, PWM_PERIOD_INT_UNDERFLOW);
            /* Enable PWMB NVIC */
            NVIC_EnableIRQ((IRQn_Type)(PWMA_IRQn));
            /* Enable PWM Timer */
            PWM_Start(PWMA, 0x1);
            while(g_u8PWMCount);
            /* Stop PWM Timer (Recommended procedure method 2)                                      */
            /* Set PWM Timer counter as 0 in Call back function                                     */
            /* Disable PWMB NVIC */
            NVIC_DisableIRQ((IRQn_Type)(PWMA_IRQn));
            /* Wait until PWMB channel 0 Timer Stop */
            while(PWMA->PDR0 != 0);
            /* Disable the PWM Timer */
            PWM_Stop(PWMA, 0x1);
            /* Disable PWM Output pin */
            PWM_DisableOutput(PWMA, 0x1);
jiekou001| | 2019-12-14 17:30 | 只看该作者
当16位向下计数计数器达到0时,中断请求产生。如果PWM定时器被定义为自动装载模式,当向下计数器达到0时,自动重新加载PWM计数寄存器(CNRx)的值,然后开始递减,之后会不断重复进行。如果定时器设为单次触发模式,向下计数器达到0时将停止计数,并产生一个中断请求.
玛尼玛尼哄| | 2019-12-14 20:18 | 只看该作者
试试不添加那个中断能否实现PWM
可能那个中断作用不同吧
玛尼玛尼哄| | 2019-12-14 20:19 | 只看该作者
这个是PWM定时器预分频中断,不是很懂例子表达什么意思。
followme001|  楼主 | 2019-12-15 09:04 | 只看该作者
我的理解是需要改变占空比时才要在中断函数里改变CMR的值,也就是要改变占空比才要用到中断。
followme001|  楼主 | 2019-12-15 09:13 | 只看该作者
另外还有一个问题,按照新唐这种计算占空比的公式,(CMR + 1)/ (CNR + 1),这个PWM发生器永远也无办法输出0% 的占空比。因为最小也是1%。
我在这里想到的办法是,
void set_pwm(unsigned int value)
      if (value == 0)
            //这里有一段代码是切换管脚的模式为GPIO
            P20 = 0;   //当要实现0%占空比时,改为用I/O口操作的方式
    else
            //这里有一段代码是切换管脚的模式为pwm
           PWMA->CMR0 = value;   //当要实现1%~100%的占空比时,改为用PWM的方式。
对于新唐我是小白一个,有经验的前辈分享一下你们的经验
Harvard| | 2019-12-15 22:24 | 只看该作者
不需要.  官方只是告诉你 如果你需要这个中断 可以这样开启
jiekou001| | 2019-12-15 23:16 | 只看该作者
根据楼上意思,不开中断PWM也可以正常工作,给力。
jasontu| | 2019-12-17 07:49 | 只看该作者
把下面2行關閉,即不開啟中斷功能,但pwm還是可以輸出
gejigeji521 2020-2-19 10:35 回复TA
https://bbs.21ic.com/icview-2904748-1-1.html 大佬帮我看看。
13
Harvard| | 2019-12-17 07:53 | 只看该作者
followme001 发表于 2019-12-15 09:13
另外还有一个问题,按照新唐这种计算占空比的公式,(CMR + 1)/ (CNR + 1),这个PWM发生器永远也无办法 ...
是这样处理的 .  不知道大家有没有更好的不办法
jasontu| | 2020-2-20 08:49 | 只看该作者
m051是舊的設計,不能输出0% 的占空比,只能切gpio控制。
後面新的系列pwm可以設成输出0% 的占空比
followme001|  楼主 | 2020-2-27 10:14 | 只看该作者
後面新的系列pwm可以設成输出0% 的占空比 ...
是这样吗,至少我现在用的NUC029LAN还不是。
huahuagg| | 2020-3-6 16:20 | 只看该作者
不需要的。
