[技术问答]
M487的PDMA使用问题
1333|7
秦九音|  楼主 | 2019-12-20 09:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PDMA基础模式
寄存器REQSEL选择PWM或UART
没有请求 还有别的什么寄存器需要配置吗
734774645| | 2019-12-20 10:18 | 只看该作者
这个看库函数有哪些是操作这个的。搞寄存器太难懂。
秦九音|  楼主 | 2019-12-20 14:09 | 只看该作者
或者说 外设是怎么请求的 我读PDMA没有请求
zhuomuniao110| | 2019-12-21 16:04 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 8 $
* $Date: 15/09/02 10:04a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Use PDMA channel 2 to transfer data from memory to memory.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M451Series.h"
/* Macro, type and constant definitions        */
#define PLL_CLOCK       72000000
/* Global variables        */
uint32_t PDMA_TEST_LENGTH = 64;
uint8_t SrcArray[256];
uint8_t DestArray[256];
uint32_t volatile u32IsTestOver = 0;
* @brief       DMA IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The DMA default IRQ, declared in startup_nuc400series.s.
void PDMA_IRQHandler(void)
    uint32_t status = PDMA_GET_INT_STATUS();
    if(status & 0x1)    /* abort */
        if(PDMA_GET_ABORT_STS() & 0x4)
            u32IsTestOver = 2;
        PDMA_CLR_ABORT_FLAG(PDMA_ABTSTS_ABTIFn_Msk);
    else if(status & 0x2)      /* done */
        if(PDMA_GET_TD_STS() & 0x4)
            u32IsTestOver = 1;
        PDMA_CLR_TD_FLAG(PDMA_TDSTS_TDIFn_Msk);
    else
        printf("unknown interrupt !!\n");
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Waiting for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Waiting for PLL clock ready */
    CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Enable PDMA clock source */
    CLK_EnableModuleClock(PDMA_MODULE);
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD and TXD */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
void UART0_Init()
    /* Init UART        */
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
/*  Main Function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    /* If user want to write protected register, please issue SYS_UnlockReg() to unlock protected register. */
    SYS_LockReg();
    /* Init UART for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("+------------------------------------------------------+ \n");
    printf("|    PDMA Memory to Memory Driver Sample Code          | \n");
    /* Reset PDMA module */
    SYS_ResetModule(PDMA_RST);
    /* Open Channel 2 */
    PDMA_Open(0x4);
    PDMA_SetTransferCnt(2, PDMA_WIDTH_32, PDMA_TEST_LENGTH);
    /* transfer width is one word(32 bit) */
    PDMA_SetTransferAddr(2, (uint32_t)SrcArray, PDMA_SAR_INC, (uint32_t)DestArray, PDMA_DAR_INC);
    PDMA_SetTransferMode(2, PDMA_MEM, FALSE, 0);
    //burst size is 4
    PDMA_SetBurstType(2, PDMA_REQ_BURST, PDMA_BURST_4);
    PDMA_EnableInt(2, PDMA_INT_TRANS_DONE);
    NVIC_EnableIRQ(PDMA_IRQn);
    u32IsTestOver = 0;
    PDMA_Trigger(2);
    while(u32IsTestOver == 0);
    if(u32IsTestOver == 1)
        printf("test done...\n");
    else if(u32IsTestOver == 2)
        printf("target abort...\n");
    PDMA_Close();
    while(1);
zhuomuniao110| | 2019-12-21 16:05 | 只看该作者
好像提供的有这种例子,直接设置好从哪儿发送到哪儿
幸福小强| | 2019-12-22 20:41 | 只看该作者
配置好从哪儿传到哪儿啊
antusheng| | 2019-12-22 23:55 | 只看该作者
不知道,去相关头文件搜一下有没有这个关键词。
jasontu| | 2019-12-23 08:10 | 只看该作者
代碼跟文件,應該有都描述
