[技术问答]
N9H30 SPI LINUX kernel启动死机有人遇到过吗
861|10
tj_zhaozq|  楼主 | 2020-1-20 09:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Kernel:启动到以下地方就不动了。
使用的是JFFS2文件系统: SPI FLASH 128MBIT, 内部64M内存。
SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:625
sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
Console: colour dummy device 80x30
console [ttyS0] enabled
Calibrating delay loop... 148.88 BogoMIPS (lpj=744448)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0xc01e99d0 - 0xc01e9a0c
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
bio: create slab <bio-0> at 0
NetWinder Floating Point Emulator V0.97 (double precision)
jffs2: version 2.2. (NAND) (SUMMARY)  漏 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
[nuc970fb_probe] 10
Console: switching to colour frame buffer device 100x30
fb0: nuc970fb frame buffer device
nuc970-uart.0: ttyS0 at I/O 0x0 (irq = 36) is a NUC970
nuc970_dma_proxy module initialized
brd: module loaded
nuc970-spi0 nuc970-spi0: master is unqueued, this is deprecated
m25p80: Enable Quad Mode
m25p80 spi0.0: w25q128 (16384 Kbytes)
Creating 2 MTD partitions on "m25p80":
0x000000000000-0x000000200000 : "kernel"
0x000000800000-0x000000e00000 : "rootfs"
nuc970-rtc nuc970-rtc: rtc core: registered nuc970-rtc as rtc0
nuc970-rtc nuc970-rtc: setting system clock to 2005-01-01 00:01:42 UTC (1104537702)
VFS: Mounted root (jffs2 filesystem) on device 31:1.
devtmpfs: error mounting -2
Freeing unused kernel memory: 128K
Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.108 #17
Backtrace:
[<c0011de4>] (dump_backtrace+0x0/0x10c) from [<c0011f80>] (show_stack+0x18/0x1c)
r6:00000000 r5:c02a7328 r4:c025cf2c r3:00000000
[<c0011f68>] (show_stack+0x0/0x1c) from [<c01e6a48>] (dump_stack+0x20/0x28)
[<c01e6a28>] (dump_stack+0x0/0x28) from [<c01e3a30>] (panic+0x94/0x1f8)
[<c01e399c>] (panic+0x0/0x1f8) from [<c01e3440>] (kernel_init+0x130/0x158)
r3:00000000 r2:60000053 r1:0000021f r0:c025cf2c
r7:00000000
[<c01e3310>] (kernel_init+0x0/0x158) from [<c000eb78>] (ret_from_fork+0x14/0x3c)
r5:c01e3310 r4:00000000
598330983| | 2020-1-23 12:59 | 只看该作者
下载git里的例子试试
antusheng| | 2020-1-23 20:15 | 只看该作者
看不懂这种操作。
xixi2017| | 2020-1-24 13:51 | 只看该作者
在将镜像拷贝到sd卡后执行一遍:sudo sync
捉虫天师| | 2020-1-24 14:07 | 只看该作者
试试楼上的方法,按照提示搜索一下啊
antusheng| | 2020-1-24 15:10 | 只看该作者
楼主解决了没
dongnanxibei| | 2020-1-24 16:01 | 只看该作者
授权不够?
gejigeji521| | 2020-1-25 15:45 | 只看该作者
想学一下嵌入式Linux
xuanhuanzi| | 2020-1-27 13:32 | 只看该作者
没学过Linux驱动开发
捉虫天师| | 2020-1-28 16:22 | 只看该作者
准备学一下Linux开发,听过高薪。
天灵灵地灵灵| | 2020-1-30 19:19 | 只看该作者
不知道Linux最低要求是什么单片机
