[DemoCode下载]
M4系列的滴答时钟用法
375|4
643757107|  楼主 | 2020-1-31 22:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 6 $
* $Date: 15/09/02 10:04a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Get the current RTC data/time per tick.
* @note
* Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M451Series.h"
#define PLL_CLOCK           72000000
/* Global Interface Variables Declarations        */
volatile uint32_t g_u32RTCTickINT;
* @brief       IRQ Handler for RTC Interrupt
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The RTC_IRQHandler is default IRQ of RTC, declared in startup_M451Series.s.
void RTC_IRQHandler(void)
    /* To check if RTC tick interrupt occurred */
    if(RTC_GET_TICK_INT_FLAG() == 1)
        /* Clear RTC tick interrupt flag */
        RTC_CLEAR_TICK_INT_FLAG();
        g_u32RTCTickINT++;
        PB8 ^= 1;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT and LXT-32KHz */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk | CLK_PWRCTL_LXTEN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk | CLK_STATUS_LXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL and SysTick source to HCLK/2*/
    CLK_SetCoreClock(PLL_CLOCK);
    CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HCLK_DIV2);
    /* Enable peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(RTC_MODULE);
    /* Peripheral clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_PLL, CLK_CLKDIV0_UART(1));
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD, TXD */
    SYS->GPD_MFPL = SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD;
void UART0_Init(void)
    /* Init UART        */
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
    S_RTC_TIME_DATA_T sWriteRTC, sReadRTC;
    uint32_t u32Sec;
    uint8_t u8IsNewDateTime = 0;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("+-----------------------------------------+\n");
    printf("|    RTC Date/Time and Tick Sample Code   |\n");
    printf("+-----------------------------------------+\n\n");
    /* Enable RTC NVIC */
    NVIC_EnableIRQ(RTC_IRQn);
    /* Open RTC and start counting */
    sWriteRTC.u32Year       = 2014;
    sWriteRTC.u32Month      = 5;
    sWriteRTC.u32Day        = 15;
    sWriteRTC.u32DayOfWeek  = RTC_THURSDAY;
    sWriteRTC.u32Hour       = 15;
    sWriteRTC.u32Minute     = 30;
    sWriteRTC.u32Second     = 30;
    sWriteRTC.u32TimeScale  = RTC_CLOCK_24;
    RTC_Open(&sWriteRTC);
    /* Enable RTC tick interrupt, one RTC tick is 1/4 second */
    RTC_EnableInt(RTC_INTEN_TICKIEN_Msk);
    RTC_SetTickPeriod(RTC_TICK_1_4_SEC);
    printf("# Showing RTC date/time on UART0.\n\n");
    printf("1.) Use PB.8 to check tick period time is 1/4 second or not.\n");
    printf("2.) Show RTC date/time and change date/time after 5 seconds:\n");
    /* Use PB.8 to check tick period time */
    PB->MODE = (PB->MODE & ~GPIO_MODE_MODE8_Msk) | (GPIO_MODE_OUTPUT << GPIO_MODE_MODE8_Pos);
    u32Sec = 0;
    g_u32RTCTickINT = 0;
    while(1)
        if(g_u32RTCTickINT == 4)
            /* Read current RTC date/time */
            RTC_GetDateAndTime(&sReadRTC);
            if(u8IsNewDateTime == 0)
                printf("    %d/%02d/%02d %02d:%02d:%02d\n",
                       sReadRTC.u32Year, sReadRTC.u32Month, sReadRTC.u32Day, sReadRTC.u32Hour, sReadRTC.u32Minute, sReadRTC.u32Second);
            else
                printf("    %d/%02d/%02d %02d:%02d:%02d\r",
            if(u32Sec == sReadRTC.u32Second)
                printf("\nRTC tick period time is incorrect.\n");
                while(1);
            u32Sec = sReadRTC.u32Second;
                if(u32Sec == (sWriteRTC.u32Second + 5))
                    printf("\n");
                    printf("3.) Update new date/time to 2014/05/18 11:12:13.\n");
                    u8IsNewDateTime = 1;
                    RTC_SetDate(2014, 5, 18, RTC_SUNDAY);
                    RTC_SetTime(11, 12, 13, RTC_CLOCK_24, RTC_AM);
/*** (C) COPYRIGHT 2013~2015 Nuvoton Technology Corp. ***/
Scale是形式,这里是24小时制
643757107|  楼主 | 2020-1-31 22:28 | 只看该作者
深入了解库函数的参数意义非常重要。
734774645| | 2020-1-31 22:33 | 只看该作者
734774645| | 2020-1-31 22:34 | 只看该作者
参考代码非常给力。
