[DemoCode下载]
RTC报警唤醒
593|3
643757107|  楼主 | 2020-1-31 22:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RTC, TE, ck, TI
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 6 $
* $Date: 15/09/02 10:04a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Use RTC alarm interrupt event to wake up system.
* @note
* Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M451Series.h"
#define PLL_CLOCK           72000000
/* Global Interface Variables Declarations        */
extern int IsDebugFifoEmpty(void);
volatile uint8_t g_u8IsRTCAlarmINT = 0;
* @brief       IRQ Handler for RTC Interrupt
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The RTC_IRQHandler is default IRQ of RTC, declared in startup_M451Series.s.
void RTC_IRQHandler(void)
    /* To check if RTC alarm interrupt occurred */
    if(RTC_GET_ALARM_INT_FLAG() == 1)
        /* Clear RTC alarm interrupt flag */
        RTC_CLEAR_ALARM_INT_FLAG();
        g_u8IsRTCAlarmINT++;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT and LXT-32KHz */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk | CLK_PWRCTL_LXTEN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk | CLK_STATUS_LXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL and SysTick source to HCLK/2*/
    CLK_SetCoreClock(PLL_CLOCK);
    CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HCLK_DIV2);
    /* Enable peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(RTC_MODULE);
    /* Peripheral clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_PLL, CLK_CLKDIV0_UART(1));
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD, TXD */
    SYS->GPD_MFPL = SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD;
void UART0_Init(void)
    /* Init UART        */
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
    S_RTC_TIME_DATA_T sWriteRTC, sReadRTC;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("+-------------------------------------+\n");
    printf("|    RTC Alarm Wake-up Sample Code    |\n");
    printf("+-------------------------------------+\n\n");
    /* Enable RTC NVIC */
    NVIC_EnableIRQ(RTC_IRQn);
    /* Open RTC */
    sWriteRTC.u32Year       = 2014;
    sWriteRTC.u32Month      = 5;
    sWriteRTC.u32Day        = 15;
    sWriteRTC.u32DayOfWeek  = RTC_THURSDAY;
    sWriteRTC.u32Hour       = 23;
    sWriteRTC.u32Minute     = 59;
    sWriteRTC.u32Second     = 50;
    sWriteRTC.u32TimeScale  = RTC_CLOCK_24;
    RTC_Open(&sWriteRTC);
    /* Set RTC alarm date/time */
    sWriteRTC.u32Second     = 55;
    RTC_SetAlarmDateAndTime(&sWriteRTC);
    /* Enable RTC alarm interrupt and wake-up function will be enabled also */
    RTC_EnableInt(RTC_INTEN_ALMIEN_Msk);
    printf("# Set RTC current date/time: 2014/05/15 23:59:50.\n");
    printf("# Set RTC alarm date/time:   2014/05/15 23:59:55.\n");
    printf("# Wait system waken-up by RTC alarm interrupt event.\n");
    /* System enter to Power-down */
    /* To program PWRCTL register, it needs to disable register protection first. */
    SYS_UnlockReg();
    printf("\nSystem enter to power-down mode ...\n");
    /* To check if all the debug messages are finished */
    while(IsDebugFifoEmpty() == 0);
    CLK_PowerDown();
    while(g_u8IsRTCAlarmINT == 0);
    /* Read current RTC date/time */
    RTC_GetDateAndTime(&sReadRTC);
    printf("System has been waken-up and current date/time is:\n");
    printf("    %d/%02d/%02d %02d:%02d:%02d\n",
           sReadRTC.u32Year, sReadRTC.u32Month, sReadRTC.u32Day, sReadRTC.u32Hour, sReadRTC.u32Minute, sReadRTC.u32Second);
    printf("\n\n");
    printf("# Set next RTC alarm date/time: 2014/05/16 00:00:05.\n");
    RTC_SetAlarmDate(2014, 05, 16);
    RTC_SetAlarmTime(0, 0, 5, RTC_CLOCK_24, 0);
    SYS_UnlockReg();
    CLK_PowerDown();
    while(1);
/*** (C) COPYRIGHT 2013~2015 Nuvoton Technology Corp. ***/
其实类似闹铃唤醒。
643757107|  楼主 | 2020-1-31 22:30 | 只看该作者
年月日,时分秒。
734774645| | 2020-1-31 22:33 | 只看该作者
分享的资料非常好。
