[技术问答]
如何用M051生成一对互补的PWM呢?
402|10
刚才看了贴,用库函数生成PWM的例子,如何生成一对互补的呢?
huahuagg| | 2020-2-20 11:37 | 只看该作者
你要知道互补是干啥用的,就知道用哪个函数了。
huahuagg| | 2020-2-20 11:38 | 只看该作者
手册上给出了,是在死区设置时候才用到的互补概念,然后你死区时间设置为0,就是完整的互补信号。
huahuagg| | 2020-2-20 11:42 | 只看该作者
* @brief Enable Dead zone of selected channel
* @param[in] pwm The pointer of the specified PWM module
*                - PWMA : PWM Group A
*                - PWMB : PWM Group B
* @param[in] u32ChannelNum PWM channel number. Valid values are between 0~3
* @param[in] u32Duration Dead Zone length in PWM clock count, valid values are between 0~0xFF, but 0 means there is no
*                        dead zone.
* @return None
* @Details This function is used to enable Dead zone of selected channel
void PWM_EnableDeadZone(PWM_T *pwm, uint32_t u32ChannelNum, uint32_t u32Duration)
huahuagg| | 2020-2-20 12:03 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 4 $
* $Date: 15/05/22 2:05p $
* @brief    通过P40(24)和P41(PIN36)输出两路PWM信号.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
/* Macro, type and constant definitions        */
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
/* Global variables        */
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for IRC22M clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external 12MHz XTAL, internal 22.1184MHz */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC22M_EN_Msk);
    /* Enable PLL and Set PLL frequency */
    CLK_SetCoreClock(PLLCON_SETTING);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_PLL, CLK_CLKDIV_HCLK(2));
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable PWM module clock */
    CLK_EnableModuleClock(PWM01_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Select PWM module clock source */
    CLK_SetModuleClock(PWM01_MODULE, CLK_CLKSEL1_PWM01_S_HXT, 0);
    /* Reset PWMA channel0~channel3 */
    SYS_ResetModule(PWM03_RST);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD  */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Set P4 multi-function pins for PWMA Channel 0 and 1 */
    SYS->P4_MFP &= ~(SYS_MFP_P40_Msk|SYS_MFP_P41_Msk);
    SYS->P4_MFP |= (SYS_MFP_P40_PWM0|SYS_MFP_P41_PWM1);
void UART0_Init(void)
    /* Init UART        */
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  Main Function        */
int32_t main(void)
        uint8_t i=100;
        /* Unlock protected registers */
        SYS_UnlockReg();
        /* Init System, IP clock and multi-function I/O */
        SYS_Init();
        /* Lock protected registers */
        SYS_LockReg();
        /* Init UART0 for printf */
        UART0_Init();
        PWM_EnableOutput(PWMA, 0x1|0x2);
        PWM_ConfigOutputChannel(PWMA, PWM_CH0, 2000, i);
        PWM_EnableDeadZone(PWMA,PWM_CH0,0);
        PWM_Start(PWMA, 0x1|0x2);
        GPIO_SetMode(P3,BIT6,GPIO_PMD_OUTPUT);
        while(1)
                while(i>0)
                        i=i-1;
                        CLK_SysTickDelay(5000);
//驱动板载的LED红灯闪烁
                P36 ^=1;
                while(i<100)
                        i=i+1;
//驱动板载的LED红灯闪烁
                P36 ^=1;
huahuagg| | 2020-2-20 12:04 | 只看该作者
借用了论坛大神的例子添加了两句,就实现了。
734774645| | 2020-2-20 12:07 | 只看该作者
有个寄存器位,写1 就行了。
zhuomuniao110|  楼主 | 2020-2-20 12:21 | 只看该作者
多谢各位,学会了。
antusheng| | 2020-2-20 12:41 | 只看该作者
库函数其实很完美的,要搞清楚每一个都干啥的。
yiy| | 2020-2-20 23:24 | 只看该作者
有大神总结真不错
