[蓝牙芯片]
【CH579开发板评测】+ 和CC2541连接收发数据
2920|31
今天搞了一下蓝牙,和CC2541板子连接。
CC2541主机,沁恒板子是从机。CC2541发数据,沁恒板子收数据。
代码:
CC2541:
if ( keys & HAL_KEY_UP )
    // Start or stop discovery
    NPI_PrintString("  [KEY UP pressed!]\r\n");
    //if (connectedPeripheralNum < MAX_PERIPHERAL_NUM)
      if ( !simpleBLEScanning )//不在扫描中则进行扫描
        simpleBLEScanning = TRUE;
        simpleBLEScanRes = 0;
        LCD_WRITE_STRING( "Discovering...", HAL_LCD_LINE_1 );
        LCD_WRITE_STRING( "", HAL_LCD_LINE_2 );
        LCD_WRITE_STRING( "", HAL_LCD_LINE_3 );
        LCD_WRITE_STRING( "", HAL_LCD_LINE_4 );
        GAPCentralRole_StartDiscovery( DEFAULT_DISCOVERY_MODE,
                                       DEFAULT_DISCOVERY_ACTIVE_SCAN,
                                       DEFAULT_DISCOVERY_WHITE_LIST );
      else // 如果在扫描中,则停止扫描, 这个时候会返回已扫描到的设备
        GAPCentralRole_CancelDiscovery();
  if ( keys & HAL_KEY_CENTER )  //中间按键
#if 1// 连续自动连接已扫描到的从机
    LCD_WRITE_STRING("Connecting......", HAL_LCD_LINE_8);
    simpleBLEUpdateCnt = 0;
    simpleBLESendValue = 0;
    simpleBLEScanIdx = 0;
    performPeriodicTask_AutoConnect();  // 执行动连接
    osal_start_timerEx( simpleBLETaskId, SBP_AUTO_CONNECT_EVT, SBP_PERIODIC_EVT_AUTO_CONNECT );
    HalLedBlink (HAL_LED_1, 1, 50, 1000);//这个的意思是, 1000ms内,以50%的占空比闪烁1次, 实际就是点亮50ms
#else
    uint8 addrType;
    uint8 *peerAddr;
    BLE_DEV *p =  &(gDev[simpleBLEScanIdx]);
    NPI_PrintString("  [KEY_CENTER]\r\n");
    NPI_PrintValue("Idx=", simpleBLEScanIdx, 10);
    NPI_PrintValue("State=", p->simpleBLEState, 10);
    NPI_PrintValue("num=", connectedPeripheralNum, 10);
    NPI_PrintValue("res=", simpleBLEScanRes, 10);
    // Connect or disconnect
    //if ( p->simpleBLEState == BLE_STATE_IDLE
    //    || connectedPeripheralNum < MAX_PERIPHERAL_NUM)
    if ( p->simpleBLEState == BLE_STATE_IDLE )
      // if there is a scan result
      if ( simpleBLEScanRes > 0
        && simpleBLEScanIdx < simpleBLEScanRes )
        // connect to current device in scan result
        peerAddr = simpleBLEDevList[simpleBLEScanIdx].addr;
        addrType = simpleBLEDevList[simpleBLEScanIdx].addrType;
        p->simpleBLEState = BLE_STATE_CONNECTING;
        //osal_pwrmgr_device( PWRMGR_ALWAYS_ON );
        GAPCentralRole_EstablishLink( DEFAULT_LINK_HIGH_DUTY_CYCLE,
                                      DEFAULT_LINK_WHITE_LIST,
                                      addrType, peerAddr );
        LCD_WRITE_STRING( "Connecting", HAL_LCD_LINE_1 );
        LCD_WRITE_STRING( bdAddr2Str( peerAddr ), HAL_LCD_LINE_2 );
    else if ( p->simpleBLEState == BLE_STATE_CONNECTING ||
              p->simpleBLEState == BLE_STATE_CONNECTED ||
              p->simpleBLEState == BLE_STATE_DISCONNECTING)
      // disconnect
      p->simpleBLEState = BLE_STATE_DISCONNECTING;
      gStatus = GAPCentralRole_TerminateLink( p->simpleBLEConnHandle );
      LCD_WRITE_STRING( "Disconnecting", HAL_LCD_LINE_1 );
#endif
// smartRF开发板上的 S1 对应我们源码上的HAL_KEY_SW_6
  // 这里设置成发送数据功能了
  if ( keys & HAL_KEY_SW_6 )
    char str[32] = {0};
    sprintf(str, "Sent CHAR to PHER.");
    HalLcdWriteString(str,  HAL_LCD_LINE_5 );
    // 启动定时器发送数据
    osal_start_timerEx( simpleBLETaskId, SBP_PERIODIC_EVT, SBP_PERIODIC_EVT_PERIOD );// 关键
    LCD_WRITE_STRING("Key DOWN = Read RSSI", HAL_LCD_LINE_8);
沁恒板子:
static void simpleProfileChangeCB( uint8 paramID )
  uint8 newValue;
  switch( paramID )
    case SIMPLEPROFILE_CHAR1:
                        //PRINT("profile ChangeCB CHAR1..\n");
      SimpleProfile_GetParameter( SIMPLEPROFILE_CHAR1, &newValue );
                PRINT("profile ChangeCB CHAR1:%d\n",newValue);
      break;
    case SIMPLEPROFILE_CHAR3:
                        PRINT("profile ChangeCB CHAR3..\n");
      SimpleProfile_GetParameter( SIMPLEPROFILE_CHAR3, &newValue );
      break;
    default:
      // should not reach here!
      break;
效果图:
WCHCN| | 2020-3-30 09:21 | 只看该作者
xinmeng_wit| | 2020-3-31 19:49 | 只看该作者
厉害了
aspoke| | 2020-4-6 10:20 | 只看该作者
不同模块也可以通信额
232321122| | 2020-4-6 10:20 | 只看该作者
aspoke| | 2020-4-6 10:21 | 只看该作者
送蓝牙模块分析仪了吗
soodesyt| | 2020-4-6 10:21 | 只看该作者
这两个哪个的价格比较贵?
mnynt121| | 2020-4-6 10:21 | 只看该作者
谢谢分析。
plsbackup| | 2020-4-6 10:22 | 只看该作者
CH579技术手册
kmzuaz| | 2020-4-6 10:22 | 只看该作者
CH579 Examples的吗
qiufengsd| | 2020-4-6 10:22 | 只看该作者
CH579能够实现HID吗
updownq| | 2020-4-6 10:23 | 只看该作者
以后有机会试用看看
sanfuzi| | 2020-4-6 10:23 | 只看该作者
和CC2541连接速度快吗
soodesyt| | 2020-4-6 10:24 | 只看该作者
功耗哪个比较多一些呢
mnynt121| | 2020-4-6 10:24 | 只看该作者
厉害了。
aspoke| | 2020-4-6 10:24 | 只看该作者
CC2541怎么样
plsbackup| | 2020-4-6 10:24 | 只看该作者
BLE+ZigBee双模无线
232321122| | 2020-4-6 10:24 | 只看该作者
楼主测评了这么多的芯片。
kmzuaz| | 2020-4-6 10:24 | 只看该作者
keil开发的吗
CH579开发板确实很好。
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
