【GD32评测】四、串口
464|0
今晚搞了一下串口。
原理图:
代码:
#include "gd32e23x.h"
#include "gd32e231c_start.h"
#include "systick.h"
#include <stdio.h>
#define uchar unsigned char
#define uint unsigned int
void led_flash(int times);
//????:Delay()
void Delay(unsigned char us)  //5,7,9
  while(--us);
    \brief      main function
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    /* initialize KEY and LED, configure SysTick */
    gd_eval_key_init(KEY_WAKEUP, KEY_MODE_GPIO);
    systick_config();
    gd_eval_led_init(LED1);
    /* flash the LED for test */
    led_flash(1);
    delay_1ms(500);
    gd_eval_led_on(LED1);
                rcu_periph_clock_enable(RCU_GPIOA);
    /* configure led GPIO port */
                gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_9);
                gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_9);
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_9);
                gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_10);
                gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_10);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_10);
    rcu_periph_clock_enable(RCU_USART0);
                usart_deinit(USART0);
                usart_baudrate_set(USART0,115200);
                usart_parity_config(USART0,USART_PM_NONE);
                usart_word_length_set(USART0,USART_WL_8BIT);
                usart_stop_bit_set(USART0,USART_STB_1BIT);
                usart_transmit_config(USART0,USART_TRANSMIT_ENABLE);
                usart_data_first_config(USART0,USART_MSBF_LSB);
                usart_enable(USART0);
    while(1)
                                        usart_data_transmit(USART0,0xaa);
                                        while(RESET == usart_flag_get(USART0, USART_FLAG_TBE));
                                        delay_1ms(500);
    \brief      flash the LED for test
    \param[in]  times: times to flash the LEDs
    \param[out] none
    \retval     none
    int i;
    for (i = 0;i < times;i++){
        /* delay 500 ms */
        delay_1ms(500);
        /* toggle the LEDs */
        gd_eval_led_toggle(LED1);
        /* delay 500 ms */
        delay_1ms(500);
效果图:
工程:
UART0.rar (609.44 KB)
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
