其实就是12864+M0+FATFS文件系统!
附上代码
没有12864的记得把 ST7588lcd_Init和DisplayDisk这个函数屏蔽! 串口一样可以打印消息的~!-
- void disk_read_file()
- uint8_t Disk_Key=0 ;
- uint8_t file_rank=0;
- uint8_t temp;
- strcpy(diskname,"");
- obtain_folder();
- DisplayDisk(0);
- while(1)
- Disk_Key=KeyVolat;
- temp=file_rank;
- switch(Disk_Key)
- case KEY_NONE: break;
- case KEY_UP :
- if(file_rank++>=foldernum)
- file_rank=foldernum;
- while(Disk_Key==KEY_UP)
- } break;
- case KEY_DOWN:
- if(file_rank--<=0)
- file_rank=0;
- while(Disk_Key==KEY_DOWN)
- } break;
- case KEY_MENU:
- strcpy(diskname,disk[file_rank].foldername);
- file_rank=0;
- obtain_folder();
- } break;
- if(temp!=file_rank)
- DisplayDisk(file_rank);
- [code]
- void obtain_folder()
- FATFS FatFs; /* File system object for logical drive */
- FRESULT res;
- FILINFO finfo;
- DIR dirs;
- uint8_t i;
- filenum=0;
- foldernum=0;
- for(i=0;i<20;i++)
- memset(disk.foldername,0,20);
- memset(disk.filename,0,20);
- f_mount(0, &FatFs);
- printf("--------------Open File:/%s-------------------------\n",diskname);
- res=f_opendir(&dirs, diskname);
- if ( res== FR_OK)
- printf("--------------file name:%s--------------------------\n",diskname);
- while ((f_readdir(&dirs, &finfo) == FR_OK) && finfo.fname[0])
- if (finfo.fattrib & AM_DIR)//如果是文件夹
- printf("%s/%s\n",diskname,&finfo.fname[0]);
- strcpy(disk[foldernum++].foldername , &finfo.fname[0]);
- if (finfo.fattrib & AM_ARC)//如果是文件
- strcpy(disk[filenum++].filename , &finfo.fname[0]);
- // DisplayDisk(0);
- f_mount(0, NULL);
[/code]-
- typedef struct
- char filename[20];
- char foldername[20];
- }disk_t;
- disk_t disk[20];
- uint8_t filenum=0;
- uint8_t foldernum=0;
- char diskname[20];
- void DisplayDisk(unsigned char x_line)
- uint8_t i,j;
- uint8_t filenumber;
- filenumber=foldernum+filenum;
- j=0;
- CogLCDClr();
- for(i=0;i<filenumber;i++)
- if(i<foldernum)
- DisPlay_12X12_Str((uint8_t *)disk.foldername ,5,i*12);
- else if(i>=foldernum&&i<5)
- DisPlay_12X12_Str((uint8_t *)disk[j++].filename ,5,i*12);
- else
- break;
- DisPlay_Picture(0x00,0,3+(x_line*12),4,4);
- CogLCDRedraw();
- DrvSYS_Delay(8000);
