[DemoCode下载]
NUC029的HDIV使用方法,那么比使用CPU计算快多少呢?
387|12
huahuagg|  楼主 | 2020-6-19 18:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V2.10
* $Revision: 2 $
* $Date: 16/10/25 4:29p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Hardware divider(HDIV) Sample Code
* @note
* Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC029xGE.h"
#define PLLCON_SETTING      CLK_PLLCON_72MHz_HXT
#define PLL_CLOCK           72000000
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and and HCLK source divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Set PLL to Power-down mode and PLLSTB bit in CLK_STATUS register will be cleared by hardware.*/
    CLK_DisablePLL();
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Init I/O Multi-function        */
    /* Set multi-function pins for UART0 RXD and TXD */
    SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
    SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA3MFP_UART0_RXD | SYS_GPA_MFPL_PA2MFP_UART0_TXD);
void UART0_Init()
    /* Init UART        */
    UART_Open(UART0, 115200);
void HDIV_Init(void)
    /* Enable Hardware Divider Clock */
    CLK->AHBCLK |= CLK_AHBCLK_HDIVCKEN_Msk;
/*  MAIN function        */
int main(void)
    /* Disable register write-protection function */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init Divider */
    HDIV_Init();
    printf("+----------------------------------------------+\n");
    printf("|    Hardware Divider(HDIV) Sample Code        |\n");
    printf("\n");
    printf("12341 / 123 = %d\n", HDIV_Div(12341, 123));
    printf("12341 %% 123 = %d\n", HDIV_Mod(12341, 123));
    /* Lock protected registers */
    SYS_LockReg();
    printf("Done\n");
    while(SYS->PDID);
    return 0;
/*** (C) COPYRIGHT 2016 Nuvoton Technology Corp. ***/
huahuagg|  楼主 | 2020-6-19 18:01 | 只看该作者
有人知道这个快多少吗,如果使用这个优势有多大
huangcunxiake| | 2020-6-20 09:01 | 只看该作者
肯定很快。
不知道这个支持计算小数不,还是自己处理小数为整数。我去试试
huahuagg|  楼主 | 2020-6-21 12:33 | 只看该作者
快个好几倍是没问题的。
jiekou001| | 2020-6-21 18:26 | 只看该作者
之前好多指令才能完成的,现在一条指令就搞定
jasontu| | 2020-6-24 09:09 | 只看该作者
我記得用硬件除法器,只有2個CPU CLOCK的就已經可以得到結果。
dongnanxibei| | 2020-6-24 11:43 | 只看该作者
一个指令就实现了原来很多指令完成的运算。
qcliu| | 2020-7-6 17:21 | 只看该作者
这个如何计算呢
tfqi| | 2020-7-6 17:21 | 只看该作者
理论上快很多
wiba| | 2020-7-6 17:21 | 只看该作者
非常快的样子
zljiu| | 2020-7-6 17:22 | 只看该作者
可以自己试试
coshi| | 2020-7-6 17:22 | 只看该作者
这段代码很不错
