[DemoCode下载]
NUC029用定时器写延时函数
514|7
zhuotuzi|  楼主 | 2020-6-23 09:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 2 $
* $Date: 16/10/25 4:30p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Show how to use timer0 to create various delay time.
* @note
* Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC029xGE.h"
#define PLL_CLOCK       72000000
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL and SysTick source to HCLK/2*/
    CLK_SetCoreClock(PLL_CLOCK);
    CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HCLK_DIV2);
    /* Enable peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(TMR0_MODULE);
    CLK_EnableModuleClock(TMR1_MODULE);
    /* Peripheral clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_PLL, CLK_CLKDIV0_UART(1));
    CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0SEL_PCLK0, 0);
    CLK_SetModuleClock(TMR1_MODULE, CLK_CLKSEL1_TMR1SEL_HXT, 0);
    /* Init I/O Multi-function        */
    /* Set multi-function pins for UART0 RXD and TXD */
    SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
    SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA3MFP_UART0_RXD | SYS_GPA_MFPL_PA2MFP_UART0_TXD);
void UART0_Init(void)
    /* Init UART        */
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
    volatile uint32_t u32DelayTime;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+-----------------------------------+\n");
    printf("|    Timer Delay API Sample Code    |\n");
    printf("+-----------------------------------+\n\n");
    printf("# This sample code is using Timer1 to check Timer0 TIMER_Delay API delay time is reasonable or not.\n");
    printf("# Delay time includes 100 ms, 200 ms, 300 ms, 400 ms and 500 ms.\n\n");
    /* Start Timer1 to measure delay period of TIMER_Delay API is reasonable or not */
    TIMER1->CTL = TIMER_PERIODIC_MODE | (12 - 1);
    TIMER_ResetCounter(TIMER1);
    TIMER_Start(TIMER1);
    TIMER_Delay(TIMER0, 100000);
    u32DelayTime = TIMER_GetCounter(TIMER1) / 1000;
    printf("    Check DelayTime-1 is %d ms .... ", u32DelayTime);
    if(u32DelayTime == 100)
        printf("PASS.\n");
    else
        printf("FAIL.\n");
    TIMER_Delay(TIMER0, 200000);
    printf("    Check DelayTime-2 is %d ms .... ", u32DelayTime);
    if(u32DelayTime == 200)
        printf("PASS.\n");
    else
        printf("FAIL.\n");
    TIMER_Delay(TIMER0, 300000);
    printf("    Check DelayTime-3 is %d ms .... ", u32DelayTime);
    if(u32DelayTime == 300)
        printf("PASS.\n");
    else
        printf("FAIL.\n");
    TIMER_Delay(TIMER0, 400000);
    printf("    Check DelayTime-4 is %d ms .... ", u32DelayTime);
    if(u32DelayTime == 400)
        printf("PASS.\n");
    else
        printf("FAIL.\n");
    TIMER_Delay(TIMER0, 500000);
    printf("    Check DelayTime-5 is %d ms .... ", u32DelayTime);
    if(u32DelayTime == 500)
        printf("PASS.\n");
    else
        printf("FAIL.\n");
    printf("\n*** Check TIMER_Delay API delay time done ***\n");
    while(1);
/*** (C) COPYRIGHT 2016 Nuvoton Technology Corp. ***/
zhuotuzi|  楼主 | 2020-6-23 09:02 | 只看该作者
库函数已经帮你实现了,非常方便
antusheng| | 2020-6-23 16:59 | 只看该作者
前来学习。。。。。。
稳稳の幸福| | 2020-6-23 23:23 | 只看该作者
这种延时方法比较精准。
dongnanxibei| | 2020-6-24 11:43 | 只看该作者
用定时器做比较方便,毕竟比51快多了,跑空指令不现实。
稳稳の幸福| | 2020-6-24 20:53 | 只看该作者
定时器还是很准的。
幸福小强| | 2020-6-24 21:08 | 只看该作者
029好像性价比很高的。
余三水| | 2020-6-28 16:47 | 只看该作者
定时器写延时函数也是不错的,不过就是会占用一点资源,对于定时器紧张的场合,有点浪费。
