21ic电子技术开发论坛 单片机与嵌入式系统 德州仪器MCU USCI模块例程
发新帖我要提问
123下一页
返回列表
[MCU]
USCI模块例程
1052|50
zhanghqi|  楼主 | 2020-6-28 23:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
zhanghqi|  楼主 | 2020-6-28 23:49 | 只看该作者
包括UART,SPI,IIC的程序  不胜感激啦
zhenykun| | 2020-6-28 23:52 | 只看该作者
嗯,在网站上http://www.ti.com/product/msp430g2553下载相关examples code,其中前缀为MSP430G2xx3_uscia0_或是MSP430G2xx3_uscib0_的C程序文件.
hanwe| | 2020-6-28 23:54 | 只看该作者
官网的例程和资料都在msp430ware里
langgq| | 2020-6-28 23:57 | 只看该作者
USI和USCI有什么区别?
xxrs| | 2020-6-28 23:59 | 只看该作者
#include "MSP430G2553.h"
   #define LED1_ON P1DIR|=BIT0; P1OUT|=BIT0
   #define LED1_OFF P1DIR|=BIT0; P1OUT&=~BIT0
   #define LED2_ON P1DIR|=BIT6; P1OUT|=BIT6
   #define LED2_OFF P1DIR|=BIT6; P1OUT&=~BIT6
   #define RX_FIFO_SIZE   16                      //接收缓冲区大小宏定义
   #define TX_FIFO_SIZE   64                      //发送缓冲区大小宏定义
   unsigned char Rx_FIFO[RX_FIFO_SIZE]={0};     //UART接收FIFO数组
   unsigned int Rx_FIFO_DataNum=0;              //UART接收FIFO的“空满”指示变量
   unsigned int Rx_FIFO_IndexR=0;               //UART接收FIFO的模拟“读指针”变量
   unsigned int Rx_FIFO_IndexW=0;               //UART接收FIFO的模拟“写指针”变量
   unsigned char Tx_FIFO[TX_FIFO_SIZE]={0};     //UART发送FIFO数组
   unsigned int Tx_FIFO_DataNum=0;              //UART发送FIFO的“空满”指示变量
   unsigned int Tx_FIFO_IndexR=0;               //UART发送FIFO的模拟“读指针”变量
   unsigned int Tx_FIFO_IndexW=0;               //UART 发送FIFO 的模拟“写指针”变量
   extern  unsigned char  Rx_FIFO[RX_FIFO_SIZE];
   extern  unsigned int  Rx_FIFO_DataNum;
   extern  unsigned int  Rx_FIFO_IndexR;
   extern  unsigned int  Rx_FIFO_IndexW;
   extern  unsigned char  Tx_FIFO[TX_FIFO_SIZE];
   extern  unsigned int  Tx_FIFO_DataNum;
   extern  unsigned int  Tx_FIFO_IndexR;
   extern  unsigned int Tx_FIFO_IndexW;
   const unsigned char Out_DELETE[]= "\x8  \x8";     /* VT100 backspace and clear */
   const unsigned char String1[]="命令:LED1_ON LED1_OFF LED2_ON LED2_OFF\r\n";
   const unsigned char String2[]="Please input Command:\r\n";
   const   unsigned char String3[]="Are you crazy?\r\n";
   const   unsigned char String4[]="I was born for these!\r\n";
   const   unsigned char String5[]="I have got it!\r\n";
   const   unsigned char String6[]="It is easy for me!\r\n";
   const   unsigned char String7[]="As your wish!\r\n";
void  UART_OnTx(void);
void  UART_OnRx(void);
void  UART_SendString(const  unsigned char *Ptr);
void  Command_match();
    *  名  称:Rx_FIFO_WriteChar()
    *  功   能:往Rx接收FIFO中写1字节
    *  入口参数:Data:待写入FIFO的数据
    * 出口参数:1:写入数据成功,0 :写入数据失败
    *  说   明:操作FIFO时需要关闭总中断
    * 范  例:无
   char Rx_FIFO_WriteChar(unsigned  char Data)
       if(Rx_FIFO_DataNum==RX_FIFO_SIZE)  return(0);
                                    //判断FIFO是否已装满未读数据,如果装满返回0
       _DINT();                 //操作FIFO前一定要关总中断
       Rx_FIFO_DataNum++;                      //未读取数据个数加一
       Rx_FIFO[Rx_FIFO_IndexW]=Data;           //将数据写入写读指针位置的FIFO数组
       Rx_FIFO_IndexW++;                        //写指针移位
       if (Rx_FIFO_IndexW>=RX_FIFO_SIZE)       //判断指针是否越界
            Rx_FIFO_IndexW=0;                  //写指针循环归零
       _EINT();                   //恢复总中断使能
       return(1);                              //返回成功
   char Rx_FIFO_ReadChar(unsigned  char *Chr)
       if(Rx_FIFO_DataNum==0) return(0);   //判断FIFO是是否有未读数据,如果没有返回0
       Rx_FIFO_DataNum--;                  //待读取数据个数减一
       *Chr=Rx_FIFO[Rx_FIFO_IndexR];        //将读指针位置的FIFO数据赋给指针所指变量
       Rx_FIFO_IndexR++;                    //读指针移位
       if (Rx_FIFO_IndexR>=RX_FIFO_SIZE)    //判断指针是否越界
            Rx_FIFO_IndexR=0;               //读指针循环归零
       _EINT();              //恢复总中断使能
       return(1);
   void  Rx_FIFO_Clear()
       Rx_FIFO_DataNum=0;                       //FIFO 中未读取数据数目清零
            Rx_FIFO_IndexR=0;                  //FIFO 中模拟读指针清零
      Rx_FIFO_IndexW=0;                 //FIFO 中模拟写指针清零
      _EINT ();            //恢复总中断使能
   char Tx_FIFO_WriteChar(unsigned  char Data)
       if(Tx_FIFO_DataNum==TX_FIFO_SIZE)  return(0);
       //-----“全新”一次发送数据必须手动触发Tx中断-----
       if((Tx_FIFO_DataNum==0) &&( !(UCA0STAT & UCBUSY)))
                                               //判断是否为一次“全新”发送
            IFG2 |=UCA0TXIFG;                  // 手动触发一次
       Tx_FIFO_DataNum++;                      //未读取数据个数加一
       Tx_FIFO[Tx_FIFO_IndexW]=Data;           //将数据写入写读指针位置的FIFO数组
       Tx_FIFO_IndexW++;                       //写指针移位
       if (Tx_FIFO_IndexW   >= TX_FIFO_SIZE)   //判断指针是否越界
            Tx_FIFO_IndexW=0;                  //写指针循环归零
       _EINT();                  //恢复总中断使能
       return(1);                              //返回成功
   char Tx_FIFO_ReadChar(unsigned    char *Chr)
        if(Tx_FIFO_DataNum==0) return(0);   //判断FIFO是是否有未读数据,如果没有返回0
        Tx_FIFO_DataNum --;                  //待读取数据个数减一
        *Chr=Tx_FIFO[Tx_FIFO_IndexR];       //将读指针位置的FIFO数据赋给指针所指变量
        Tx_FIFO_IndexR++;                    //读指针移位
        if (Tx_FIFO_IndexR>=TX_FIFO_SIZE)    //判断指针是否越界
            Tx_FIFO_IndexR=0;                //读指针循环归零
        _EINT();               //恢复总中断使能
        return(1);                           //返回成功
   void Tx_FIFO_Clear()
        Tx_FIFO_DataNum=0;                         //FIFO 中未读取数据数目清零
        Tx_FIFO_IndexR=0;                          //FIFO 中模拟读指针清零
        Tx_FIFO_IndexW=0;                          //FIFO 中模拟写指针清零
        _EINT();                     //恢复总中断使能
    *  名  称:USCI_A0_init()
    *  功    能:初始化USCI_A0模块为UART模式
    *  入口参数:无
    * 出口参数:无
    *  说    明:UART设为波特率9600,8位数据,无校验,1位停止位
    *             UART初始化配置较复杂,可以使用Grace配置后再移植代码的方法
    * 范  例:无
   void  USCI_A0_init(void)
       //-----开启IO口的TXD和RXD功能-----
          P1SEL = BIT1 + BIT2 ;                   // P1.1 = RXD, P1.2=TXD
          P1SEL2 = BIT1 + BIT2;
         //-----设置UART时钟源为ACLK-----
          UCA0CTL1 |= UCSSEL_1;                    // CLK = ACLK
         //-----移植Grace配置的波特率参数-----
          UCA0BR0 = 0x03;                         // 32kHz/9600 = 3.41
          UCA0BR1 = 0x00;
          UCA0MCTL = UCBRS1 + UCBRS0;             // Modulation UCBRSx = 3
          UCA0CTL1 &= ~UCSWRST;                   // **Initialize USCI state machine**
                   IE2 |= UCA0RXIE + UCA0TXIE;                // Enable USCI_A0 TX/RX interrupt
         _EINT();                     //开总中断
    *  名  称:USCI0TX_ISR()
    *  功    能:响应Tx中断服务
    *  入口参数:无
    * 出口参数:无
    *  说    明:凡是中断标志位有可能不被自动清除的,均手动清除一次,以防万一
    * 范  例:无
   #pragma vector=USCIAB0TX_VECTOR
   __interrupt void  USCI0TX_ISR(void)
       IFG2&=~UCA0TXIFG;                           //手动清除标志位
        UART_OnTx();                               //调用Tx事件处理函数
    *  名  称:USCI0RX_ISR()
    *  功    能:响应Rx中断服务
    *  入口参数:无
    * 出口参数:无
    * 范  例:无
   #pragma vector=USCIAB0RX_VECTOR
   __interrupt void  USCI0RX_ISR(void)
        IFG2&=~UCA0RXIFG;                         //手动清除标志位
        UART_OnRx();                               //调用Rx事件处理函数
        unsigned char Temp=0;
        if(Tx_FIFO_DataNum>0)
             Tx_FIFO_ReadChar(&Temp);                 //调用FIFO库函数
              UCA0TXBUF= Temp;
gongche| | 2020-6-28 23:59 | 只看该作者
// HW UART(J4)!!!!!! 特别注意,板子上J4有2个跳线要竖放,设为HW UART模式
// MSP430G2xx3 Demo - USCI_A0, 9600 UART Echo ISR, DCO SMCLK
// Description: Echo a received character, RX ISR used. Normal mode is LPM0.
// USCI_A0 RX interrupt triggers TX Echo.
// Baud rate divider with 16MHz
// ACLK = n/a, MCLK = SMCLK = CALxxx_16MHZ = 16MHz
// MSP430G2xx3
// /|\| XIN|-
// --|RST XOUT|-
// | P1.2/UCA0TXD|------------>
// | | 9600 - 8N1
// | P1.1/UCA0RXD|<------------
// 修改http://jiwm.blog.163.com
本文引用地址:http://www.**/article/201611/316568.htm
//串口调试助手,下载地址:http://www.sudt.com/download/AccessPort137.zip
// Texas Instruments Inc.
// February 2011
// Built with IAR Embedded Workbench Version: 5.40
#include "msp430g2553.h"
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
BCSCTL1 = CALBC1_16MHZ; // Set DCO
DCOCTL = CALDCO_16MHZ;
UCA0CTL1 |= UCSSEL_2; // SMCLK
UCA0BR0 = 0x82; // 16MHz 9600 UCA0BRX=1666=0x0682
UCA0BR1 = 0x06; // 16MHz 9600
UCA0MCTL = UCBRS2 + UCBRS1; // Modulation UCBRSx = 6
IE2 |= UCA0RXIE; // Enable USCI_A0 RX interrupt
__bis_SR_register(LPM0_bits + GIE); // Enter LPM0, interrupts enabled
// Echo back RXed character, confirm TX buffer is ready first
while (!(IFG2&UCA0TXIFG)); // USCI_A0 TX buffer ready?
UCA0TXBUF = UCA0RXBUF; // TX -> RXed character
stly| | 2020-6-29 22:09 | 只看该作者
msp430G2553只有USCI,笼统的说,USCI比USI功能强大。
xxrs| | 2020-6-29 22:13 | 只看该作者
msp430g2553例程大全这个有。
chenjunt| | 2020-6-29 22:16 | 只看该作者
MSP430G2553测试程序网上有的。
xxmmi| | 2020-6-29 22:18 | 只看该作者
这个在官网的代码有吧。
hanwe| | 2020-6-29 22:21 | 只看该作者
msp430G2553只有USCI吗?
wangpe| | 2020-6-29 22:24 | 只看该作者
官网的代码没有嘛?
gongche| | 2020-6-29 22:26 | 只看该作者
是不是msp430g2553上只有USCI?
bqyj| | 2020-6-29 22:32 | 只看该作者
//                MSP430G2xx3
//         /|\|              XIN|-
//          --|RST          XOUT|-
//            |                 | 9600 - 8N1
//   February 2011
void main(void)
songqian17| | 2020-6-29 22:34 | 只看该作者
       unsigned char Temp = 0;
       Temp=UCA0RXBUF;                            //预存下Tx Buffer数据
       //-----首先必须回显屏幕-----
       if(Temp == 0x0d)                           //如果是回车
            Tx_FIFO_WriteChar('\r');
            Tx_FIFO_WriteChar('\n');
       else if(Temp==0x08 || Temp==0x7f)          //如果是退格
            UART_SendString(Out_DELETE);         //发送退格键
               else                                              //如果是正常显示数据
               Tx_FIFO_WriteChar(Temp);                     // 回显数据
         //----- 回车后开始数据帧识别-----
         if(Temp == 0x0d)                                   //如果是回车,表明可以做个” 了断“了
               if(Rx_FIFO_DataNum > 0)                      //FIFO里有数据,则进行数据判断
                    Command_match();                        //判断命令是什么
                    Rx_FIFO_Clear();                         //清空FIFO
               else{                                         //如果啥数据都没有(光敲了个回车)
                    UART_SendString(String1);                //显示命令提示符
                    UART_SendString(String2);                //显示命令提示符
         //-----退格键则要删除FIFO里一个数据-----
         else if(Temp==0x08 || Temp==0x7f)                   //如果是退格键,则需要删除一个
               if( Rx_FIFO_DataNum>0)                         //有数据才需要删,没有数据当然不用删
                    _DINT();                    //操作FIFO时必须关重大U难
                    Rx_FIFO_DataNum--;                         //待读数据减1
                    if(Rx_FIFO_IndexW   >0)                   //防止溢出
                          Rx_FIFO_IndexW--;                   //写指针退格
                     _EINT();
         //-----既不是回车也不是退格,那就正常存命令数据-----
         else
               Rx_FIFO_WriteChar(Temp);                        //正常写FIFO
      void  UART_SendString(const  unsigned char *Ptr)      //给上位机发送字符串
        while(*Ptr)
             Tx_FIFO_WriteChar(*Ptr++);
      void  Command_match()      //  字符匹配命令
        unsigned char Command_Num=0;
        //-----命令共4种:LED1_ON,LED1_OFF,LED2_ON,LED2_OFF-----
        if((Rx_FIFO[0]=='L')&&(Rx_FIFO[1]=='E')&&(Rx_FIFO[2]=='D')
                  &&(Rx_FIFO[4]=='_')&&(Rx_FIFO[5]=='O'))     //先匹配共有字母LED?_O??
                             if((Rx_FIFO[3]=='1')&&(Rx_FIFO[6]=='N'))
                                       Command_Num=1;        //匹配上命令字LED1_ON
                                                          if((Rx_FIFO[3]=='1')&&(Rx_FIFO[6]=='F')&&(Rx_FIFO[7]=='F'))
                                        Command_Num=2;          //匹配上命令字LED1_OFF
                              if((Rx_FIFO[3]=='2')&&(Rx_FIFO[6]=='N'))
                                        Command_Num=3;          //匹配上命令字LED2_ON
                              if((Rx_FIFO[3]=='2')&&(Rx_FIFO[6]=='F')&&(Rx_FIFO[7]=='F'))
                                        Command_Num=4;          //匹配上命令字LED2_OFF
        switch(Command_Num)
        case 0: UART_SendString(String3);break;                //没匹配上任何命令,发送错误提示语
         //-----执行LED控制命令,并给出正面积极提示语-----
        case 1: LED1_ON;UART_SendString(String4);break;
        case 2: LED1_OFF;UART_SendString(String5);break;
        case 3: LED2_ON;UART_SendString(String6);break;
        case 4: LED2_OFF;UART_SendString(String7);break;
        default:break;
void  main(void) {
       WDTCTL = WDTPW + WDTHOLD;                 // Stop watchdog timer
       USCI_A0_init();
       _BIS_SR(LPM3_bits) ;
       while(1){
chuxh| | 2020-6-29 22:37 | 只看该作者
MSP430G2553测试程序(串口程序,USCI模式)
llljh| | 2020-6-29 22:42 | 只看该作者
单片机内USCI模块的UART模式
pengf| | 2020-6-29 22:45 | 只看该作者
例程网上有很多吧。
xxrs| | 2020-6-29 22:49 | 只看该作者
官网好像有,下载一个参考一下。
下一页 »
关闭 热门推荐
