[通用8051核FLASH系列]
【芯圣SDK-HC89F0541测评】+ HT1621
2364|1
今天下午搞了一下HT1621.
CS:P1.5
WR:P1.6
DA:P1.7
代码:
#define        ALLOCATE_EXTERN
#include "HC89F0541.h"
#define uchar unsigned char
#define uint unsigned int
#define Smg_a    0x80
#define Smg_b    0x40
#define Smg_c    0x20
#define Smg_d    0x01
#define Smg_e    0x02
#define Smg_f    0x08
#define Smg_g    0x04
#define Smg_dp   0x10
#define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map          Smg_b | Smg_c
#define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map          Smg_a | Smg_b | Smg_c
#define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
#define CS_0           P1_5=0
#define CS_1           P1_5=1
#define WR_0           P1_6=0
#define WR_1           P1_6=1
#define DA_0           P1_7=0
#define DA_1           P1_7=1
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //显示缓冲区
unsigned int i;
void COMMAND_HT1621(unsigned char comm)
    //unsigned char i;
    CS_0;
    WR_0;
    for(i=0;i<3;i++)        //写命令
        if((0x04<<i)&0x04)  DA_1;    //100
        else                DA_0;
        WR_0;
        WR_1;
    for(i=0;i<9;i++)        //写命令数据
        if((comm<<i)&0x80)  DA_1;    //100
        else                DA_0;
        WR_0;
        WR_1;
    CS_1;
void HT1621_Display(void)
    //unsigned char i;
    CS_0;                        //片选CS
    WR_0;
        if((0x05<<i)&0x04)  DA_1;
        else                DA_0;
        WR_0;
        WR_1;
    for(i=0;i<6;i++)                   //写地址
        if((20<<i)&0x20)    DA_1;  //20对应 SEG地址
        else                DA_0;
        WR_0;
        WR_1;
    for(i=0;i<8;i++)                   //写数据
        if((DpyNum[5]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[4]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[3]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[2]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[1]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[0]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
    CS_1;                          //释放CS
void LCD_Init(void)
    COMMAND_HT1621(0x01);         //SYS EN
    COMMAND_HT1621(0x03);         //LCD ON
    COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
    HT1621_Display();             //clear screen
  * @实现效果        T0定时1ms,每进一次中断,P14翻转一次
void main()
        //long int i;
/************************************系统初始化****************************************/
        CLKSWR = 0x51;                                                //选择内部高频RC为系统时钟,内部高频RC 2分频,Fosc=16MHz
        CLKDIV = 0x01;                                                //Fosc 1分频得到Fcpu,Fcpu=16MHz
/**********************************相关配置初始化**************************************/
  P1M5 = 0xC0;                        //P25设置为推挽输出
        P1M6 = 0xC0;                        //P26设置为推挽输出
        P1M7 = 0xC0;                        //P27设置为推挽输出
/**********************************TIM0配置初始化**************************************/
        LCD_Init();
        DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"三"
        DpyNum[1] = SegCode[1];
        DpyNum[2] = SegCode[3];
        DpyNum[3] = SegCode[5];
        DpyNum[4] = SegCode[7];
        DpyNum[5] = SegCode[9];
        HT1621_Display();               //刷新LCD
        while(1)
效果图:
工程:
HT1621.rar (47.46 KB)
芯片彭于晏| | 2020-7-8 16:33 | 只看该作者
HT1621B 这个市面上有很多种货,质量都参差不齐
