写个单片机程序最后搞得像PLC程序一样
285|0
电员师|  楼主 | 2018-7-30 11:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
[mw_shl_code=c,true]void M_updata(void)
        u32 i;
                    switch(Set_screen_id )
                        case screen_0:        //选择画面
                        break;
                        case screen_1:        //自动画面
                                for (i = 100;i < 101 ;i++)
                                        if (m != mtemp)
                                                SetButtonValue(Set_screen_id,madd+i,m);
                                                mtemp = m;
                                for (i = 0;i < osize ;i++)
                                        if (o != otemp)
                                                AnimationPlayFrame(Set_screen_id,oadd+i,o);
                                                otemp = o;
                        break;
                        case screen_2:        //手动画面
                                for (i = 100;i < 118 ;i++)
                                        if (m != mtemp)
                                                mtemp = m;
                        break;
                        case screen_3:        //参数画面
                        break;
                        case screen_4:
                        break;
                        case screen_5:        //输入画面
                                for (i = 0;i < xsize ;i++)
                                        if ((x != xtemp) ||(Set_screen_id != Set_screen_idtemp))
                                                AnimationPlayFrame(Set_screen_id,xadd+i,x);
                                                xtemp = x;
                                Set_screen_idtemp = Set_screen_id;
                        break;
                        case screen_6:        //输出画面
                                for (i = 0;i < ysize ;i++)
                                        if ((y != ytemp) ||(Set_screen_id != Set_screen_idtemp))
                                                AnimationPlayFrame(Set_screen_id,yadd+i,y);
                                                ytemp = y;
                        break;
                        case screen_7:
                        break;
void main1 (void )
        u8 i;
        if (X0) Y0 = 0;
        if (m[100] == 1 && mp100 == 0)
                mf100 = 0;
                mp100 = 1;
                o[2] = 1;
                m[10] = 1;        //回原点
        else if (m[100] ==0 && mf100 == 0)        //M100程序启动 o2程序指示
                o[2] = 0;
                mp100 = 0;
                mf100 = 1;
                for (i=0;i<msize;i++) m = 0;
                for (i=0;i<ysize;i++) y = 0;
        if (m[0]) o[0] = 1;                //M0手动自动选择 o0指示
        else o[0] = 0;
        if (m[1]) o[1] = 1;        //M1规格选择 o1规格指示
        else o[1] = 0;
        if (m[2]) o[3] = 1;        //M2清洗 o3指示
        else o[3] = 0;
        if (m[3]) d[0] = 0,m[3] = 0;        //M3清零
}[/mw_shl_code]
