[技术问答]
关于n76e003单片机串口接收,接收字符串会在发完所有字符后...
901|11
#include "n76e003.h"
#include "system.h"
#include "tm1650.h"
#include "stdio.h"
#include "BC26.h"
#include "string.h"
#define   CHARTAST     1
#define   NUMTAST       2
#define   MENUTAST     3
#define BUFLEN 32              //字符串长度
typedef struct _UART_BUF
    char buf [BUFLEN+1];
    unsigned int index ;
}UART_BUF;
bit HaveTast=0;
unsigned char Uart0Cmd;
int SET_BIT4=0X10;
int CLR_BIT4=0XEF;
UART_BUF buf_uart2;      //给字符串数组分配空间
void Uart0_Init(void);
void Uart0_Process(void);
void Uart0_SendChar(unsigned char Udat);
void Uart0_SendString(unsigned char *PBuf);
   void Clear_Buffer(void)          //数组清空
    Delay_ms(30);
    buf_uart2.index=0;
    memset(buf_uart2.buf,1,BUFLEN);
void nbiot_receive_process_event(unsigned char ch )          //将字符依次存入数组
     if(buf_uart2.index >= BUFLEN)
        buf_uart2.index = 0 ;
      else{
                                buf_uart2.buf[buf_uart2.index] = ch;
              buf_uart2.index++;
void USART2_IRQHandler()   interrupt 4
        char temp;
temp=SBUF;
nbiot_receive_process_event(temp); 将SUBF依次存入数组
        RI=0;        //串口中断标志位  置0
void main(void)
        System_Init();
        TM1650_Init();
        ToDisplay__();
         Uart0_Init();
  MODIFY_HIRC_166();   //调整波特率
         while(1)
        Uart0_SendString(buf_uart2.buf); //打印字符串内容
                Delay_ms(1000);
         SCON=0x50;                                                      //模式一,定时器,八位自动重装
        ClrBits(TMOD,T1_GATE|T1_CT|T1_M0);
        SetBits(TMOD,T1_M1);
        SetBits(PCON,SMOD);
        SetBits(CKCON,T1M);
        ClrBits(T3CON,BRCK);
        TH1=256 - (1000000/115200+1);        //波特率115200  16.6MHz
        TR1=1;
        ES=1;
        EA=1;
        P0_Quasi_Mode(PIN_6|PIN_7);
void Uart0_SendChar(unsigned char Udat) //串口发送单个字符
        SBUF=Udat;
        while(!TI);
  TI=0;
void Uart0_SendString(unsigned char *PBuf)   //串口发送字符串
  while(*PBuf!='\0')
          Uart0_SendChar(*PBuf);
          PBuf++;
void MODIFY_HIRC_166(void)  //调整时钟
unsigned char hircmap0,hircmap1;
unsigned int trimvalue16bit;
if ((PCON&SET_BIT4)==SET_BIT4)
hircmap0 = RCTRIM0;
hircmap1 = RCTRIM1;
trimvalue16bit = ((hircmap0<<1)+(hircmap1&0x01));
trimvalue16bit = trimvalue16bit - 15;
hircmap1 = trimvalue16bit&0x01;
hircmap0 = trimvalue16bit>>1;
TA=0XAA;
TA=0X55;
RCTRIM0 = hircmap0;
TA=0XAA;
TA=0X55;
RCTRIM1 = hircmap1;
PCON &= CLR_BIT4;
[img][/img]
7_串口0接收发送字符串测试实验定时器1.zip
95.89 KB
程序源码
新塘初级用户 2020-7-24 09:23 回复TA
process和isr这两个函数没有调用,不用管它
新塘初级用户 2020-7-24 09:22 回复TA
不知为何,复制过来的代码注释是乱码,不好意思
643757107| | 2020-7-24 09:30 | 只看该作者
没看明白是什么问题,
643757107| | 2020-7-24 09:31 | 只看该作者
楼主是要问的啥,没懂。
新塘初级用户|  楼主 | 2020-7-24 09:41 | 只看该作者
643757107 发表于 2020-7-24 09:30
没看明白是什么问题,
意思就是,我用单片机接收从PC串口下发的字符串,收到这个字符串,把他存到数组里面打印出来,不知为何会在发回我接收到的字符串的所有字符后,会一直打印这个字符串的最后一个字符,比如我发给单片机GJKV,他回GJKVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
新塘初级用户|  楼主 | 2020-7-24 09:47 | 只看该作者
新塘初级用户 2020-7-24 09:51 回复TA
发送给单片机GJKV,他回GJKVVVVVVVV,按理说我打印的是个数组,他会一直回最后一个字母,应该是不知道什么时候又跳进中断,但是没有数据给他,SBUF就一直存着最后一个字符,但我不知道是哪个环节出了问题
新塘初级用户|  楼主 | 2020-7-24 10:27 | 只看该作者
我整出来了,原来是没有清除TI
598330983| | 2020-7-24 17:56 | 只看该作者
新塘初级用户 发表于 2020-7-24 10:27
我整出来了,原来是没有清除TI
喔,就是没清除中断,一直在重复。。。。。
598330983| | 2020-7-24 18:00 | 只看该作者
多谢楼主分享经验。
643757107| | 2020-7-24 21:29 | 只看该作者
这个经验宝贵。
