[技术讨论]
Xilinx zynq Ultrascale+ MPSOC SD卡boot 启动异常,各位大佬,还请不吝赐教!
634|0
wang168506|  楼主 | 2021-5-24 15:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
板卡目前情况:
PL侧编程正常,PS侧编程正常
但是在SD卡boot模式下报错,请各位大佬给指点一下思路!
开发板上的SD卡加一个SD3.0的buffer,但是我们用的是SD2.0,因此是直接将Bank的电压设置为3V3,然后相应的功能管脚引到SD卡槽
Xilinx Zynq MP First Stage Boot Loader
Release 2020.2   May 24 2021  -  03:15:45
Reset Mode      :       System Reset
Platform: Silicon (4.0), Cluster ID 0x80000000
Running on A53-0 (64-bit) Processor, Device Name: XCZU11EG
Processor Initialization Done
================= In Stage 2 ============
SD1 Boot Mode
SD: rc= 0
File name is 1:/BOOT.BIN
SD: Unable to open file 1:/BOOT.BIN: 3
                                      XFSBL_ERROR_SD_F_OPEN
Boot Device Initialization failed 0x29
================= In Stage Err ============
Fsbl Error Status: 0x0
