[DemoCode下载]
硬件除法器使用方法
5999|13
玛尼玛尼哄|  楼主 | 2021-6-20 20:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V2.10
* $Revision: 3 $
* $Date: 14/01/28 11:44a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    NUC029 Series Timer Controller and Watchdog Timer Driver Sample Code
* @note
* Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC029xAN.h"
#define PLLCON_SETTING      CLK_PLLCON_50MHz_XTAL
#define PLL_CLOCK           50000000
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable External XTAL (4~24 MHz) */
    CLK->PWRCON &= ~CLK_PWRCON_XTL12M_EN_Msk;
    CLK->PWRCON |= (0x1 << CLK_PWRCON_XTL12M_EN_Pos); // XTAL12M (HXT) Enabled
    /* Waiting for 12MHz clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_XTL12M_STB_Msk));
    /* Enable IP clock */
    CLK->APBCLK |= CLK_APBCLK_UART0_EN_Msk; // UART Clock Enable
    /* Select IP clock source */
    CLK->CLKSEL1 &= ~CLK_CLKSEL1_UART_S_Msk;
    CLK->CLKSEL1 |= (0x0 << CLK_CLKSEL1_UART_S_Pos);// Clock source from external 12 MHz
    /* Set P30(RXD0),P31(TXD0) multi-function pins for UART0 RXD and TXD  */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
void UART0_Init(void)
    /* Init UART        */
    /* Configure UART0 and set UART0 Baudrate */
    UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
void HDIV_Init(void)
    /* Enable Hardware Divider Clock */
    CLK->AHBCLK |= CLK_AHBCLK_HDIV_EN_Msk;
/*  MAIN function        */
int main(void)
    /* Disable register write-protection function */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init Divider */
    HDIV_Init();
    printf("+----------------------------------------------+\n");
    printf("|       Divider Sample Code                    |\n");
    printf("\n");
    printf("12341 / 123 = %d\n", HDIV_Div(12341, 123));
    printf("12341 %% 123 = %d\n", HDIV_Mod(12341, 123));
    /* Lock protected registers */
    SYS_LockReg();
    printf("Done\n");
    while(SYS->PDID);
    return 0;
sparrow054| | 2021-7-10 16:34 | 只看该作者
老板,看不太懂,能不能有时间的时候,给讲解一下。
发个原创帖,没准还有奖励,
实在是,最近也一直对这部分有点兴趣
之前都是代码里存来存去的,
幸福小强| | 2021-7-10 17:16 | 只看该作者
发个原创帖,没准还有奖励,
实在是,最近也一直对这部 ...
直接使能该功能,然后调用库函数啊。有啥难的。
我是看明白了,就是有一个相关的库函数,直接使能该功能后调用除法器的库函数计算。
huahuagg| | 2021-7-10 21:19 | 只看该作者
看起来很好使用,下次遇到计算试试这个方法对比一下。
foxsbig| | 2021-7-12 09:42 | 只看该作者
是初始化,之后,就直接调用如下就可以了么?
zhuomuniao110| | 2021-7-12 22:34 | 只看该作者
应该是的,就是这样吧
zhuomuniao110| | 2021-7-12 22:35 | 只看该作者
初始化好像就是使能数学除法器的时钟。
jiekou001| | 2021-7-15 21:51 | 只看该作者
还没用过,所有系列都支持吗
两只袜子| | 2021-7-16 19:51 | 只看该作者
所有系列都支持吗
木木guainv| | 2021-8-6 19:01 | 只看该作者
这个是专用的除法器吗
xiaoqizi| | 2021-8-6 19:06 | 只看该作者
会不会非常耗费资源啊
734774645| | 2021-8-9 22:57 | 只看该作者
非常容易用。
734774645| | 2021-8-9 22:58 | 只看该作者
xiaoqizi 发表于 2021-8-6 19:06
会不会非常耗费资源啊
这个外设应该就是减少消耗资源的。
不然需要很多指令组合才能完成除法运算
