[应用相关]
移植rt-thread的过程中出现 #20: identifier “time_t“ is undefined...
796|2
keaibukelian|  楼主 | 2021-7-1 17:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
移植rt-thread的过程中出现 #20: identifier “time_t“ is undefined或 identifier “clock_t“ is undefined
主要原因是在linux操作系统上这些值时定义的,但是移植到IAR或KEIL中是没有定义的,我查了半天三个值需要定义
typedef long int time_t;
typedef long clock_t;
struct tm
        int tm_sec;
        int tm_min;
        int tm_hour;
        int tm_mday;  //一个月中的某天(0 - 31)
        int tm_mon;
        int tm_year;
        int tm_wday;  //星期(0 - 6)
        int tm_yday;  //一年中的某天(1 - 365)
        int tm_isdst; //夏令时(即夏天将时间调快1小时)
keaibukelian|  楼主 | 2021-7-1 17:44 | 只看该作者
修改后的time.c和time.h
* Copyright (c) 2006-2018, RT-Thread Development Team
* SPDX-License-Identifier: Apache-2.0
* Change Logs:
* Date           Author       Notes
* 2019-08-21     zhangjun     copy from minilibc
#include <time.h>
#include <rtthread.h>
#if !defined (__IAR_SYSTEMS_ICC__)
/* days per month -- nonleap! */
const short __spm[13] =
    0,
    (31),
    (31 + 28),
    (31 + 28 + 31),
    (31 + 28 + 31 + 30),
    (31 + 28 + 31 + 30 + 31),
    (31 + 28 + 31 + 30 + 31 + 30),
    (31 + 28 + 31 + 30 + 31 + 30 + 31),
    (31 + 28 + 31 + 30 + 31 + 30 + 31 + 31),
    (31 + 28 + 31 + 30 + 31 + 30 + 31 + 31 + 30),
    (31 + 28 + 31 + 30 + 31 + 30 + 31 + 31 + 30 + 31),
    (31 + 28 + 31 + 30 + 31 + 30 + 31 + 31 + 30 + 31 + 30),
    (31 + 28 + 31 + 30 + 31 + 30 + 31 + 31 + 30 + 31 + 30 + 31),
static const char days[] = "Sun Mon Tue Wed Thu Fri Sat ";
static const char months[] = "Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec ";
/* seconds per day */
#define SPD 24*60*60
int __isleap(int year)
    /* every fourth year is a leap year except for century years that are
     * not divisible by 400. */
    /*  return (year % 4 == 0 && (year % 100 != 0 || year % 400 == 0)); */
    return (!(year % 4) && ((year % 100) || !(year % 400)));
struct tm *gmtime_r(const time_t *timep, struct tm *r)
    time_t i;
    register time_t work = *timep % (SPD);
    r->tm_sec = work % 60;
    work /= 60;
    r->tm_min = work % 60;
    r->tm_hour = work / 60;
    work = *timep / (SPD);
    r->tm_wday = (4 + work) % 7;
    for (i = 1970;; ++i)
        register time_t k = __isleap(i) ? 366 : 365;
        if (work >= k)
            work -= k;
        else
            break;
    r->tm_year = i - 1900;
    r->tm_yday = work;
    r->tm_mday = 1;
    if (__isleap(i) && (work > 58))
        if (work == 59)
            r->tm_mday = 2; /* 29.2. */
        work -= 1;
    for (i = 11; i && (__spm > work); --i)
    r->tm_mon = i;
    r->tm_mday += work - __spm;
    return r;
struct tm* gmtime(const time_t* t)
    static struct tm tmp;
    return gmtime_r(t, &tmp);
/*TODO timezone is not supprt now */
struct tm* localtime_r(const time_t* t, struct tm* r)
    return gmtime_r(t, r);
struct tm* localtime(const time_t* t)
    return localtime_r(t, &tmp);
time_t mktime(struct tm * const t)
    register time_t day;
    register time_t i;
    register time_t years = t->tm_year - 70;
    if (t->tm_sec > 60)
        t->tm_min += t->tm_sec / 60;
        t->tm_sec %= 60;
    if (t->tm_min > 60)
        t->tm_hour += t->tm_min / 60;
        t->tm_min %= 60;
    if (t->tm_hour > 24)
        t->tm_mday += t->tm_hour / 24;
        t->tm_hour %= 24;
    if (t->tm_mon > 12)
        t->tm_year += t->tm_mon / 12;
        t->tm_mon %= 12;
    while (t->tm_mday > __spm[1 + t->tm_mon])
        if (t->tm_mon == 1 && __isleap(t->tm_year + 1900))
            --t->tm_mday;
        t->tm_mday -= __spm[t->tm_mon];
        ++t->tm_mon;
        if (t->tm_mon > 11)
            t->tm_mon = 0;
            ++t->tm_year;
    if (t->tm_year < 70)
        return (time_t) - 1;
    /* Days since 1970 is 365 * number of years + number of leap years since 1970 */
    day = years * 365 + (years + 1) / 4;
    /* After 2100 we have to substract 3 leap years for every 400 years
     This is not intuitive. Most mktime implementations do not support
     dates after 2059, anyway, so we might leave this out for it's
     bloat. */
    if (years >= 131)
        years -= 131;
        years /= 100;
        day -= (years >> 2) * 3 + 1;
        if ((years &= 3) == 3)
            years--;
        day -= years;
    day += t->tm_yday = __spm[t->tm_mon] + t->tm_mday - 1 +
                        (__isleap(t->tm_year + 1900) & (t->tm_mon > 1));
    /* day is now the number of days since 'Jan 1 1970' */
    i = 7;
    t->tm_wday = (day + 4) % i; /* Sunday=0, Monday=1, ..., Saturday=6 */
    i = 24;
    day *= i;
    i = 60;
    return ((day + t->tm_hour) * i + t->tm_min) * i + t->tm_sec;
static void num2str(char *c, int i)
    c[0] = i / 10 + '0';
    c[1] = i % 10 + '0';
char* asctime_r(const struct tm *t, char *buf)
    /* "Wed Jun 30 21:49:08 1993\n" */
    *(int*) buf = *(int*) (days + (t->tm_wday << 2));
    *(int*) (buf + 4) = *(int*) (months + (t->tm_mon << 2));
    num2str(buf + 8, t->tm_mday);
    if (buf[8] == '0')
        buf[8] = ' ';
    buf[10] = ' ';
    num2str(buf + 11, t->tm_hour);
    buf[13] = ':';
    num2str(buf + 14, t->tm_min);
    buf[16] = ':';
    num2str(buf + 17, t->tm_sec);
    buf[19] = ' ';
    num2str(buf + 20, (t->tm_year + 1900) / 100);
    num2str(buf + 22, (t->tm_year + 1900) % 100);
    buf[24] = '\n';
    return buf;
char* asctime(const struct tm *timeptr)
    static char buf[25];
    return asctime_r(timeptr, buf);
char* ctime(const time_t *timep)
    return asctime(localtime(timep));
#endif /* __IAR_SYSTEMS_ICC__ */
int gettimeofday(struct timeval *tp, void *ignore)
    time_t time = 0;
#ifdef RT_USING_DEVICE
    rt_device_t device;
    device = rt_device_find("rtc");
    RT_ASSERT(device != RT_NULL);
    rt_device_control(device, RT_DEVICE_CTRL_RTC_GET_TIME, &time);
    if (tp != RT_NULL)
        tp->tv_sec = time;
        tp->tv_usec = 0;
#else
    tv->tv_sec = 0;
    tv->tv_usec = 0;
#endif
    return time;
* Returns the current time.
* @param time_t * t the timestamp pointer, if not used, keep NULL.
* @return time_t return timestamp current.
/* for IAR 6.2 later Compiler */
#if defined (__IAR_SYSTEMS_ICC__) &&  (__VER__) >= 6020000
#pragma module_name = "?time"
#if _DLIB_TIME_USES_64
time_t __time64(time_t *t)
#else
time_t __time32(time_t *t)
#endif
#else
time_t time(time_t *t)
#endif
    time_t time_now = 0;
#ifdef RT_USING_RTC
    static rt_device_t device = RT_NULL;
    /* optimization: find rtc device only first. */
    if (device == RT_NULL)
    /* read timestamp from RTC device. */
    if (device != RT_NULL)
        if (rt_device_open(device, 0) == RT_EOK)
            rt_device_control(device, RT_DEVICE_CTRL_RTC_GET_TIME, &time_now);
            rt_device_close(device);
#endif /* RT_USING_RTC */
    /* if t is not NULL, write timestamp to *t */
    if (t != RT_NULL)
        *t = time_now;
    return time_now;
RT_WEAK clock_t clock(void)
    return rt_tick_get();
* Change Logs:
* Date           Author       Notes
#ifndef _SYS_TIME_H_
#define _SYS_TIME_H_
#include <time.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifndef _TIMEVAL_DEFINED
#define _TIMEVAL_DEFINED
* Structure returned by gettimeofday(2) system call,
* and used in other calls.
struct timeval {
    long    tv_sec;     /* seconds */
    long    tv_usec;    /* and microseconds */
#endif /* _TIMEVAL_DEFINED */
* Skip define timespec for IAR version over 8.10.1 where __VER__ is 8010001.
#if defined ( __ICCARM__ ) && (__VER__ >= 8010001)
#define _TIMESPEC_DEFINED
#endif
#ifndef _TIMESPEC_DEFINED
* Structure defined by POSIX.1b to be like a timeval.
struct timespec {
    time_t  tv_sec;     /* seconds */
    long    tv_nsec;    /* and nanoseconds */
#endif /* _TIMESPEC_DEFINED */
struct timezone {
  int tz_minuteswest;   /* minutes west of Greenwich */
  int tz_dsttime;       /* type of dst correction */
struct tm
        int tm_sec;
        int tm_min;
        int tm_hour;
        int tm_mon;
        int tm_year;
int gettimeofday(struct timeval *tp, void *ignore);
struct tm *gmtime_r(const time_t *timep, struct tm *r);
#ifdef __cplusplus
#endif
#endif /* _SYS_TIME_H_ */
