[讨论] 使用crosstool-ng,出现难解的问题
4860|0
cr315|  楼主 | 2021-8-16 17:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
os, ST, LED, ui, ip, SCR
用的事1.24版本crosstool-ng,所有的的依赖项都已经安装完成,配置所须的源码包都能够正常下载完成,使用的list-samples中的arm-cortex-a8-,ct-ng menuconfig里面的配置采用的是默认,已经进入到build阶段,本以为可以完成了,却出现了如下的错误,希望大牛可以帮忙解答,如果有路人遇见相同的问题,希望共同探讨。
以下是问题描述
Installing C library headers & start files
[INFO ]    =================================================================
[INFO ]    Building for multilib 1/1: ''
[EXTRA]      Configuring C library
[ERROR]      configure: error:
[ERROR]
[ERROR]  >>
[ERROR]  >>  Build faiLED in step 'Building for multilib 1/1: '''
[ERROR]  >>        called in step 'Installing C library headers & start files'
[ERROR]  >>        called in step '(top-level)'
[ERROR]  >>
[ERROR]  >>  Error happened in: CT_DoExecLog[scripts/functions@376]
[ERROR]  >>        called from: glibc_backend_once[scripts/build/libc/glibc.sh@263]
[ERROR]  >>        called from: CT_IterateMultilibs[scripts/functions@1586]
[ERROR]  >>        called from: glibc_backend[scripts/build/libc/glibc.sh@74]
[ERROR]  >>        called from: glibc_start_files[scripts/build/libc/glibc.sh@38]
[ERROR]  >>        called from: do_libc_start_files[scripts/build/libc.sh@28]
[ERROR]  >>        called from: main[scripts/crosstool-NG.sh@696]
