[信息]
mini51ZDE 使用内部22m spi的速率为多少
283|0
麻花油条|  楼主 | 2021-9-6 10:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题
数据手册里没写
  One SPI devices
  Supports Master/Slave mode
  Full-duplex synchronous serial data transfer
  Provides 3-wire function
Mini51
Jul. 18, 2016  Page 13 of 376 Revision 1.03
™ DE SERIES TECHNICAL REFERENCE MANUAL
  Variable length of transfer data from 8 to 32 bits
  MSB or LSB first data transfer
  Rx latching data can be either at rising edge or at falling edge of serial clock
  Tx sending data can be either at rising edge or at falling edge of serial clock
  Supports Byte Suspend mode in 32-bit transmission
  4-level depth FIFO buffe
里面没有 速率的 描述
