[STM8]
加了一行代码程序不正常
657|14
pengf|  楼主 | 2021-11-13 21:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
static void RTC_Config(void)
    RTC_InitTypeDef RTC_InitStr;
        RTC_TimeTypeDef RTC_TimeStr;
        RTC_DateTypeDef RTC_DateStr;
  /* Configures the RTC */
  CLK_RTCClockConfig(CLK_RTCCLKSource_LSE, CLK_RTCCLKDiv_1);
  /* Wait for LSE clock to be ready */
  while(CLK_GetFlagStatus(CLK_FLAG_LSERDY) == RESET);
  /* wait for 1 second for the LSE Stabilisation */
  //LSE_StabTime();
  //delay_ms(1000);
  CLK_PeripheralClockConfig(CLK_Peripheral_RTC, ENABLE);
  RTC_InitStr.RTC_HourFormat = RTC_HourFormat_24;
  RTC_InitStr.RTC_AsynchPrediv = 127;
  RTC_InitStr.RTC_SynchPrediv = 255;
  RTC_Init(&RTC_InitStr);
  RTC_TimeStructInit(&RTC_TimeStr);
  RTC_TimeStr.RTC_Hours = 00;
  RTC_TimeStr.RTC_Minutes = 00;
  RTC_TimeStr.RTC_Seconds = 00;
  RTC_SetTime(RTC_Format_BIN, &RTC_TimeStr);
  RTC_DateStructInit(&RTC_DateStr);
  //RTC_DateStr.RTC_WeekDay = RTC_Weekday_Tuesday;
  RTC_DateStr.RTC_Date = 2;
  RTC_DateStr.RTC_Month = RTC_Month_February;
  RTC_DateStr.RTC_Year = 19;
  RTC_SetDate(RTC_Format_BIN, &RTC_DateStr);
  RTC_WakeUpClockConfig(RTC_WakeUpClock_CK_SPRE_16bits);
  RTC_ITConfig(RTC_IT_WUT, ENABLE);
  /* Enable Interrupts*/
  enableInterrupts();
这句
jiahy| | 2021-11-13 21:47 | 只看该作者
会不会 LSE 的晶振就没有么?
pengf|  楼主 | 2021-11-13 21:50 | 只看该作者
lse 有的 波形正常。后来改为这个有好了, while( (CLK->ECKCR) & (uint8_t)(1<<3) == (uint8_t)RESET);
ousj| | 2021-11-13 21:52 | 只看该作者
这个不知道怎么会影响i2c read
pengf|  楼主 | 2021-11-13 21:54 | 只看该作者
void sEE_ReadBuffer(uint8_t* pBuffer, uint16_t ReadAddr, uint16_t* NumByteToRead)
  //__IO uint32_t timeout = 0xFFFF;
  __IO uint32_t timeout = 0xf00;
  /*!< Wait the end of last communication */
  for (;timeout > 0; timeout--);
  /* Set the pointer to the Number of data to be read. This pointer will be used
      by the DMA Transfer Complete interrupt Handler in order to reset the
      variable to 0. User should check on this variable in order to know if the
      DMA transfer has been completed or not. */
  sEEDataReadPointer = NumByteToRead;
  /*!< While the bus is busy */
  while (I2C_GetFlagStatus(sEE_I2C, I2C_FLAG_BUSY))
  /*!< Send START condition */
  I2C_GenerateSTART(sEE_I2C, ENABLE);
  /*!< Test on EV5 and clear it */
  while (!I2C_CheckEvent(sEE_I2C, I2C_EVENT_MASTER_MODE_SELECT))
  /*!< Send EEPROM address for write */
  I2C_Send7bitAddress(sEE_I2C, (uint8_t)sEEAddress, I2C_Direction_Transmitter);
  /*!< Test on EV6 and clear it */
  while (!I2C_CheckEvent(sEE_I2C, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED))
#ifdef sEE_M24C64_32
  /*!< Send the EEPROM's internal address to read from: MSB of the address first */
  I2C_SendData(sEE_I2C, (uint8_t)((ReadAddr & 0xFF00) >> 8));
  /*!< Test on EV8 and clear it */
  while (!I2C_CheckEvent(sEE_I2C, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
  /*!< Send the EEPROM's internal address to read from: LSB of the address */
  I2C_SendData(sEE_I2C, (uint8_t)(ReadAddr & 0x00FF));
#endif /*!< sEE_M24C64_32 */
  /*!< Send STRAT condition a second time */
  /*!< Send EEPROM address for read */
  I2C_Send7bitAddress(sEE_I2C, (uint8_t)sEEAddress|0x01, I2C_Direction_Receiver);
  while (!I2C_CheckEvent(sEE_I2C, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED))
  // cheng
  I2C_AcknowledgeConfig(sEE_I2C, ENABLE);
  while((uint16_t)(*NumByteToRead))
    if((uint16_t)(*NumByteToRead) == 1)
      /* Disable Acknowledgement */
      //I2C_AcknowledgeConfig(I2C_ACK_NONE);
      I2C_AcknowledgeConfig(sEE_I2C, DISABLE);
    /*!< Send STOP Condition */
      I2C_GenerateSTOP(sEE_I2C, ENABLE);
      /* Send STOP Condition */
      //I2C_GenerateSTOP(ENABLE);
    /* Test on EV7 and clear it */
    while (!I2C_CheckEvent(sEE_I2C, I2C_EVENT_MASTER_BYTE_RECEIVED))
    /*!< Read a byte from the EEPROM */
    *pBuffer = I2C_ReceiveData(sEE_I2C);
      /* Point to the next location where the byte read will be saved */
    pBuffer++;
      /* Decrement the read bytes counter */
    (uint16_t)(*NumByteToRead)--;
  /* Enable Acknowledgement to be ready for another reception */
  #if 0
  /* If number of data to be read is 1, then DMA couldn't be used */
  if ((uint16_t)(*NumByteToRead) < 2)
    /*!< Disable Acknowledgement */
    /*!< Test on EV7 and clear it */
    /*!< Decrement the read bytes counter */
    /*!< Enable Acknowledgement to be ready for another reception */
  #endif
  #if 0
  /* DMA could be used for number of data higher than 1 */
  else
    /* Configure the DMA Rx Channel with the buffer address and the buffer size */
    sEE_LowLevel_DMAConfig((uint16_t)pBuffer, (uint8_t)(*NumByteToRead), sEE_DIRECTION_RX);
    /* Inform the DMA that the next End Of Transfer Signal will be the last one */
    I2C_DMALastTransferCmd(sEE_I2C, ENABLE);
    /* Enable the DMA Rx Channel */
    DMA_Cmd(sEE_I2C_DMA_CHANNEL_RX, ENABLE);
    /* Global DMA Enable */
    DMA_GlobalCmd(ENABLE);
  #endif
supernan| | 2021-11-13 21:57 | 只看该作者
看样子是    while(CLK_GetFlagStatus(CLK_FLAG_LSERDY) == RESET);
的问题.
xxrs| | 2021-11-13 21:59 | 只看该作者
估计晶振未就绪,这  CLK_GetFlagStatus(CLK_FLAG_LSERDY) 返回值并非 RESET.
supernan| | 2021-11-13 22:04 | 只看该作者
得查一下这个函数的说明呢
lizye| | 2021-11-13 22:06 | 只看该作者
看起来没有问题啊
pengf|  楼主 | 2021-11-13 22:08 | 只看该作者
唉,还是没有什么结果,算了,多谢大家啦
aoyi| | 2021-12-7 19:38 | 只看该作者
是一直在while循环里边吗
drer| | 2021-12-7 20:01 | 只看该作者
判定标志位的问题
gwsan| | 2021-12-7 20:05 | 只看该作者
加在什么位置上有很大的关系吧
kxsi| | 2021-12-7 20:07 | 只看该作者
异常现象是什么呢
nawu| | 2021-12-7 20:09 | 只看该作者
是不是不符合配置啊
