[DemoCode下载]
[M480] QSPI 4-BIT Transmission
525|0
奔跑的牛|  楼主 | 2021-12-23 17:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  • Application: This example code is used for the M480 series microcontroller (MCU) to send QSPI 4 serial data bits simultaneously.
  • BSP Version: M480 BSP CMSIS V3.05.001
  • Hardware: NuMaker-M483KG V1.1
This example code is used to configure two QSPIs to transfer serial data bits to other device. Through 2-bit transfer mode, two QSPIs transfer the four serial data bits simultaneously.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1221143146
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
253
