[DemoCode下载]
[NuMicro] Using Nu-Link2 to Access MCU on Linux
481|0
奔跑的牛|  楼主 | 2021-12-23 17:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  • Application: On Linux platform, this example code uses the HIDAPI library to connect Nu-Link2 and access NuMicro series microcontrollers (MCUs).
  • Linux Version: Ubuntu 20.04.3 LTS
  • Hardware: Nu-Link2 (Nu-Link2-Pro or Nu-Link2-Me)
This example code demonstrates the use of HIDAPIto connect Nu-Link2 on Linux, connect to the target microcontroller (MCU) through Nu-Link2, perform chip erase, and read/write operations on Flash and configuration area.
The HIDAPI library used in the example supports two back-ends (hidraw and libusb) on Linux platform. For details, please refer to HIDAPI official website. When compiling this example code, you can choose to use hidraw or libusb back-end in the compilation options.
The example code supports 8-bit (8051) and 32-bit (Arm Cortex-m) target microcontroller access. You can choose to use 8-bit or 32-bit access in the compilation options.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1210095708
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
253
