[DemoCode下载]
[M258] LCD Loading and Short Circuit Detection
458|0
奔跑的牛|  楼主 | 2021-12-28 15:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  • Application: This sample code uses charge pump timeout to calculate the current overall load value of the LCD, and then scans based on the timeout value to detect whether the LCD pins are abnormal.
  • BSP Version: M251/M252/M254/M256/M258 Series CMSIS BSP V3.01.002
  • Hardware: NuMaker-M258KE Ver1.1
This example code "LCD_Loading_And_Short_Circuit_Detection" mainly uses the current maximum time of the charge pump timeout to infer the current overall LCD overall driving load. Then use the charge pump timeout time as the timeout time for scanning each Segment Pin and Common Pin to test whether the current LCD drive load is abnormal and whether there is a short circuit.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1201155027
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
253
