[DemoCode下载]
[M252] Porting Google Protocol Buffers
429|0
奔跑的牛|  楼主 | 2021-12-28 15:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  • Application: This example code demonstrates how to use Nanopb to implement protocol buffers in M252. Nanopb is an ANSI-C implementation of Google Protocol Buffers data format.
  • BSP Version: M251/M252/M254/M256/M258 Series CMSIS BSP V3.01.002
  • Hardware: NuMaker-M252SD Ver1.2
Protocol Buffers (Protobuf) is a free and open source cross-platform library used to serialize structured data. It is useful in developing programs to communicate with each other over a network or for storing data. The method involves an interface description language that describes the structure of some data and a program that generates source code from that description for generating or parsing a stream of bytes that represents the structured data.
The M252 provides sample code to demonstrate how to actually make protocol buffer functionality. Note that this sample code also applies to the M251/M254/M256/M258 series.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1022175123
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
253
