[DemoCode下载]
[M483] Performing 8 MSPS ADC Code
293|0
奔跑的牛|  楼主 | 2021-12-29 13:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AD, RF, dc, ps, FOR, code
  • Application: This sample code uses M483KGCAE2A to perform 8 MSPS ADC by EADC0 and EADC1 sampling alternately.
  • BSP Version: M480 BSP CMSIS V3.05.001
  • Hardware: NuMaker-M483KG Ver1.1
The M483KGCAE2A has two 5 MSPS ADC — EADC0 and EADC1. The sample rate can be doubled if EADC0 and EADC1 do conversion alternately.
This sample code performs 8 MSPS ADC with M483KGCAE2A. 8 MHz trigger signal is from 1 MHz PWM that triggers evenly 8 times within one period. Such high rate data can only be transferred by PDMA. For that reason, EADC0, EADC1, PWM and PDMA is configured working co-operation in this example.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1028172910
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
253
