[DemoCode下载]
[M480] UART RX PDMA
361|0
奔跑的牛|  楼主 | 2022-1-13 14:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  • Application: This example code is used for the M480 series microcontroller (MCU) to receive UART data through PDMA.
  • BSP Version: M480 BSP CMSIS V3.05.001
  • Hardware: NuMaker-PFM-M487 Ver3.0
This example code is used to configure UART and PDMA, then transfer data from UART_RX to RAM through PDMA, and also provide complete package flag. Through Scatter-Gather operation mode, the example code will transfer data by looped around two descriptor tables from UART RX to two different destination RAMs in sequence. Complete package flag is used to indicate that the transmission is completed or timeout. This document introduces the example code of UART_RX triggering PDMA configuration, PDMA Scatter-gather mode configuration, descriptor tables configuration, complete package flag and so on.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1008093231
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
253
