[牛人杂谈]
掉电模式的应用
1044|9
xuanhuanzi|  楼主 | 2022-1-21 13:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TE, ck, UART, IO, se, gp
单片机低功耗的关键就是休眠,休眠的最高境界就是掉电模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 2 $
* $Date: 16/10/25 4:29p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Show how to wake up system from Power-down mode by GPIO interrupt.
* @note
* Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC029xGE.h"
#define PLLCTL_SETTING  CLK_PLLCTL_72MHz_HXT
#define PLL_CLOCK       72000000
/*  Function for System Entry to Power Down Mode                                                           */
void PowerDownFunction(void)
    /* Check if all the debug messages are finished */
    UART_WAIT_TX_EMPTY(UART0);
    /* Enter to Power-down mode */
    CLK_PowerDown();
* @brief       PortA/PortB IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The PortA/PortB default IRQ, declared in startup_NUC029xGE.s.
void GPAB_IRQHandler(void)
    /* To check if PB.3 interrupt occurred */
    if(GPIO_GET_INT_FLAG(PB, BIT3))
        GPIO_CLR_INT_FLAG(PB, BIT3);
        printf("PB.3 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PB interrupts */
        PB->INTSRC = PB->INTSRC;
        printf("Un-expected interrupts.\n");
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and HCLK source divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Init I/O Multi-function        */
    /* Set multi-function pins for UART0 RXD and TXD */
    SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA3MFP_Msk);
    SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA3MFP_UART0_RXD | SYS_GPA_MFPL_PA2MFP_UART0_TXD);
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+-------------------------------------------------------+\n");
    printf("|    GPIO Power-Down and Wake-up by PB.3 Sample Code    |\n");
    printf("+-------------------------------------------------------+\n\n");
    /* Configure PB.3 as Input mode and enable interrupt by rising edge trigger */
    GPIO_SetMode(PB, BIT3, GPIO_MODE_INPUT);
    GPIO_EnableInt(PB, 3, GPIO_INT_RISING);
    NVIC_EnableIRQ(GPAB_IRQn);
    /* Enable interrupt de-bounce function and select de-bounce sampling cycle time is 1024 clocks of LIRC clock */
    GPIO_SET_DEBOUNCE_TIME(GPIO_DBCTL_DBCLKSRC_LIRC, GPIO_DBCTL_DBCLKSEL_1024);
    GPIO_ENABLE_DEBOUNCE(PB, BIT3);
    /* Unlock protected registers before entering Power-down mode */
    SYS_UnlockReg();
    /* Waiting for PB.3 rising-edge interrupt event */
    printf("Enter to Power-Down ......\n");
    PowerDownFunction();
    printf("System waken-up done.\n\n");
    while(1);
/*** (C) COPYRIGHT 2016 Nuvoton Technology Corp. ***/
CLK_PowerDown();
掉电模式的关键函数BSP已经提供了,我们看看到底怎么实现的
  * @brief      Enter to Power-down mode
  * @param      None
  * @return     None
  * @details    This function is used to let system enter to Power-down mode. \n
  *             The register write-protection function should be disabled before using this function.
void CLK_PowerDown(void)
    /* Set the processor uses deep sleep as its low power mode */
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    /* Set system Power-down enabled*/
    CLK->PWRCTL |= CLK_PWRCTL_PDEN_Msk;
    /* Chip enter Power-down mode after CPU run WFI instruction */
    __WFI();
xuanhuanzi|  楼主 | 2022-1-21 14:04 | 只看该作者
看着还挺难懂,如果不看手册。
WFI      Wait For Interrupt
sparrow054| | 2022-1-21 17:27 | 只看该作者
确实比较难懂,一堆代码啊
asmine| | 2022-1-26 13:49 | 只看该作者
掉电和休眠是一会事么?有什么区别
cr315| | 2022-1-26 14:44 | 只看该作者
所以掉电是休眠的一种
redone| | 2022-2-9 15:45 | 只看该作者
有点复杂
sparrow054| | 2022-2-14 14:22 | 只看该作者
我一般需要有人讲解下,尤其是长代码
twjiang| | 2022-2-14 14:25 | 只看该作者
掉电会触发“低压” or "什么“中断,得有个后备电源(电容,UPS)吧,然后进入”休眠“?
twjiang| | 2022-2-14 14:29 | 只看该作者
实现原理是这样的?”掉电“会产生”电压抖动“,这一事件可以由”GPIO防抖功能 de-bounce“捕捉到,然后接下来就可以干自己想做的事情了。
