[DemoCode下载]
[MS51] Using SPI to Realize Breathing ARGB LED Effect
456|0
奔跑的牛|  楼主 | 2022-1-25 15:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  • Application: This sample code uses SPI to simulate ARGB LED timing sequence and realize breathing ARGB LED effect on MS51 series.
  • BSP Version: MS51 Series BSP V1.00.003
  • Hardware: NuMaker-MS51PC Ver1.0
This sample code uses SPI to simulate ARGB LED timing sequence and do LED breathing effect. This code uses one timer to schedule ARGB LED to do ARGB LED dimming and uses one set of SPI to simulate ARGB LED strip timing sequence.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 0907175616
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
253
