[DemoCode下载]
[M031] Control AS7221 by AT Command
500|0
奔跑的牛|  楼主 | 2022-1-25 15:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  • Application: This example code uses AT command to communicate with the AS7221 module through the USCI_UART interface.
  • BSP Version: M031 BSP CMSIS V3.03.000
  • Hardware: NuMaker-M031KI V1.0, AS7221 Module
In this example code, the M031 can send AT command by the UART interface to communicate with the AS7221 embedded module to control the lamp behavior, including brightness adjustment, color temperature control, gradient time tuning and so on.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 0819185615
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
253
