[技术问答]
Control AS7221 by DALI Command
648|0
两只袜子|  楼主 | 2022-1-26 10:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Application: This example code is to add UART interface to the original DALI application project for communication with AS7221, so that DALI
Command can control the AS7221 module.
BSP Version: 102_207_209_NDA102_200707_Lib
Hardware: DALI_SLAVE_NDA102EC1 V1.0
This example code can receive the instructions sent by the DALI (Digital Addressable Lighting Interface) host, and then send commands to AS7221 through the UART1 interface to control the lamp behavior in the module, such as adjusting brightness, color temperature, gradient time and so on.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 0803135654
