[电源技术资料]
大功率D类功放芯片-FT3128
662|2
qiuzhixiang|  楼主 | 2022-3-2 14:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
QQ:2232442533
FEATURES
 Wide range of supply voltages from 5.5V to 20V  Adjustable power limit to safeguard audio speakers
 Automatic level control to eliminate output clipping
 Four selectable gain settings: 20/26/30/34dB
 Three selectable ALC dynamic characteristics
 Two selectable PWM frequencies with optional
spread-spectrum: 360/500kHz
 Two modulation schemes: SSM, DSM
 Optional PBTL configuration for mono applications
qiuzhixiang|  楼主 | 2022-3-8 14:43 | 只看该作者
ft3128还有哪些功能呢?
 GAIN一个管脚提供4个增益选择,节省输入电阻,
防止POP音;
 ALC一个管脚提供4种音效,方便调音;
 2种PWM频率选择,抖频选择,EMI设计更简单
 2种PWM模式选择: SSM / DSM
 PBTL功能,对单喇叭或者低音喇叭提供更大功率;
 PSRR高,纹波抑制性能强;
关机电流30uA
qiuzhixiang 2022-3-9 16:54 回复TA
359244211
