[DemoCode下载]
NUC100的GPIO中断操作
260|0
捉虫天师|  楼主 | 2022-5-17 19:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V2.00
* $Revision: 1 $
* $Date: 14/12/08 11:49a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Show the usage of GPIO interrupt function.
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC100Series.h"
#define PLL_CLOCK   50000000
* @brief       GPIO PA/PB IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The PA/PB default IRQ, declared in startup_NUC100Series.s.
void GPAB_IRQHandler(void)
    /* To check if PB.3 interrupt occurred */
    if(GPIO_GET_INT_FLAG(PB, BIT3))
        GPIO_CLR_INT_FLAG(PB, BIT3);
        printf("PB.3 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PA, PB interrupts */
        PA->ISRC = PA->ISRC;
        PB->ISRC = PB->ISRC;
        printf("Un-expected interrupts.\n");
* @brief       GPIO PC/PD/PE/PF IRQ
* @param       None
* @return      None
* @details     The PC/PD/PE/PF default IRQ, declared in startup_NUC100Series.s.
void GPCDEF_IRQHandler(void)
    /* To check if PE.5 interrupt occurred */
    if(GPIO_GET_INT_FLAG(PE, BIT5))
        GPIO_CLR_INT_FLAG(PE, BIT5);
        printf("PE.5 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PC, PD, PE and PF interrupts */
        PC->ISRC = PC->ISRC;
        PD->ISRC = PD->ISRC;
        PE->ISRC = PE->ISRC;
        PF->ISRC = PF->ISRC;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
    SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD);
void UART0_Init(void)
    /* Init UART        */
    /* Reset UART */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+------------------------------------------------+\n");
    printf("|    GPIO PB.3 and PE.5 Interrupt Sample Code    |\n");
    printf("+------------------------------------------------+\n\n");
    /* GPIO Interrupt Function Test        */
    printf("PB.3 and PE.5 are used to test interrupt ......\n");
    /* Configure PB.3 as Input mode and enable interrupt by rising edge trigger */
    GPIO_SetMode(PB, BIT3, GPIO_PMD_INPUT);
    GPIO_EnableInt(PB, 3, GPIO_INT_RISING);
    NVIC_EnableIRQ(GPAB_IRQn);
    /*  Configure PE.5 as Quasi-bidirection mode and enable interrupt by falling edge trigger */
    GPIO_SetMode(PE, BIT5, GPIO_PMD_QUASI);
    GPIO_EnableInt(PE, 5, GPIO_INT_FALLING);
    NVIC_EnableIRQ(GPCDEF_IRQn);
    /* Waiting for interrupts */
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
