[研电赛技术支持]
GD32F450 ADC的数据寄存器中始终没有数据
703|2
Rogerzl1234|  楼主 | 2022-5-29 18:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是我写的代码,还请各位大神帮忙看一下。外部引脚上有电压,但是ad的规则数据寄存器中始终没有数据。
#include "bsp_adc.h"
__IO uint16_t adc_value[2];
void gpio_config(void)
         rcu_periph_clock_enable(RCU_GPIOA);
         gpio_mode_set(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_1);
         gpio_mode_set(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_6);
void dma_config(void)
        //DMA配置结构体
        dma_single_data_parameter_struct dma_single_data_parameter;
        //开启DMA1时钟
        rcu_periph_clock_enable(RCU_DMA1);
        //复位DMA1的通道0
        dma_deinit(DMA1, DMA_CH0);
        //配置DMA结构体
        dma_single_data_parameter.periph_addr = (uint32_t)(&ADC_RDATA(ADC0));
        dma_single_data_parameter.periph_inc = DMA_PERIPH_INCREASE_DISABLE;
        dma_single_data_parameter.memory0_addr = (uint32_t)(adc_value);
        dma_single_data_parameter.memory_inc = DMA_MEMORY_INCREASE_ENABLE;
        dma_single_data_parameter.periph_memory_width = DMA_PERIPH_WIDTH_16BIT;
        dma_single_data_parameter.direction = DMA_PERIPH_TO_MEMORY;
        dma_single_data_parameter.number = 2;
        dma_single_data_parameter.priority = DMA_PRIORITY_HIGH;
        dma_single_data_mode_init(DMA1, DMA_CH0, &dma_single_data_parameter);
        dma_channel_subperipheral_select(DMA1, DMA_CH0, DMA_SUBPERI0);
        dma_circulation_enable(DMA1, DMA_CH0);  //循环模式
        dma_channel_enable(DMA1, DMA_CH0);  //使能DMA通道
void adc_config(void)
        rcu_periph_clock_enable(RCU_ADC0); //配置ADC0时钟
        adc_clock_config(ADC_ADCCK_PCLK2_DIV6);  //时钟6分频
        adc_deinit();  //ADC寄存器恢复默认值
        /* ADC mode config */
        adc_sync_mode_config(ADC_SYNC_MODE_INDEPENDENT);//
        /* ADC contineous function disable */
        adc_special_function_config(ADC0, ADC_CONTINUOUS_MODE, ENABLE);
        /* ADC scan mode disable */
        adc_special_function_config(ADC0, ADC_SCAN_MODE, ENABLE);
        /* ADC data alignment config */
        adc_data_alignment_config(ADC0, ADC_DATAALIGN_RIGHT);
        adc_resolution_config(ADC0,ADC_RESOLUTION_12B);
        /* ADC channel length config */
        adc_channel_length_config(ADC0, ADC_REGULAR_CHANNEL, 2);
        adc_regular_channel_config(ADC0, 0, ADC_CHANNEL_1, ADC_SAMPLETIME_15);
        adc_regular_channel_config(ADC0, 1, ADC_CHANNEL_6, ADC_SAMPLETIME_15);
//        /* ADC trigger config */
        adc_external_trigger_source_config(ADC0, ADC_REGULAR_CHANNEL, ADC_EXTTRIG_REGULAR_T0_CH0);
        adc_external_trigger_config(ADC0, ADC_REGULAR_CHANNEL, EXTERNAL_TRIGGER_DISABLE);
        /* enable ADC interface */
        adc_enable(ADC0);
        delay_ms(1);
                /* ADC DMA function enable */
        adc_dma_request_after_last_enable(ADC0);
        adc_dma_mode_enable(ADC0);
        /* ADC calibration and reset calibration */
        adc_calibration_enable(ADC0);
        delay_ms(1);
        /* enable ADC software trigger */
        adc_software_trigger_enable(ADC0, ADC_REGULAR_CHANNEL);
void adc_init(void)
        gpio_config();
        dma_config();
        adc_config();
jlnjkbjhcvfgcfg| | 2024-2-28 16:04 | 只看该作者
和你一样问题,请问博主现在解决了吗
申小林一号| | 2024-4-30 16:24 | 只看该作者
非常不错的帖子,值得推广扩散!!!
