LCD12864液晶屏问题
278|0
橘子阿小|  楼主 | 2022-6-2 14:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
定义了汉字库
const uchar  CHN_CHARACTORS[][28]={
                {/*--  文字:  相  --*///CHN_xiang[]
                /*--  新宋体五号;  此字体下对应的点阵为:宽x高=14x16   --*/
        0x08,0x88,0x68,0xFF,0x48,0x88,0x00,0xFE,0x22,0x22,0x22,0x22,0xFE,0x00,
        0x02,0x01,0x00,0x3F,0x00,0x00,0x00,0x3F,0x11,0x11,0x11,0x11,0x3F,0x00,
                {/*--  文字:  漏  --*/
        /*--  新宋体11;  此字体下对应的点阵为:宽x高=16x15   --*/
        /*--  高度不是8的倍数,现调整为:宽度x高度=16x16  --*/
        0x10,0x22,0x84,0x00,0xFE,0x2A,0xAA,0xAA,0xAA,0xEA,0xAA,0xAA,0xAE,0x00,
        0x18,0x06,0x01,0x20,0x1F,0x00,0x3F,0x0A,0x00,0x1F,0x00,0x2A,0x3F,0x00,
                {/*--  文字:  电  --*///CHN_dian[]
                0x00,0xF8,0x48,0x48,0x48,0x48,0xFF,0x48,0x48,0x48,0x48,0xF8,0x00,0x00,0x00,0x07,
                0x02,0x02,0x02,0x02,0x1F,0x22,0x22,0x22,0x22,0x23,0x38,0x00
                {/*--  文字:  有  --*///CHN_you[]
                0x84,0x44,0x24,0xF4,0x9C,0x97,0x94,0x94,0x94,0x94,0xF4,0x04,0x04,0x00,0x00,0x00,
                0x00,0x3F,0x04,0x04,0x04,0x04,0x24,0x24,0x3F,0x00,0x00,0x00
                {/*--  文字:  无  --*///CHN_wu[]
                0x40,0x42,0x42,0x42,0x42,0xC2,0x7E,0xC2,0x42,0x42,0x42,0x42,0x40,0x00,0x20,0x10,
                0x08,0x04,0x02,0x01,0x00,0x1F,0x20,0x20,0x20,0x20,0x38,0x00
如果没有const限定符 液晶屏就会显示字,反之,如果如上有const则液晶屏不显示汉字  是什么问题?
