[开发工具]
static关键字在定义接口初始化结构体的用处是什么?
289|0
wanduzi|  楼主 | 2022-6-23 10:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* USER CODE BEGIN PV */
static GPIO_InitTypeDef  GPIO_InitStruct;
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * [url=home.php?mod=space&uid=247401]@brief[/url]  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* STM32G4xx HAL library initialization:
       - Configure the Flash prefetch
       - Systick timer is configured by default as source of time base, but user
         can eventually implement his proper time base source (a general purpose
         timer for example or other time source), keeping in mind that Time base
         duration should be kept 1ms since PPP_TIMEOUT_VALUEs are defined and
         handled in milliseconds basis.
       - Set NVIC Group Priority to 4
       - Low Level Initialization
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* USER CODE BEGIN 2 */
   /* -1- Enable GPIO Clock (to be able to program the configuration registers) */
  LED2_GPIO_CLK_ENABLE();
  /* -2- Configure IO in output push-pull mode to drive external LEDs */
  GPIO_InitStruct.Mode  = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull  = GPIO_PULLUP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  GPIO_InitStruct.Pin = LED2_PIN;
  HAL_GPIO_Init(LED2_GPIO_PORT, &GPIO_InitStruct);
一直不懂啊
这里为何要用 static 修饰。
