[技术讨论] SST26VF064B的状态寄存器读取
629|0
 楼主| 132lll 发表于 2022-9-2 11:16 | 显示全部楼层 |阅读模式
兄弟们,读取flash的JEDEC_ID能够正确发挥0xBF2643,但读取状态寄存器一直返回0xFF。
求助!!!!!!!!!
下面附代码:
static uint8_t Flash_TransferReceiveByte(IN uint8_t TxData)
    uint16_t spiTxData = (uint16_t)TxData;
    uint16_t spiRxData;
    spiTransmitAndReceiveData(spiREG4, &g_spi4Config, 1, &spiTxData, &spiRxData);
    return (uint8_t)spiRxData;
uint32_t Flash_GetJEDEC_ID(void){
    uint32_t ID1, ID2, ID3, ID;
    CS_ENABLE();
    Flash_TransferReceiveByte(JEDEC_ID);
    ID1 = Flash_TransferReceiveByte(DUMMY);
    ID2 = Flash_TransferReceiveByte(DUMMY);
    ID3 = Flash_TransferReceiveByte(DUMMY);
    CS_DISABLE();
    ID=((ID1<<16)|(ID2<<8)|ID3);
    return ID;
uint8_t Flash_ReadStaReg(void){
    uint8_t StaReg;
    CS_ENABLE();
    Flash_TransferReceiveByte(RDSR);
    StaReg = Flash_TransferReceiveByte(DUMMY);
    CS_DISABLE();
    return StaReg;
