九齐NY8BE62D数码管03
167|0
34af9uc|  楼主 | 2022-10-25 12:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <ny8.h>
//             NY8BE62D_S16
//         _______   _______
//        |1 vdd  \_/ vss 16|
//        |2 pa6      pa4 15|-scl
//        |3 pa7      pa3 14|
//        |4 pa5      pa2 13|-sda
//        |5 pb3      pa1 12|
//  led_4-|6 pb2      pa0 11|-led_1
//  led_5-|7 pb1      pb5 10|-led_2
//  led_6-|8_pb0______pb4__9|-led_3
//                 LCD CS3631AW-4-D
//                  @1@2@3@4@5@6
//     ___A1___      ___A2___      ___A3___
//    F1      B1    F2      B2    F3      B3
//    |___G1___|    |___G2___|    |___G3___|
//    E1      C1 DP E2      C2 DP E3      C3 DP
//    |___D1___|.   |___D2___|.   |___D3___|.
//       x_a1          x_a2          x_a3    //全局变量
//  1  1  4  5  1  2  3  1    2  2  5  2  2  3  4  3    5  3  4  6  6  4  5  4
//  2  3  1  1  4  1  1  6    3  4  2  6  5  2  2  6    4  5  5  1  3  3  3  6
// A1 B1 C1 D1 E1 F1 G1 DP   A2 B2 C2 D2 E2 F2 G2 DP   A3 B3 C3 D3 E3 F3 G3 DP
__sbit led_1                =PORTA:0;
__sbit led_2                =PORTB:5;
__sbit led_3                =PORTB:4;
__sbit led_4                =PORTB:2;
__sbit led_5                =PORTB:1;
__sbit led_6                =PORTB:0;
/**************************************************/                //0输出1输入
#define                led_1_h                IOSTA&=~(1<<0);led_1=1
#define                led_2_h                IOSTB&=~(1<<5);led_2=1
#define                led_3_h                IOSTB&=~(1<<4);led_3=1
#define                led_4_h                IOSTB&=~(1<<2);led_4=1
#define                led_5_h                IOSTB&=~(1<<1);led_5=1
#define                led_6_h                IOSTB&=~(1<<0);led_6=1
#define                led_1_l                IOSTA&=~(1<<0);led_1=0
#define                led_2_l                IOSTB&=~(1<<5);led_2=0
#define                led_3_l                IOSTB&=~(1<<4);led_3=0
#define                led_4_l                IOSTB&=~(1<<2);led_4=0
#define                led_5_l                IOSTB&=~(1<<1);led_5=0
#define                led_6_l                IOSTB&=~(1<<0);led_6=0
#define                led_1_g                IOSTA|=1<<0
#define                led_2_g                IOSTB|=1<<5
#define                led_3_g                IOSTB|=1<<4
#define                led_4_g                IOSTB|=1<<2
#define                led_5_g                IOSTB|=1<<1
#define                led_6_g                IOSTB|=1<<0
void                yanshi(unsigned int x);
void                xianshi();                //显示
unsigned char                x_a1,x_a2,x_a3;                //全局变量显示用
unsigned char const zi1[]={ 0xfc,0x60,0xda,0xf2,0x66,
0xb6,0xbe,0xe0,0xfe,0xf6,0x7e};//0-20
void main(void)
x_a1                =zi1[0];
x_a2                =zi1[1];
x_a3                =zi1[2];
while(1)
xianshi();
unsigned int y;
for(y=1;y>0;y--);
void                xianshi()                //显示
//unsigned char                x_a1,x_a2,x_a3;                //全局变量显示用
led_1_h;        //第一次扫描
if(x_a1&0x20){led_4_l;} else{led_4_g;}
if(x_a1&0x10){led_5_l;} else{led_5_g;}
if(x_a1&0x04){led_2_l;} else{led_2_g;}
if(x_a1&0x02){led_3_l;} else{led_3_g;}
if(x_a3&0x10){led_6_l;} else{led_6_g;}
yanshi(10);
led_1_g;
led_2_h;        //第二次扫描
if(x_a1&0x80){led_1_l;} else{led_1_g;}
if(x_a2&0x20){led_5_l;} else{led_5_g;}
if(x_a2&0x04){led_3_l;} else{led_3_g;}
if(x_a2&0x02){led_4_l;} else{led_4_g;}
yanshi(10);
led_2_g;
led_3_h;        //第三次扫描
if(x_a1&0x40){led_1_l;} else{led_1_g;}
if(x_a2&0x80){led_2_l;} else{led_2_g;}
if(x_a3&0x08){led_6_l;} else{led_6_g;}
if(x_a3&0x04){led_4_l;} else{led_4_g;}
if(x_a3&0x02){led_5_l;} else{led_5_g;}
yanshi(10);
led_3_g;
led_4_h;        //第四次扫描
if(x_a1&0x08){led_1_l;} else{led_1_g;}
if(x_a2&0x40){led_2_l;} else{led_2_g;}
if(x_a3&0x80){led_5_l;} else{led_5_g;}
yanshi(10);
led_4_g;
led_5_h;        //第五次扫描
if(x_a2&0x08){led_2_l;} else{led_2_g;}
if(x_a3&0x40){led_3_l;} else{led_3_g;}
if(x_a3&0x20){led_4_l;} else{led_4_g;}
yanshi(10);
led_5_g;
led_6_h;        //第六次扫描
if(x_a1&0x01){led_1_l;} else{led_1_g;}
if(x_a2&0x10){led_2_l;} else{led_2_g;}
if(x_a2&0x01){led_3_l;} else{led_3_g;}
if(x_a3&0x01){led_4_l;} else{led_4_g;}
yanshi(10);
led_6_g;
main (3).zip
1.22 KB
发新帖
