[技术讨论]
观海微电子GH1001 datasheet及应用介绍
203|0
草莓|  楼主 | 2022-12-2 16:35 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
#申请原创# #每日话题# #有奖活动# #技术资源# 观海微电子GH1001 datasheet及应用介绍
观海微GH1001支持HD 768分辨率驱动IC。
GH1001 设计可驱动 α-Si、LTPS&IGZO TFT 点阵 LCD,最高可支持分辨率:768RGBx2046 。
Single chip solution for a WXGA α-Si type LCD display Resolution:
768 x LN*2
750 x LN*2
720 x LN*2
640 x LN*2
600 x LN*2
Display color modes
Full color mode:
   16.7M colors (24-bit 8(R):8(G):8(B))
Display Interface
  MIPI-DSI (Display Serial Interface) interface
Input voltage ranges
  1. I/O and interface power supply (VDDI): 1.65V to 3.6V
  2. High speed interface power supply (VDDM): 1.65V to 3.6V
  3. Analog voltage range for VSP to VSS: 4.3V ~ 6.5V
  4. Analog voltage range for VSN to VSS: -4.3V ~ -6.5V
  5. Analog voltage range for VGH to VSS: 6.2V ~ 19.6V
  6. Analog voltage range for VGL to VSS: -7V ~ -16V
Output voltage ranges(On module DC/DC converter)
  1. Positive source output voltage level: VSPR= +4.0V to 5.5V
  2. Negative source output voltage level: VSNR= -4.0V to -5.5V
  3. Positive gate driver output voltage level: VGH= 7 to 19.6V
  4. Negative gate driver output voltage level: VGL=-7V to -16V
  5. VCOM=-0.3V to -4V, a step=10mv
Miscellaneous of chip
  1. Internal level shifter for Gate Driver control
  2. Supports column / 1-dot /1+2-dot / 2-dot / 4-dot / 8-dot/ 3-dot
  3. Gamma correction (1 preset gamma curve)
  4. Internal Oscillator generation
  5. CMOS compatible inputs
  6. Proprietary multi-phase driving for lower power consumption
  7. On-chip OTP program voltage generator
  8. OTP memory to store initialization register settings
     3 times OTP for Gamma setting
     2 times OTP for VCOM setting
     4 times OTP for ID setting
  9. Support BIST mode
  10. Support scaler-source/gate
  11. Temperature range: -40 to +85
  12. Chip size(including scribe line):27450um×880um
  13. Bump high:9um
目前匹配LCD如下(部分):
