[PIC32/SAM]
ATSAMD51 EVK评估板评测7HT1621
379|10
今天真背,PWM没搞好,触摸按键没搞好,只好搞一个段式液晶HT1621了。
代码:
#include <stddef.h>                     // Defines NULL
#include <stdbool.h>                    // Defines true
#include <stdlib.h>                     // Defines EXIT_FAILURE
#include "definitions.h"                // SYS function prototypes
// Section: Main Entry Point
#define Smg_a    0x80
#define Smg_b    0x40
#define Smg_c    0x20
#define Smg_d    0x01
#define Smg_e    0x02
#define Smg_f    0x08
#define Smg_g    0x04
#define Smg_dp   0x10
#define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map          Smg_b | Smg_c
#define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map          Smg_a | Smg_b | Smg_c
#define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
#define CS_0           GPIO_PA06_Clear()
#define CS_1           GPIO_PA06_Set()
#define WR_0           GPIO_PB05_Clear()
#define WR_1           GPIO_PB05_Set()
#define DA_0           GPIO_PB04_Clear()
#define DA_1           GPIO_PB04_Set()
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //显示缓冲区
unsigned int i;
void delay(void)
    for(i=0;i<10;i++);
void COMMAND_HT1621(unsigned char comm)
        unsigned char i;
        CS_0;
        delay();
        WR_0;
    delay();
        for(i=0;i<3;i++)        //写命令
                if((0x04<<i)&0x04)  DA_1;    //100
                else                DA_0;
        delay();
                WR_0;
        delay();
                WR_1;
        delay();
        for(i=0;i<9;i++)        //写命令数据
                if((comm<<i)&0x80)  DA_1;    //100
                else                DA_0;
        delay();
                WR_0;
        delay();
                WR_1;
        delay();
        CS_1;
void HT1621_Display(void)
        unsigned char i;
        CS_0;                        //片选CS
    delay();
        WR_0;
    delay();
                if((0x05<<i)&0x04)  DA_1;
                else                DA_0;
        delay();
                WR_0;
        delay();
                WR_1;
        delay();
        for(i=0;i<6;i++)                   //写地址
                if((20<<i)&0x20)    DA_1;  //20对应 SEG地址
                  else                DA_0;
        delay();
                WR_0;
        delay();
                WR_1;
        delay();
        for(i=0;i<8;i++)                   //写数据
                if((DpyNum[5]<<i)&0x80)   DA_1;
                else                      DA_0;
        delay();
                WR_0;
        delay();
                WR_1;
        delay();
                if((DpyNum[4]<<i)&0x80)   DA_1;
                else                      DA_0;
        delay();
                WR_0;
        delay();
                WR_1;
        delay();
                if((DpyNum[3]<<i)&0x80)   DA_1;
                else                      DA_0;
        delay();
                WR_0;
        delay();
                WR_1;
        delay();
                if((DpyNum[2]<<i)&0x80)   DA_1;
                else                      DA_0;
        delay();
                WR_0;
        delay();
                WR_1;
        delay();
                if((DpyNum[1]<<i)&0x80)   DA_1;
                else                      DA_0;
        delay();
                WR_0;
        delay();
                WR_1;
        delay();
                if((DpyNum[0]<<i)&0x80)   DA_1;
                else                      DA_0;
        delay();
                WR_0;
        delay();
                WR_1;
        delay();
        CS_1;                          //释放CS
void LCD_Init(void)
        COMMAND_HT1621(0x01);         //SYS EN
        COMMAND_HT1621(0x03);         //LCD ON
        COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
        HT1621_Display();             //clear screen
int main ( void )
    /* Initialize all modules */
    SYS_Initialize ( NULL );
    LCD_Init();
    DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"三"
    DpyNum[1] = SegCode[1];
    DpyNum[2] = SegCode[3];
    DpyNum[3] = SegCode[5];
    DpyNum[4] = SegCode[7];
    DpyNum[5] = SegCode[9];
    HT1621_Display();
    while ( true )
        /* Maintain state machines of all polled MPLAB Harmony modules. */
        SYS_Tasks ( );
    /* Execution should not come here during normal operation */
    return ( EXIT_FAILURE );
End of File
初始化代码:
void SYS_Initialize ( void* data )
    /* MISRAC 2012 deviation block start */
    /* MISRA C-2012 Rule 2.2 deviated in this file.  Deviation record ID -  H3_MISRAC_2012_R_2_2_DR_1 */
    NVMCTRL_Initialize( );
    PORT_Initialize();
    CLOCK_Initialize();
    EVSYS_Initialize();
    NVIC_Initialize();
    /* MISRAC 2012 deviation block end */
void PORT_Initialize(void)
   /************************** GROUP 0 Initialization *************************/
   PORT_REGS->GROUP[0].PORT_DIR = 0x40U;
   PORT_REGS->GROUP[0].PORT_PINCFG[6] = 0x0U;
   PORT_REGS->GROUP[0].PORT_PMUX[3] = 0x0U;
   /************************** GROUP 1 Initialization *************************/
   PORT_REGS->GROUP[1].PORT_DIR = 0x30U;
   PORT_REGS->GROUP[1].PORT_PINCFG[4] = 0x0U;
   PORT_REGS->GROUP[1].PORT_PINCFG[5] = 0x0U;
   PORT_REGS->GROUP[1].PORT_PMUX[2] = 0x0U;
   /************************** GROUP 2 Initialization *************************/
   /************************** GROUP 3 Initialization *************************/
效果图:
lzmm| | 2023-1-5 12:30 | 只看该作者
ATSAMD51 EVK评估板真是小巧玲珑的。
claretttt| | 2023-1-5 16:57 | 只看该作者
感觉好复杂的代码,需要自己写这么多寄存器的。
lzbf| | 2023-1-6 14:42 | 只看该作者
HT1621这个是驱动模块的吗?
jonas222| | 2023-1-6 15:14 | 只看该作者
这个段式液晶需要自己定制的 吗?
比神乐|  楼主 | 2023-1-6 16:07 | 只看该作者
lzbf 发表于 2023-1-6 14:42
HT1621这个是驱动模块的吗?
我自己买的,根据例程改的。
jonas222 发表于 2023-1-6 15:14
这个段式液晶需要自己定制的 吗?
我淘宝上买的。
uiint| | 2023-1-7 13:12 | 只看该作者
HT1621是自带的设备的吗?
比神乐|  楼主 | 2023-1-7 13:27 | 只看该作者
uiint 发表于 2023-1-7 13:12
HT1621是自带的设备的吗?
不是
uytyu| | 2023-1-10 21:38 | 只看该作者
怎么才能让液晶显示汉字?
比神乐|  楼主 | 2023-1-11 10:57 | 只看该作者
这种段式液晶显示不了汉字
