GD32F303RCT6-TIMER2-CH2无法进行PWM频率捕获
456|0
zsy3830|  楼主 | 2022-12-12 15:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
硬件初始化:
            rcu_periph_clock_enable(RCU_GPIOB);
            rcu_periph_clock_enable(RCU_TIMER2);
            rcu_periph_clock_enable(RCU_AF);
            gpio_init(GPIOC, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_8);
            gpio_pin_remap_config(GPIO_TIMER2_FULL_REMAP, ENABLE);//PC8 FULL Remap
            timer_deinit(TIMER2);
            /* initialize TIMER init parameter struct */
            timer_struct_para_init(&timer_initpara);
            /* TIMER2 configuration */
            timer_initpara.prescaler         = 0;
            timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
            timer_initpara.counterdirection  = TIMER_COUNTER_UP;
            timer_initpara.period            = 65535;
            timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
            timer_initpara.repetitioncounter = 0;
            timer_init(TIMER2, &timer_initpara);
            /* TIMER2 CH2 PWM input capture configuration */
            timer_icinitpara.icpolarity  = TIMER_IC_POLARITY_RISING;
            timer_icinitpara.icselection = TIMER_IC_SELECTION_DIRECTTI;
            timer_icinitpara.icprescaler = TIMER_IC_PSC_DIV1;
            timer_icinitpara.icfilter    = 0;
            //timer_input_pwm_capture_config(TIMER2, TIMER_CH_2, &timer_icinitpara);
            timer_input_capture_config(TIMER2, TIMER_CH_2, &timer_icinitpara);
            /* slave mode selection: TIMER2 */
            timer_input_trigger_source_select(TIMER2, TIMER_SMCFG_TRGSEL_CI1FE1);
            timer_slave_mode_select(TIMER2, TIMER_SLAVE_MODE_RESTART);
            /* select the master slave mode */
            timer_master_slave_mode_config(TIMER2, TIMER_MASTER_SLAVE_MODE_ENABLE);
            /* auto-reload preload enable */
            timer_auto_reload_shadow_enable(TIMER2);
            /* clear channel 2 interrupt bit */
            timer_interrupt_flag_clear(TIMER2, TIMER_INT_FLAG_CH2);
            /* channel 2 interrupt enable */
            timer_interrupt_enable(TIMER2, TIMER_INT_CH2);
            /* TIMER2 counter enable */
            timer_enable(TIMER2);
中断函数:
void TIMER2_IRQHandler(void)
    if(SET == timer_interrupt_flag_get(TIMER2, TIMER_INT_FLAG_CH2))
        /* clear channel 1 interrupt bit */
        /* read channel 1 capture value */
        ic1valueW[0] = timer_channel_capture_value_register_read(TIMER2, TIMER_CH_2) + 1;
        if(0 != ic1valueW[0])
            ic2valueW[0] = timer_channel_capture_value_register_read(TIMER2, TIMER_CH_2)+1;
            /* calculate the duty cycle value */
            dutycycleW[0] = (ic2valueW[0] * 100) / ic1valueW[0];
            /* calculate the frequency value */
            frequencyW[0] = 1000000 / ic1valueW[0];
        else
            dutycycleW[0] = 0;
            frequencyW[0] = 0;
硬件没有问题,MCU的IO口有真实的PWM波形,但是中断没有触发
各路大神,跪求指点找出问题在哪里
