GD32F103外部脉冲计数
2067|1
yangfrch|  楼主 | 2022-12-20 19:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
yangfrch|  楼主 | 2022-12-20 19:37 | 只看该作者
static void Timer_Rcu_NvicIrq_Init(void)
    rcu_periph_clock_enable(RCU_GPIOA);
    rcu_periph_clock_enable(RCU_AF);
    rcu_periph_clock_enable(RCU_TIMER1);
static void Timer_Gpio_Init(void)
    gpio_init(GPIOA, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_0);
static void Timer_Config(void)
    timer_parameter_struct timer_initpara;
    // timer_ic_parameter_struct timer_icinitpara;
    timer_deinit(TIMER1);
    /* initialize TIMER init parameter struct */
    timer_struct_para_init(&timer_initpara);
    /* TIMER1 configuration */
    timer_initpara.prescaler = 0;
    timer_initpara.alignedmode = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection = TIMER_COUNTER_UP;
    timer_initpara.period = 0xffff;
    timer_initpara.clockdivision = TIMER_CKDIV_DIV1;
    timer_init(TIMER1, &timer_initpara);
    /* slave mode selection : TIMER1 */
    /* TIMER1 input trigger : external trigger connected to CI0 */
    timer_input_trigger_source_select(TIMER1, TIMER_SMCFG_TRGSEL_CI0FE0);
    timer_slave_mode_select(TIMER1, TIMER_SLAVE_MODE_EXTERNAL0);
    timer_external_clock_mode1_config(TIMER1, TIMER_EXT_TRI_PSC_OFF, TIMER_ETP_RISING, 0);
    timer_enable(TIMER1);
