[开发工具]
【APM32F107VCT6 MINI开发板测评】HT1621
327|0
今天搞了一下HT1621.
DA接PC0,WR接PC1,CS接PC2.
主程序代码:
#include "main.h"
/** @addtogroup Examples
#define uchar unsigned char
#define uint unsigned int
/** @addtogroup 425_GPIO_led_toggle GPIO_led_toggle
#define DA_1 GPIO_SetBit(GPIOC,DA_PIN)
#define DA_0 GPIO_ResetBit(GPIOC,DA_PIN)
#define WR_1 GPIO_SetBit(GPIOC,WR_PIN)
#define WR_0 GPIO_ResetBit(GPIOC,WR_PIN)
#define CS_1 GPIO_SetBit(GPIOC,CS_PIN)
#define CS_0 GPIO_ResetBit(GPIOC,CS_PIN)
#define Smg_a    0x80
#define Smg_b    0x40
#define Smg_c    0x20
#define Smg_d    0x01
#define Smg_e    0x02
#define Smg_f    0x08
#define Smg_g    0x04
#define Smg_dp   0x10
#define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map          Smg_b | Smg_c
#define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map          Smg_a | Smg_b | Smg_c
#define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //ÏÔʾ»º³åÇø
unsigned int i;
void COMMAND_HT1621(unsigned char comm)
    //unsigned char i;
    CS_0;
    WR_0;
    for(i=0;i<3;i++)        //дÃüÁî
        if((0x04<<i)&0x04)  DA_1;    //100
        else                DA_0;
        WR_0;
        WR_1;
    for(i=0;i<9;i++)        //дÃüÁîÊý¾Ý
        if((comm<<i)&0x80)  DA_1;    //100
        else                DA_0;
        WR_0;
        WR_1;
    CS_1;
void HT1621_Display(void)
    //unsigned char i;
    CS_0;                        //ƬѡCS
    WR_0;
        if((0x05<<i)&0x04)  DA_1;
        else                DA_0;
        WR_0;
        WR_1;
    for(i=0;i<6;i++)                   //дµØÖ·
        if((20<<i)&0x20)    DA_1;  //20¶ÔÓ¦ SEGµØÖ·
        else                DA_0;
        WR_0;
        WR_1;
    for(i=0;i<8;i++)                   //дÊý¾Ý
        if((DpyNum[5]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[4]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[3]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[2]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[1]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
        if((DpyNum[0]<<i)&0x80)   DA_1;
        else                      DA_0;
        WR_0;
        WR_1;
    CS_1;                          //ÊÍ·ÅCS
void LCD_Init(void)
    COMMAND_HT1621(0x01);         //SYS EN
    COMMAND_HT1621(0x03);         //LCD ON
    COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
    HT1621_Display();             //clear screen
/** @addtogroup GPIO_Toggle
/** @defgroup GPIO_Toggle_Functions Functions
void APM_MINI_HT1621Init(void)
    GPIO_Config_T  configStruct;
    /* Enable the GPIO_LED Clock */
    RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_GPIOC);
    /* Configure the GPIO_LED pin */
    configStruct.pin = DA_PIN | WR_PIN | CS_PIN;
    configStruct.mode = GPIO_MODE_OUT_PP;
    configStruct.speed = GPIO_SPEED_50MHz;
    GPIO_Config(GPIOC, &configStruct);
* [url=home.php?mod=space&uid=247401]@brief[/url]       Main program
* @param       None
* @retval      None
int main(void)
    APM_MINI_HT1621Init();
    LCD_Init();
    DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"Èý"
    DpyNum[1] = SegCode[2];
    DpyNum[2] = SegCode[4];
    DpyNum[3] = SegCode[6];
    DpyNum[4] = SegCode[8];
    DpyNum[5] = SegCode[0];
    HT1621_Display();               //Ë¢ÐÂLCD
    while (1)
* @brief       Main program
* @param       None
* @retval      None
void Delay(void)
    volatile uint32_t delay = 0xffffff;
    while(delay--);
/**@} end of group GPIO_Toggle_Functions */
/**@} end of group GPIO_Toggle */
/**@} end of group Examples */
初始化代码:
#define DA_PIN                                  GPIO_PIN_0
#define DA_GPIO_PORT                     GPIOC
#define DA_GPIO_CLK                      RCM_APB2_PERIPH_GPIOC
#define WR_PIN                                  GPIO_PIN_1
#define WR_GPIO_PORT                     GPIOC
#define WR_GPIO_CLK                      RCM_APB2_PERIPH_GPIOC
#define CS_PIN                                  GPIO_PIN_2
#define CS_GPIO_PORT                     GPIOC
#define CS_GPIO_CLK                      RCM_APB2_PERIPH_GPIOC
效果图:
